Re: [mpich-discuss] any clue on this mpiio error
On 02/10/2016 11:39 AM, Jaln wrote: My jobs on Edison die on IO errors like this:
ADIOI_CRAY_WRITECONTIG(284): filename='OUT/rei20_0.g029' error='Input/output error' errno=5 PE=00044 W_rec=33518 off=2232920756 len=0000524288 See MPICH_MPIIO_ABORT_ON_RW_ERROR.
Any Ideas about this error infor? I couldn't find anything on Google. Thanks
On Wed, Feb 10, 2016 at 9:46 AM, Rob Latham <[email protected]> wrote:
Cray doesn't share their modifications to ROMIO with us. You'll have more luck with your cray support contact.
errno 5 might be indicative of a general I/O error of some kind. Your offset is just large enough that maybe you are hitting some kind of cray 32 bit limitation?
but I'm only guessing as cray doesn't share source with us.
==rob
Hi Jaln, This message means that Cray's MPIIO had just made a system write() call and write() returned a status of -1. The MPIIO routine that made the call, "ADIOI_CRAY_WriteContig", is giving you as much information as it can. "errno" has a value of 5, which translates to the general I/O error message "Input/output error". That doesn't really tell you much. The message recommends that you look at MPICH_MPIIO_ABORT_ON_RW_ERROR in the Cray MPI "intro_mpi" man page: MPICH_MPIIO_ABORT_ON_RW_ERROR If set to enable, causes MPI-IO to abort immediately after issuing an error message if an I/O error occurs during a system read() or write() call. This applies only to I/O errors for system read() and write() calls made as a result of MPI I/O calls. It does not apply to I/O errors for other MPI I/O calls such as MPI_File_open(), nor does it apply to read() and write() calls made by means other than MPI I/O calls. Abort on error is not standard behavior. The MPI Standard specifies that the default error handling for MPI I/O calls is to return an error code to the application rather than aborting the application, but since errors on write or read are almost always unexpected and usually not recoverable, it may be preferable to abort as soon as the error is detected. Doing so does not allow any recovery, but does provide the most information about the error and terminates the job quickly. If the Cray Abnormal Termination Processing (ATP) feature is enabled, the abort will result in a full stack backtrace written to stderr and a graphical merged stack backtrace tree (a "dot" file) that shows exactly where each process was at the time of the abort. This environment variable is global for all files opened by MPI_File_open(). To enable this behavior only for specific files, use the MPICH_MPIIO_HINTS abort_on_rw_error option. Default: disable If this problem is repeatable and if you enable ATP (see man atp), set the environment variable and see what the backtrace tells you. You can contact me directly ([email protected]). David Knaak _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
David Knaak
