Re: [mpich-discuss] MPI_Finalize hangs in dynamic connection in case of failed process
First, I believe the sock device is untested with most of the MPICH fault tolerance features, so YMMV here. Is there a reason that you aren’t calling MPI_Disconnect for the failed process? Did you try it an something bad happened? That seems like the most straightforward way of doing things. Otherwise, this sounds like a known issue that we’re seeing from time to time with MPI_Finalize and the FT work. It’s something I’m trying to figure out now. If you can reduce your code down to the minimum and send it to me, I can use it as a test case to try to fix the problem. Thanks, Wesley
On Feb 19, 2015, at 5:15 AM, Roy, Hirak <[email protected]> wrote:
Hi All,
I am using MPICH with sock connection. I also setup processes using dynamic connection method (MPI_Comm_connect/MPI_Comm_accept). It’s a master-slave architecture where master accepts the connections from slaves.
Now if one of the process dies (or get killed), I can still recover from this (without using checkpoint/restore method). For the particular process in master, I do not call MPI_disconnect (it hangs and does not complete). As a result, my MPI_Finalize in master hangs and does not complete. Do you have a workaround to forcefully complete MPI_Finalize or MPI_disconnect? I tried MPI_Comm_free on the failed connection. However, it does not solve the hang in finalize.
Thanks, Hirak _______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
