Re: [mpich-discuss] Problems with MPI and virtual functions in C++
* Hélvio Vairinhos <[email protected]> [2012-12-12 20:00:28]:
Thanks for your suggestion, Dries! It works if I use &p.elem[0] as the initial address (not &p->elem), and only if I make elem public.I guess that's a price to pay (well, I can always fetch the address with a getter).
Do you know what happens to the memory layout in the presence of virtual functions if I have multiple components? For example:
double a,b;
instead of:
double elem[2];
When you have virtual functions (in fact, according to the <C++98 standard, as soon as you have non-trivial constructor/destructor), you can no longer reason about the memory layout of the struct/class. They are no longer PODs (plain old datatype).
Is it safe to assume that &p.a would give the initial address of a contiguous structure? Or should I play safe and use MPI_Pack and MPI_Unpack, for example?
Even for a 'contiguous' structure (such as POD struct) the compiler is allowed to insert padding for alignment reasons. The difference with non-POD is that you are allowed to copy those bytes as well to another instance and expect everything to work. (i.e. memcpy (&a, &b, sizeof(a)) is allowed for POD). Really, this is a larger topic. If I'm not mistaken, there is some discussion of this in the MPI standard, even though at this point, your question is more a C/C++ question than an MPI question. To give you at least some practical advice: POD types will generally work as expected. But I would strongly recommend against making similar assumptions for non-POD types (i.e. types having public/protect/private modifiers, non-trivial constructors/destructors, and especially virtual functions). Dries
participants (1)
Dries Kimpe
