fkomijani@fk1:~/program_install/COAWST$ mpif90 -v -o hello hello.F90 ./coawst.bash mpif90 for MPICH version 3.0.4 Driving: gfortran -v -o hello hello.F90 ./coawst.bash -I/home/fkomijani/program_install/mpich-3.0.4/include -I/home/fkomijani/program_install/mpich-3.0.4/include -L/home/fkomijani/program_install/mpich-3.0.4/lib -lmpichf90 -lmpich -lopa -lmpl -lrt -lpthread -l gfortran -l m -shared-libgcc gfortran: error: hello.F90: No such file or directory Using built-in specs. COLLECT_GCC=gfortran COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.6/lto-wrapper Target: i686-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.3-1ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --enable-targets=all --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu --target=i686-linux-gnu Thread model: posix gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) On Sat, Sep 13, 2014 at 4:33 PM, Junchao Zhang <[email protected]> wrote:
That is strange. Could you compile the following program with "mpif90 -v -o hello hello.F90" and paste the output?
! hello.F90 program main implicit none include 'mpif.h' integer :: ierr
call MPI_Init(ierr) call MPI_Finalize(ierr) end program
--Junchao Zhang
On Sat, Sep 13, 2014 at 6:24 AM, fereshteh komijani < [email protected]> wrote:
sorry that is my fault, it is mpif.h
it seems that COAWST model is searching it, in -I/user/include directory not in /home/fkomijani/program_install/mpich-3.0.4/include. so how can i set mentined directory in system environment?
On Sat, Sep 13, 2014 at 3:45 PM, Junchao Zhang <[email protected]> wrote:
The file name should be mpif.h, but not mpih.f. On Sep 13, 2014 1:45 AM, "fereshteh komijani" < [email protected]> wrote:
yes, /home/fkomijani/program_install/mpich-3.0.4/include contains mpih.f
On Sat, Sep 13, 2014 at 11:07 AM, Kenneth Raffenetti < [email protected]> wrote:
If you 'ls /home/fkomijani/program_install/mpich-3.0.4/include' does it contain an mpif.h file? If not, your MPICH installation might be bad.
On 09/13/2014 03:24 PM, fereshteh komijani wrote:
gfortran -I/home/fkomijani/program_install/mpich-3.0.4/include -I/home/fkomijani/program_install/mpich-3.0.4/include -L/home/fkomijani/program_install/mpich-3.0.4/lib -lmpichf90 -lmpich -lopa -lmpl -lrt -lpthread
On Sat, Sep 13, 2014 at 10:52 AM, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
What is the output from 'mpif90 -show'?
On 09/13/2014 03:19 PM, fereshteh komijani wrote:
dear Kenneth Raffenetti i am using mpif90 compiler. if it is, why i have got that error?
On Sat, Sep 13, 2014 at 10:47 AM, Kenneth Raffenetti <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote:
Are you using the mpif77 or mpif90 compiler wrappers to build your program? They will automatically add the location of mpif.h to your include path.
On 09/13/2014 02:56 PM, fereshteh komijani wrote:
Dear friends
recently I have installed mpich 3.0.4 in my system (Ubuntu).
After compiling my model (coawst) it gives me following error :
mod_parallel.f90:17: Error: Can't open included file 'mpif.h'
coaws's developer tell me :
*check your environment and see if the location of mpif.h is in your INCLUDE list*.
But I don't know what is its mean? Where and how I can do that? Does environment mean .bashrc?
many thanks for any reply
fereshteh
-- ***Angel*** *__*
___________________________________________________ discuss mailing list [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> To manage subscription options or unsubscribe: https://lists.mpich.org/____mailman/listinfo/discuss <https://lists.mpich.org/__mailman/listinfo/discuss> <https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>>
-- ***Angel*** *__*
_________________________________________________ discuss mailing list [email protected] <mailto: [email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
_________________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
-- ***Angel*** *__*
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- ***Angel***
-- ***Angel***
-- ***Angel***
participants (1)
fereshteh komijani
