Re: [mpich-discuss] Usage of MPICH_PORT_RANGE has no impact
Ok, the solution is listed here: https://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_How_do_... <https://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_How_do_I_control_which_ports_MPICH_uses.3F> I thought i could configure that ports with -env.
Am 18.09.2015 um 11:03 schrieb Mark Bonnekessel <[email protected]>:
we want to setup a mpi-cluster with raspberry pis. The mpi-process run in a docker-container. That’s why we need to configure the ports, that mpi uses.
We found the env flag MPI_PORT_RANGE / MPIEXEC_PORT_RANGE to configure the port range, that is used by mpi. Our problem is, that this flag has no impact to the running mpi-process:
root@pi1:/mnt/docker# mpiexec -f machines -env MPIEXC_PORT_RANGE 10000:10100 -n 2 ./mpi-hello [proxy:0:1@pi2] HYDU_sock_connect (utils/sock/sock.c:172): unable to connect from "pi2" to "pi1" (Connection refused) [proxy:0:1@pi2] main (pm/pmiserv/pmip.c:189): unable to connect to server pi1 at port 35994 (check for firewalls!)
We tried every other combination of mpirun/mipexec and MPICH_PORT_RANGE/ MPIEXEC_PORT_RANGE.
Is there any other configuration needed or something, that we are missing to specify the used ports for mpi?
Regards, Mark _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Mark Bonnekessel
