troubles with 3.3.2 and libslurm
Hi, I have version 3.2 running smoothly. Now I want to upgrade to vers 3.3.2, but I get a problem that the libslurm.so is required by the mpiexec in v3.3.2. This is a pitty since I don't have that on the compute nodes (and I don't use slurm). In vers3.2 this was not a problem. I use the same compiler suite and the same configure arguments for both versions (except prefix path, of course).
From ldd on the mpiexec from v3.3.2 I get:
libslurm.so.29 => /usr/lib64/libslurm.so.29 (0x00007fc91ebf8000) which will eventually lead to runtime errors when running across nodes that don't have it. As said, vers3.2 doesn't have the slurm lib path burned into the mpiexec (and I don't need it). How do I get rid of the libslurm in mpiexec? Which combination of configure args should I use? I have tried a tons of different args, but without success. Please, help. Regards, Per
participants (1)
Per Berg
