Re: [mpich-discuss] Questions about MPICH multi-thread support
Question 1. I am aware of the message envelope tuples (source, destination, tag, communicator) that may be used to identify and filter different messages. While using MPICH, can I rely on such information in order to guarantee that the correct messages will reach/be matched with their destinations in a multiprocess multithreaded program?
Yes, you can rely on the correctness of MPI implementation. That is, if your `rank, tag, communicator` matches the messages correctly to your intention, then you can trust that a correct implementation will do that even in a multi-threaded setting. The care need be taken that when your `rank, tag, ,communicator` doesn’t uniquely match, and if you send or receive in different threads, the order of matching is not certain, and it may surprise you. But that is just the perils of concurrent programming.
Question 2. Is there a problem when mixing blocking and non-blocking calls on opposite sides of a message? Even in the multithreaded scenarios described previously? (e.g. matching a MPI_Isend with a MPI_Recv, and vice-versa.)
No, there is no problem in that. -- Hui Zhou From: Guilherme Valarini via discuss <[email protected]> Date: Tuesday, January 26, 2021 at 3:24 PM To: [email protected] <[email protected]> Cc: Guilherme Valarini <[email protected]> Subject: [mpich-discuss] Questions about MPICH multi-thread support Dear MPICH community, I am currently developing an event system built upon MPI and I have a few questions about the current state of multi-thread support from MPICH in the MPI_THREAD_MULTIPLE mode. Question 1. I am aware of the message envelope tuples (source, destination, tag, communicator) that may be used to identify and filter different messages. While using MPICH, can I rely on such information in order to guarantee that the correct messages will reach/be matched with their destinations in a multiprocess multithreaded program? I know this is quite a broad question, but I am more interested in the analysis of the following scenarios. * Two threads in a process A want to send different messages to two different processes, B and C (each with one thread), while using the same communicator and tag. Code example: // One process with N threads to N process with one thread (same tag) if (rank == 0) { std::thread t1([&]() { // Generate data ... MPI_Send(data, 1, MPI_CHAR, 1, 0, MPI_COMM_WORLD); }); std::thread t2([&]() { // Generate data ... MPI_Send(data, 1, MPI_CHAR, 2, 0, MPI_COMM_WORLD); }); t1.join(); t2.join(); } else { MPI_Recv(data, 1, MPI_CHAR, 0, 0, MPI_COMM_WORLD, MPI_STATUS_IGNORE); } * The same scenario as above, but now each thread uses a different tag to communicate to their respective process while only sharing the same communicator. Code example: // One process with N threads to N process with one thread (different tags) if (rank == 0) { std::thread t1([&]() { // Generate data ... MPI_Send(data, 1, MPI_CHAR, 1, 1, MPI_COMM_WORLD); }); std::thread t2([&]() { // Generate data ... MPI_Send(data, 1, MPI_CHAR, 2, 2, MPI_COMM_WORLD); }); t1.join(); t2.join(); } else { MPI_Recv(data, 1, MPI_CHAR, 0, rank, MPI_COMM_WORLD, MPI_STATUS_IGNORE); } * Multiple threads from a process A want each to send a message to the same thread of another process B using the same communicator and tag. Code example: // One process with N threads to one process with one thread (same tags) if (rank == 0) { std::thread t1([&]() { // Generate data ... MPI_Send(data, 1, MPI_CHAR, 1, 0, MPI_COMM_WORLD); }); std::thread t2([&]() { // Generate data ... MPI_Send(data, 1, MPI_CHAR, 1, 0, MPI_COMM_WORLD); }); t1.join(); t2.join(); } else if (rank == 1) { MPI_Recv(data, 1, MPI_CHAR, 0, 0, MPI_COMM_WORLD, MPI_STATUS_IGNORE); // Process data ... MPI_Recv(data, 1, MPI_CHAR, 0, 0, MPI_COMM_WORLD, MPI_STATUS_IGNORE); // Process data ... } * One thread from a process A wants to send a message to one of multiple threads from a process B using the same communicator and tag. Code example: // One process with one thread to one process with N threads (same tags) if (rank == 0) { MPI_Request requests[2]; // Generate data ... MPI_Isend(data, 1, MPI_CHAR, 1, 0, MPI_COMM_WORLD, &requests[0]); // Generate data ... MPI_Isend(data, 1, MPI_CHAR, 1, 0, MPI_COMM_WORLD, &requests[1]); MPI_Waitall(2, requests, MPI_STATUSES_IGNORE); } else if (rank == 1) { std::thread t1([&]() { MPI_Recv(data, 1, MPI_CHAR, 0, 0, MPI_COMM_WORLD, MPI_STATUS_IGNORE); // Process data ... }); std::thread t2([&]() { MPI_Recv(data, 1, MPI_CHAR, 0, 0, MPI_COMM_WORLD, MPI_STATUS_IGNORE); // Process data ... }); t1.join(); t2.join(); } * Two threads from a process A want each to send a message to two threads from a process B using different tags for each pair of threads (e.g. the pair A.1/B.1 uses a different tag from pair A.2/B.2). Code example: // One process with N threads to one process with N thread (different tags) if (rank == 0) { std::thread t1([&]() { // Generate data ... MPI_Send(data, 1, MPI_CHAR, 1, 1, MPI_COMM_WORLD); }); std::thread t2([&]() { // Generate data ... MPI_Send(data, 1, MPI_CHAR, 1, 2, MPI_COMM_WORLD); }); t1.join(); t2.join(); } else if (rank == 1) { std::thread t1([&]() { MPI_Recv(data, 1, MPI_CHAR, 0, 1, MPI_COMM_WORLD, MPI_STATUS_IGNORE); // Process data ... }); std::thread t2([&]() { MPI_Recv(data, 1, MPI_CHAR, 0, 2, MPI_COMM_WORLD, MPI_STATUS_IGNORE); // Process data ... }); t1.join(); t2.join(); } Question 2. Is there a problem when mixing blocking and non-blocking calls on opposite sides of a message? Even in the multithreaded scenarios described previously? (e.g. matching a MPI_Isend with a MPI_Recv, and vice-versa.) Thank you. Regards, Guilherme Valarini
participants (1)
Zhou, Hui
