Re: [mpich-discuss] Possible integer overflows at scale in gather.c
On 09/30/2015 04:08 PM, Ignacio Laguna wrote:
I found some 'potential' integer overflows when running mpich at large scale and/or with large inputs in gather.c. I believe that they are related to ticket #1767 (http://trac.mpich.org/projects/mpich/ticket/1767), but I didn't see any other bug reports about them so I thought I should confirm with mpich developers.
In addition to this case in line 171:
98 int tmp_buf_size, missing; ... 169 if (nbytes < MPIR_CVAR_GATHER_VSMALL_MSG_SIZE) tmp_buf_size++; 170 171 tmp_buf_size *= nbytes;
which I believe it's fixed in mpich-3.2b4 (where tmp_buf_size is declared as a 64-bit MPI_Aint),
I fixed this (I sure hope!) over the summer in commit 68f8c7aa798f7009
I found the following cases in the same file src/mpi/coll/gather.c (in both mpich-3.1.4 and mpich-3.2b4):
Case 1:
222 mpi_errno = MPIC_Recv(((char *)recvbuf + 223 (((rank + mask) % comm_size)*recvcount*extent)), 224 recvblks * recvcount, recvtype, src, 225 MPIR_GATHER_TAG, comm, 226 &status, errflag);
In line 223 I believe we get an integer overflow as follows. Suppose I run 2^20 = 1,048,576 ranks and do a gather with 4,096 elements. In this case (if I understand the algorithm well), ((rank + mask) % comm_size) would be 2^20 / 2 = 524,288, and recvcount = 4,096. Then the ((rank + mask) % comm_size)*recvcount expression would overflow: 524,288 * 4,096 = 2,147,483,648, and become negative.
We're doing address math here, so I hope the compiler is not trying to store intermediate results in an integer. However, if LLVM is saying otherwise, then sure, let's promote those types. ((rank + mask) % comm_size)*recvcount is of type int*int, which is then multiplied by an MPI_Aint... yeah, looks suspicious. There are quite a few places where we do math on recvcount and recvblocks -- does your static analysis show problems with all of those spots?
When multiplied with 'extent', which is size_t or MPI_Aint, it will become negative I believe or a huge positive which in any case will point to the wrong location in the recvbuf buffer, unless of course this wraparound behavior is intended.
Nope, wraparound sure is not intended! We would have no hope of cleaning up all these locations if it were not for clang's -Wshorten64-to-32 flag.
Case 2:
There might be a similar problem in line 224 in the above code. With 2^20 ranks, recvblks becomes 524,288 (again if I understand well the algorithm), so the recvblks * recvcount operation will also overflow.
I might be wrong on this -- I'm catching these issues with LLVM symbolic analysis -- so they can be totally false positives,
Tell me more about LLVM symbolic analysis! We have started using coverity for static analysis but yes, there are a lot of messages obscuring the genuine bugs.
but I just wanted to check with the mpich developers if they are valid issues or not. If they are, I believe fixes can be easy to implement (just make all these computations size_t).
I promoted the prototype for MPIC_Recv to this: int MPIC_Recv(void *buf, MPI_Aint count, MPI_Datatype datatype, int source, int tag, MPID_Comm *comm_ptr, MPI_Status *status, MPIR_Errflag_t *errflag) Top-level MPI routines are stuck using an 'int' count, but internally we can (and now do) use a larger MPI_Aint type. True, int*int can overflow, but since that parameter to MPIC_Recv is of the larger MPI_Aint type, we're ok here. LLVM disagrees? ==rob -- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Rob Latham
