Re: [mpich-discuss] Error: "MPIR_Get_contextid_sparse_group(1193): Too many communicators (0/2048)"
Memory limitations. With one large window all processes have to allocate memory for the objects they own as well as for objects assigned to other process. May be I need to assign all objects to one process with large memory. After the assembly is done, data will be scattered back for processing. Do you have other suggestions? Thanks, --Ted On 05/21/2014 05:42 PM, Balaji, Pavan wrote:
Creating so many communicators is not a good idea. Why can�t all processes open one large window?
� Pavan
On May 21, 2014, at 4:10 PM, Ted Sariyski <[email protected]> wrote:
I am working on a long-range interaction problem, so that communication is "each-to-each", although very sparse. My current approach is as follow: 1. If a process owns an object A, it opens a shared window to this object. 2. If another process happens to generate data which belongs to A, which is determined on the fly, it 'put' its share to A.
The algorithm works for small number of objects, but I need millions of them. I wonder: 1. Is it possible to increase the number of communicators above 2048? 2. Is it a scalable approach?
Again, although that communication is 'each-to-each', it is extremely sparse. Any advise and comments are highly appreciated.
Thanks in advance, --Ted
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Ted Sariyski Senior Research Scientist Combustion Research & Flow Technology, Inc. (CRAFT Tech) 6210 Keller's Church Road, Pipersville, PA 18947-1020 Voice: (215) 766-1520 x14; Fax: (215) 766-1524 http://www.craft-tech.com
participants (1)
Ted Sariyski
