Re: [mpich-discuss] Possible integer overflows at scale in gather.c
Rob, I agree, debugging these issues without the appropriate tools is close to impossible. Okay now that I'm allowed to speak more about let me elaborate :-D This started as a compiler analysis tool to catch problems before codes are tested at large scale or with large input sets. We see these problems again again and users spend a huge amount of time (sometimes months) debugging them. We are trying to see if the community has interest on these tools, and if so, we could potentially release them. Basically the analysis detects integer operations that depend on the scale/input size. For example, it detects if there are loops like this: for (i=0; i < SCALE; ++i) { ... } where SCALE can be a variable that comes from MPI_Comm_size or from the communicator size itself (e.g., in the case of gather.c), and if so it instruments the instructions there and save the resulting values. Then it runs the program at various small scales (e.g., 4, 8, 16) and then predicts if the operations will overflow say with 2^20 ranks. This is something you should be able to put in the mpich tests once we release it. The only things you need are: - Be able to compile mpich with clang (not a problem, I did it already) - Write a simple program that executes the MPI functions that you want to test. The more functions you test the better. I only tested the most used MPI functions, e.g., alltoall, gather, broadcast, etc. - A script that runs the test at multiple small scales, say mpirun -n4, -n8 and -n16. That's it. I would be happy to help you incorporate this in the mpich tests later. Thanks for your help! Ignacio PS: Now I'm moving to openmpi to see if I find bugs there ;-) On 10/1/15 2:13 PM, Rob Latham wrote:
On 10/01/2015 01:09 PM, Ignacio Laguna wrote:
I would be happy to continue the discussion too. It's just that since I'm new here I don't want to violate the rules (if there are). I know that non mpich topics should be discussed in stack-overflow and places like that. If there are more questions, just let me know.
I think the question we all have is "when can we add this to our git commit hooks?" -- debugging these problems without the aid of tooling is basically impossible.
==rob
Ignacio
On 10/1/15 10:50 AM, Jeff Hammond wrote:
I would be happy to see this discussion continue on the MPICH devel list even if it gets into LLVM weeds. Tools for ensuring count-safety are vital to MPICH and related efforts in the MPI community, and I think many of the people who are subscribed to [email protected] <mailto:[email protected]> would be interested in this topic. At the very least, they should tolerate it, since everyone on that list knows how to use email filters ;-)
Best,
Jeff
On Thu, Oct 1, 2015 at 10:35 AM, Ignacio Laguna <[email protected] <mailto:[email protected]>> wrote:
Rob,
Thanks for replying! I'm answering your questions inline below.
On 10/1/15 9:15 AM, Rob Latham wrote:
On 09/30/2015 04:08 PM, Ignacio Laguna wrote:
I found some 'potential' integer overflows when running mpich at large scale and/or with large inputs in gather.c. I believe that they are related to ticket #1767 (http://trac.mpich.org/projects/mpich/ticket/1767), but I didn't see any other bug reports about them so I thought I should confirm with mpich developers.
In addition to this case in line 171:
98 int tmp_buf_size, missing; ... 169 if (nbytes < MPIR_CVAR_GATHER_VSMALL_MSG_SIZE) tmp_buf_size++; 170 171 tmp_buf_size *= nbytes;
which I believe it's fixed in mpich-3.2b4 (where tmp_buf_size is declared as a 64-bit MPI_Aint),
I fixed this (I sure hope!) over the summer in commit 68f8c7aa798f7009
Yes, this is fixed (according to my analysis), so don't worry, I just used it as a reference.
I found the following cases in the same file src/mpi/coll/gather.c (in both mpich-3.1.4 and mpich-3.2b4):
Case 1:
222 mpi_errno = MPIC_Recv(((char *)recvbuf + 223 (((rank + mask) % comm_size)*recvcount*extent)), 224 recvblks * recvcount, recvtype, src, 225 MPIR_GATHER_TAG, comm, 226 &status, errflag);
In line 223 I believe we get an integer overflow as follows. Suppose I run 2^20 = 1,048,576 ranks and do a gather with 4,096 elements. In this case (if I understand the algorithm well), ((rank + mask) % comm_size) would be 2^20 / 2 = 524,288, and recvcount = 4,096. Then the ((rank + mask) % comm_size)*recvcount expression would overflow: 524,288 * 4,096 = 2,147,483,648, and become negative.
We're doing address math here, so I hope the compiler is not trying to store intermediate results in an integer. However, if LLVM is saying otherwise, then sure, let's promote those types.
((rank + mask) % comm_size)*recvcount is of type int*int, which is then multiplied by an MPI_Aint... yeah, looks suspicious.
Even when they are intermediate operations, the compiler could place the result of ((rank + mask) % comm_size)*recvcount in an 32-bit integer register. In fact, in llvm with -O0 optimization level that's what it does. This is the portion of the code in llvm IR:
%mul220 = mul nsw i32 %rem219.pre, %recvcount %conv221 = sext i32 %mul220 to i64 %mul222 = mul nsw i64 %conv221, %extent.1851 %add.ptr223 = getelementptr inbounds i8* %recvbuf, i64 %mul222
In the first line it multiplies the result of ((rank + mask) % comm_size) with recvcount. Note that this is a 32-bit multiplication (it says i32). Then in the 2nd line it extends the result to a 64-bit register (unfortunately at this point %mul220 is already wrapped around) and stores it in %conv221. Then it multiplies it by %extent, and then gets an element of the array (with getelementptr).
I'm not sure if this would be a problem with higher optimization levels, though, but we should not rely on that.
I also verified these things are propagated to actual machine registers by looking at the assembly code. Here's an example:
$ cat test.c #include <stdio.h> int main() { int val1, val2; long long tmp, final; val1 = (1 << 20) / 2; val2 = 4096; tmp = 4; final = val1 * val2 * tmp; printf("val1: %d, val2: %d, final: %lld\n", val1, val2, final); return 0; }
I compiled it with clang and -O0 and this is what I get when I run it:
$ ./test val1: 524288, val2: 4096, final: -8589934592
This is the assembly code in my Mac:
$ otool -vVt test test: (__TEXT,__text) section _main: 0000000100000f00 pushq %rbp 0000000100000f01 movq %rsp, %rbp 0000000100000f04 subq $0x30, %rsp 0000000100000f08 leaq 0x6f(%rip), %rdi 0000000100000f0f movl $0x0, -0x4(%rbp) 0000000100000f16 movl $0x80000, -0x8(%rbp) 0000000100000f1d movl $0x1000, -0xc(%rbp) 0000000100000f24 movq $0x4, -0x18(%rbp) 0000000100000f2c movl -0x8(%rbp), %eax 0000000100000f2f imull -0xc(%rbp), %eax 0000000100000f33 movslq %eax, %rcx 0000000100000f36 imulq -0x18(%rbp), %rcx
The first multiplication with imull is stored in %eax, and then second one in %rcx, but at this point %eax already has an overflow.
There are quite a few places where we do math on recvcount and recvblocks -- does your static analysis show problems with all of those spots?
I checked all MPI calls in mpich-3.2b4 and the analysis doesn't report anything else. Now, this doesn't mean there are no more bugs--just that it could not find anything else :-)
When multiplied with 'extent', which is size_t or MPI_Aint, it will become negative I believe or a huge positive which in any case will point to the wrong location in the recvbuf buffer, unless of course this wraparound behavior is intended.
Nope, wraparound sure is not intended! We would have no hope of cleaning up all these locations if it were not for clang's -Wshorten64-to-32 flag.
Thanks! I was just double checking. In some programs wraparounds are actually intended.
Case 2:
There might be a similar problem in line 224 in the above code. With 2^20 ranks, recvblks becomes 524,288 (again if I understand well the algorithm), so the recvblks * recvcount operation will also overflow.
I might be wrong on this -- I'm catching these issues with LLVM symbolic analysis -- so they can be totally false positives,
Tell me more about LLVM symbolic analysis! We have started using coverity for static analysis but yes, there are a lot of messages obscuring the genuine bugs.
I can tell you more in a separate email (I know this mailing list is only for mpich discussions).
Basically we are looking for scale-dependent bugs, i.e., bugs that will only manifest at large scale and/or with large inputs. It does data-flow analysis to understand what code is dependent on things like the size of the problem (in mpich and/or MPI apps this is basically code that depends on the size of the communicators, for example). It then performs tests to see if things could go wrong at large scale, e.g., by replacing ranks = 1 million values and so on. And then it reports what line of the code and file the problem is.
Having said that, coverity should find much more bugs. This is very specialized for scale-dependent bugs.
but I just wanted to check with the mpich developers if they are valid issues or not. If they are, I believe fixes can be easy to implement (just make all these computations size_t).
I promoted the prototype for MPIC_Recv to this:
int MPIC_Recv(void *buf, MPI_Aint count, MPI_Datatype datatype, int source, int tag, MPID_Comm *comm_ptr, MPI_Status *status, MPIR_Errflag_t *errflag)
Top-level MPI routines are stuck using an 'int' count, but internally we can (and now do) use a larger MPI_Aint type.
True, int*int can overflow, but since that parameter to MPIC_Recv is of the larger MPI_Aint type, we're ok here. LLVM disagrees?
Once you have a version I can download with the patches, I can run the analysis again and see if I can catch more things. Just let me know and I would be happy to test it.
In general, overflows can also occur in intermediate computations, depending on how code is optimized, I believe.
Thanks!
Ignacio
==rob
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/
discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Ignacio Laguna
