Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries
Darn. I'm creating an issue to track this since it will likely take some time and effort to investigate each configuration. https://github.com/pmodels/mpich/issues/5835 Ken On 2/7/22, 12:41 PM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]> wrote: Ken, To review, I configured as follows: $ configure CFLAGS=-DUSE_PMI2_API LIBS=-lpmi2 --with-pm=none --with-pmi=slurm --with-slurm=/opt/slurm < ...> and ran srun with the argument --mpi=pmi2. The job is stil segfaulting in MPI_Comm_spawn in one process and returning an error from MPI_Barrier in the other. Error messages below: The MPI_Comm_spawn error: backtrace for error: backtrace after receiving signal SIGSEGV: /home/kmccall/Needles2/./NeedlesMpiMM() [0x45ab36] /lib64/libpthread.so.0(+0x12c20) [0x7f4833387c20] /lib64/libc.so.6(+0x15d6b7) [0x7f483310d6b7] /lib64/libc.so.6(__strdup+0x12) [0x7f4833039802] /lib64/libpmi2.so.0(+0x171c) [0x7f483294371c] /lib64/libpmi2.so.0(+0x185e) [0x7f483294385e] /lib64/libpmi2.so.0(PMI2_Job_Spawn+0x1a7) [0x7f48329453d8] /home/kmccall/mpich-slurm-install-4.0_2/lib/libmpi.so.12(+0x23a7db) [0x7f4834e0a7db] /home/kmccall/mpich-slurm-install-4.0_2/lib/libmpi.so.12(+0x1fc805) [0x7f4834dcc805] /home/kmccall/mpich-slurm-install-4.0_2/lib/libmpi.so.12(MPI_Comm_spawn+0x507) [0x7f4834cea9f7] The MPI_Barrier error: MPI_Barrier returned the error MPI runtime error: Unknown error class, error stack: internal_Barrier(84).......................: MPI_Barrier(MPI_COMM_WORLD) failed MPIR_Barrier_impl(91)......................: MPIR_Barrier_allcomm_auto(45)..............: MPIR_Barrier_intra_dissemination(39).......: MPIDI_CH3U_Complete_posted_with_error(1090): Process failed Thanks, Kurt -----Original Message----- From: Raffenetti, Ken <[email protected]> Sent: Friday, February 4, 2022 4:08 PM To: Mccall, Kurt E. (MSFC-EV41) <[email protected]>; [email protected] Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries :(. We need to link -lpmi2 instead of -lpmi. This really needs a patch in our configure script, but adding this to your configure is worth a shot: LIBS=-lpmi2 Ken On 2/4/22, 1:56 PM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]> wrote: I added the CFLAGS argument and the configuration completed, but make ended with a link error. lib/.libs/libmpi.so: undefined reference to `PMI2_Abort' lib/.libs/libmpi.so: undefined reference to `PMI2_Info_GetJobAttr' lib/.libs/libmpi.so: undefined reference to `PMI2_Job_Spawn' lib/.libs/libmpi.so: undefined reference to `PMI2_Nameserv_publish' lib/.libs/libmpi.so: undefined reference to `PMI2_Finalize' lib/.libs/libmpi.so: undefined reference to `PMI2_KVS_Put' lib/.libs/libmpi.so: undefined reference to `PMI2_Info_GetNodeAttr' lib/.libs/libmpi.so: undefined reference to `PMI2_KVS_Get' lib/.libs/libmpi.so: undefined reference to `PMI2_KVS_Fence' lib/.libs/libmpi.so: undefined reference to `PMI2_Nameserv_unpublish' lib/.libs/libmpi.so: undefined reference to `PMI2_Info_PutNodeAttr' lib/.libs/libmpi.so: undefined reference to `PMI2_Job_GetId' lib/.libs/libmpi.so: undefined reference to `PMI2_Init' lib/.libs/libmpi.so: undefined reference to `PMI2_Nameserv_lookup' collect2: error: ld returned 1 exit status -----Original Message----- From: Raffenetti, Ken <[email protected]> Sent: Friday, February 4, 2022 1:23 PM To: Mccall, Kurt E. (MSFC-EV41) <[email protected]>; [email protected] Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries I think I see a new issue. The Slurm website documentation says that their PMI library doesn't support PMI_Spawn_multiple from the PMI 1 API. We can try to force PMI 2 and see what happens. Try adding this to your configure line. CFLAGS=-DUSE_PMI2_API Ken On 2/4/22, 11:58 AM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]> wrote: Did that, and launched the job with "srun --mpi=none" and one of the processes failed when MPI_Comm_spawn was called. Note the : internal_Comm_spawn(101)......: MPI_Comm_spawn(command=NeedlesMpiMM, argv=0x226b030, maxprocs=1, info=0x9c000000, 0, MPI_COMM_SELF, intercomm=0x7ffffda9448c, array_of_errcodes=0x7ffffda94378) failed MPIDI_Comm_spawn_multiple(225): PMI_Spawn_multiple returned -1 The other process failed when MPI_Barrier was called: internal_Barrier(84).......................: MPI_Barrier(MPI_COMM_WORLD) failed MPIR_Barrier_impl(91)......................: MPIR_Barrier_allcomm_auto(45)..............: MPIR_Barrier_intra_dissemination(39).......: MPIDI_CH3U_Complete_posted_with_error(1090): Process failed MPI runtime error: Unknown error class, error stack: internal_Barrier(84).......................: MPI_Barrier(MPI_COMM_WORLD) failed MPIR_Barrier_impl(91)......................: MPIR_Barrier_allcomm_auto(45)..............: MPIR_Barrier_intra_dissemination(39).......: MPIDI_CH3U_Complete_posted_with_error(1090): Process failed MPI runtime error: Unknown error class, error stack: internal_Barrier(84).......................: MPI_Barrier(MPI_COMM_WORLD) failed MPIR_Barrier_impl(91)......................: MPIR_Barrier_allcomm_auto(45)..............: MPIR_Barrier_intra_dissemination(39).......: MPIDI_CH3U_Complete_posted_with_error(1090): Process failed MPI manager 1 threw exception: MPI runtime error: Unknown error class, error stack: internal_Barrier(84).......................: MPI_Barrier(MPI_COMM_WORLD) failed MPIR_Barrier_impl(91)......................: MPIR_Barrier_allcomm_auto(45)..............: MPIR_Barrier_intra_dissemination(39).......: MPIDI_CH3U_Complete_posted_with_error(1090): Process failed -----Original Message----- From: Raffenetti, Ken <[email protected]> Sent: Friday, February 4, 2022 11:42 AM To: Mccall, Kurt E. (MSFC-EV41) <[email protected]>; [email protected] Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries Yes, you should also use --with-pm=none. If using mpicc to build your application, you should not have to add -lpmi. The script will handle it for you. If using another method, you might have to add it. These days with shared libraries, linkers are often able to manage "inter-library" dependencies just fine. Static builds are a different story. Ken On 2/4/22, 11:35 AM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]> wrote: Ken, >> configure --with-slurm=/opt/slurm --with-pmi=slurm That is similar to your first suggestion below. With the above, do I have to include --with-pm=none? I guess I also have to link my application with -lpmi, right? Thanks, Kurt -----Original Message----- From: Raffenetti, Ken <[email protected]> Sent: Friday, February 4, 2022 11:02 AM To: Mccall, Kurt E. (MSFC-EV41) <[email protected]>; [email protected] Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries When running with srun you need to use the Slurm PMI library, not the embedded Simple PMI2 library. Simple PMI2 is API compatible, but uses a different wire protocol that the Slurm implementation. Try this instead: configure --with-slurm=/opt/slurm --with-pmi=slurm This will link the Slurm PMI library to MPICH. I do acknowledge how confusing this must be to users :). Probably a good FAQ topic for our Github discussions page. Ken On 2/3/22, 7:00 PM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]> wrote: Ken, I'm trying to build MPICH 4.0 in several ways, one of which will be what you suggested below. For this particular attempt suggested by the Slurm MPI guide, I built it with configure --with-slurm=/opt/slurm --with-pmi=pmi2/simple <etc> and invoked it with srun --mpi=pmi2 <etc> The job is crashing with this message. Any idea what is wrong? slurmstepd: error: mpi/pmi2: no value for key in req slurmstepd: error: mpi/pmi2: no value for key in req slurmstepd: error: mpi/pmi2: no value for key <99>èþ^? in req slurmstepd: error: mpi/pmi2: no value for key in req slurmstepd: error: mpi/pmi2: no value for key in req slurmstepd: error: mpi/pmi2: no value for key ´2¾ÿ^? in req slurmstepd: error: mpi/pmi2: no value for key ; in req slurmstepd: error: mpi/pmi2: no value for key in req slurmstepd: error: *** STEP 52227.0 ON n001 CANCELLED AT 2022-02-03T18:48:02 *** -----Original Message----- From: Raffenetti, Ken <[email protected]> Sent: Friday, January 28, 2022 3:15 PM To: Mccall, Kurt E. (MSFC-EV41) <[email protected]>; [email protected] Subject: [EXTERNAL] Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries On 1/28/22, 2:22 PM, "Mccall, Kurt E. (MSFC-EV41)" <[email protected]> wrote: Ken, I confirmed that MPI_Comm_spawn fails completely if I build MPICH without the PMI2 option. Dang, I thought that would work :(. Looking at the Slurm documentation https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fslurm.schedmd.com%2Fmpi_guide.html%23intel_mpiexec_hydra&data=04%7C01%7Ckurt.e.mccall%40nasa.gov%7C9249f74763f1428b909908d9e82adeef%7C7005d45845be48ae8140d43da96dd17b%7C0%7C0%7C637796093091225985%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=dcpAlSu4FLsL2o39rDH0t1jyzq4AYSOQlZXMReZmmJU%3D&reserved=0 it states "All MPI_comm_spawn work fine now going through hydra's PMI 1.1 interface." The full quote is below for reference. 1) how do I build MPICH to support hydra's PMI 1.1 interface? That is the default, so no extra configuration should be needed. One thing I notice in your log output is that the Slurm envvars seems to have changed name from what we have in our source. E.g. SLURM_JOB_NODELIST vs. SLURM_NODELIST. Do your initial processes launch on the right nodes? 2) Can you offer any guesses on how to build Slurm to do the same? (I realize this isn't a Slurm forum 😊) Hopefully you don't need to rebuild Slurm to do it. What you could try is configuring the Slurm PMI library when building MPICH. Add "--with-pm=none --with-pmi=slurm --with-slurm=<path/to/install>". Then use srun instead of mpiexec and see how it goes. Ken
participants (1)
Raffenetti, Ken
