Re: [mpich-discuss] Problems with "make check" in romio building MPICH-4.2.3
I see! It is the * in "rm -f ${FILENAME}*" causing the issue. We should either remove the "*" or rename "test_hintfile". Sorry for being dense. 🙂 Hui ________________________________ From: Edric Ellis via discuss <[email protected]> Sent: Monday, December 23, 2024 1:46 AM To: [email protected] <[email protected]> Cc: Edric Ellis <[email protected]> Subject: Re: [mpich-discuss] Problems with "make check" in romio building MPICH-4.2.3 Yes, runtests deletes the file! As mentioned below, the runtests scripts states “FILENAME=test”, and then at various stages, runtests executes “rm -f ${FILENAME}*” Cheers, Edric. From: Zhou, Hui <zhouh@ anl. gov> Sent: 17 December 2024 16: 11 ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Yes, runtests deletes the file! As mentioned below, the runtests scripts states “FILENAME=test”, and then at various stages, runtests executes “rm -f ${FILENAME}*” Cheers, Edric. From: Zhou, Hui <[email protected]> Sent: 17 December 2024 16:11 To: Edric Ellis <[email protected]>; [email protected] Subject: Re: Problems with "make check" in romio building MPICH-4.2.3 Hi Edric, Thanks for the test log. The test-suite.log is complaining "test_hintfile" not exist. This is not a temporary file created during testing, but part of the static test files. Something is causing the tests not able to open "/mathworks/devel/sandbox/eellis/3p-mpich-4.2.3/3p/derived/glnxa64/mpich/src/mpi/romio/test/test_hintfile". Any clues? Hui ________________________________ From: Edric Ellis <[email protected]<mailto:[email protected]>> Sent: Tuesday, December 17, 2024 9:49 AM To: Zhou, Hui <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: RE: Problems with "make check" in romio building MPICH-4.2.3 I see this: make[2]: Entering directory '/mathworks/devel/sandbox/eellis/3p-mpich-4. 2. 3/3p/derived/glnxa64/mpich/src/mpi/romio/test' FAIL: runtests ============================================================================ Testsuite summary ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd I see this: make[2]: Entering directory '/mathworks/devel/sandbox/eellis/3p-mpich-4.2.3/3p/derived/glnxa64/mpich/src/mpi/romio/test' FAIL: runtests ============================================================================ Testsuite summary for ROMIO 4.2.3 ============================================================================ # TOTAL: 1 # PASS: 0 # SKIP: 0 # XFAIL: 0 # FAIL: 1 # XPASS: 0 # ERROR: 0 ============================================================================ See test/test-suite.log Please report to [email protected]<mailto:[email protected]> ============================================================================ make[2]: *** [Makefile:1167: test-suite.log] Error 1 and the test-suite.log has this: **** Testing syshints **** MPI_File_open(MPI_COMM_WORLD, argv[1], MPI_MODE_RDONLY, info_mine, &fh): File does not exist, error stack: ADIOI_NFS_OPEN(37): File /mathworks/devel/sandbox/eellis/3p-mpich-4.2.3/3p/derived/glnxa64/mpich/src/mpi/romio/test/test_hintfile does not exist Abort(1) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 FAIL runtests (exit status: 1) The file test_hintfile did exist before running the tests. Cheers, Edric. From: Zhou, Hui <[email protected]<mailto:[email protected]>> Sent: 13 December 2024 16:04 To: [email protected]<mailto:[email protected]> Cc: Edric Ellis <[email protected]<mailto:[email protected]>> Subject: Re: Problems with "make check" in romio building MPICH-4.2.3 Hi Edric, Could you show the relevant console log for the failure? Hui ________________________________ From: Edric Ellis via discuss <[email protected]<mailto:[email protected]>> Sent: Friday, December 13, 2024 2:59 AM To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Cc: Edric Ellis <[email protected]<mailto:[email protected]>> Subject: [mpich-discuss] Problems with "make check" in romio building MPICH-4.2.3 Hi mpich-discuss, "make check" is failing with mpich-4. 2. 3, in the src/mpi/romio/test subdirectory. I think it's because this file: https: //urldefense. us/v3/__https: //github. com/pmodels/mpich/blob/4. 2. x/src/mpi/romio/test/runtests. in__;!!G_uCfscf7eWS!c86jBfO2_nn7840CXToEK-Dl8-y3_afw3ARA6rXELHbuMyXHtcqIGwBNDcw6oUUN8brlyugyCb5NBiY$ ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Hi mpich-discuss, "make check" is failing with mpich-4.2.3, in the src/mpi/romio/test subdirectory. I think it's because this file: https://urldefense.us/v3/__https://github.com/pmodels/mpich/blob/4.2.x/src/m... still says "FILENAME=test" on line 25. (The test fails because "FILENAME=test" eventually causes "test_hintfile" to be delete before it's needed by one of the tests). There's a change over here: https://urldefense.us/v3/__https://github.com/pmodels/mpich/commit/90b0b0614... to make it say "FILENAME=", which I think would fix things. I'm not sufficiently familiar with github to fathom how that change didn't make it in to 4.2.3 when this change to the Makefile https://urldefense.us/v3/__https://github.com/pmodels/mpich/commit/6e1e892a0... (which effectively makes top-level "make check" enter the romio/test subdirectory) did make it in to 4.2.3... Cheers, Edric.
participants (1)
Zhou, Hui
