Re: [mpich-discuss] MPE running problem
That works! I installed the MPICH2 1.5rc3 and now the MPE works nice. If someone knows how to fix this problem and use mpe with MPICH3 please help, but I believe that MPICH2 is enough for me. Thanks Fatemeh, Mikhael Chrum UTFPR - Toledo, Brasil
I have used the version of MPICH that comes with MPE. also, I found the lecture from rice university useful. The one that installs it by an script. http://www.caam.rice.edu/~timwar/Concertina/caam520menu.html
Hope you find it useful. Fatemeh
On Mon, Mar 2, 2015 at 9:00 PM, Mikhael C <[email protected]> wrote:
Hello,
I'm having some trouble trying to generate log files with MPE.
I've installed MPICH with the following command: ./configure --prefix=/usr/local/mpich 2>&1 | tee c.txt
And then the MPE: ./configure --with-mpich=--prefix=/usr/local/mpich \ --with-mpichdev=/usr/local/mpich/lib \ --prefix=/usr/local/mpich \ --with-mpicc=/usr/local/mpich/bin/mpicc \ --disable-f77
MPICH goes fine, but when i try to compile with mpecc i get this message:
$mpecc -mpilog -o monte_carlo_pi_2.o monte_carlo_pi_2.c /usr/bin/ld: library not found for -llmpe collect2: error: ld returned 1 exit status
The equivalent expression gives the same error: $ mpicc -o monte_carlo_pi_2.o monte_carlo_pi_2.c -L/usr/local/mpich/lib -llmpe -lmpe
Can someone help me?
Thank You, Mikhael Chrum UTFPR - Toledo, Brasil
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Mikhael C
