Re: [mpich-discuss] success and failure report for mpich-3.0.2
Adding [email protected] back to cc.
[proxy:0:1@linpc1] HYDU_create_process (../../../../mpich-3.0.2/src/pm/hydra/utils/launch/launch.c:74): execvp error on file date (No such file or directory)
This seems to indicate that "date" is not found on linpc1. Try giving the full path to "date". -- Pavan On 04/29/2013 02:40 AM US Central Time, Siegmar Gross wrote:
Hi
This is not an architectural problem. You need to have mpich installed on all machines. It looks like some of your machines don't have it installed.
It is installed on all machines, but sometimes I have a problem if I use different operating systems on the same hardware architecture. I use "date" to exclude any errors in my program. I get an error, if I try to start my processes from a Solaris machine and everything works well, if I do the same thing from my Linux machine, so that it is an architectural problem in my opinion. I have unsubscribed from the list in the meantime, because I didn't get any response. Perhaps you can reply to my address directly, if you want to send a response. I get the following results.
sunpc1 fd1026 105 which mpiexec /usr/local/mpich-3.0.2_64_cc/bin/mpiexec sunpc1 fd1026 106 ssh linpc1 which mpiexec /usr/local/mpich-3.0.2_64_cc/bin/mpiexec sunpc1 fd1026 107 mpiexec -np 2 -host sunpc0,sunpc1 date Mon Apr 29 09:26:34 CEST 2013 Mon Apr 29 09:26:35 CEST 2013 sunpc1 fd1026 108 mpiexec -np 2 -host linpc0,linpc1 date [proxy:0:1@linpc1] HYDU_create_process (../../../../mpich-3.0.2/src/pm/hydra/utils/launch/launch.c:74): execvp error on file date (No such file or directory)
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 255 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== [proxy:0:0@linpc0] HYDU_create_process (../../../../mpich-3.0.2/src/pm/hydra/utils/launch/launch.c:74): execvp error on file date (No such file or directory)
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 255 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== sunpc1 fd1026 109 ssh linpc1 linpc1 fd1026 101 mpiexec -np 2 -host linpc0,linpc1 date Mon Apr 29 09:27:40 CEST 2013 Mon Apr 29 09:27:41 CEST 2013 linpc1 fd1026 102 mpiexec -np 2 -host sunpc0,sunpc1 date Mon Apr 29 09:27:49 CEST 2013 Mon Apr 29 09:27:49 CEST 2013 linpc1 fd1026 103 mpiexec -np 2 -host sunpc0,linpc0 date Mon Apr 29 09:30:55 CEST 2013 Mon Apr 29 09:30:56 CEST 2013 linpc1 fd1026 104 linpc1 fd1026 103
As you can see below, I wasn't able to build the packacke on some machines with GNU C or in 32-bit versions. Thank you very much for any answer in advance.
Kind regards
Siegmar
-- Pavan
On 03/22/2013 10:22 AM US Central Time, Siegmar Gross wrote:
Hi
today I tried to install mpich-3.0.2. I could compile and install the package for the following architectures.
openSuSE Linux 12.1, x86_64, Sun C 5.12, 64-bit Solaris 10, x86_64, Sun C 5.12, 64-bit Solaris 10, sparc, Sun C 5.12, 32-bit Solaris 10, sparc, Sun C 5.12, 64-bit
As described in the RELEASE_NOTES a communication between little-endian and big-endian machines is not possible (broken pipe). Unfortunately you don't even allow different operating systems (it seems that you don't evaluate PATH to find a program).
sunpc1 fd1026 103 mpiexec -np 2 -host sunpc0,sunpc1 init_finalize Hello! Hello!
sunpc1 fd1026 104 mpiexec -np 2 -host sunpc0,linpc1 init_finalize [proxy:0:1@linpc1] HYDU_create_process (../../../../mpich-3.0.2/src/pm/hydra/utils/launch/launch.c:74): execvp error on file init_finalize (No such file or directory)
======================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 255 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ======================================================================== [proxy:0:0@sunpc0] HYD_pmcd_pmip_control_cmd_cb (../../../../mpich-3.0.2/src/pm/hydra/pm/pmiserv/pmip_cb.c:886): assert (!closed) failed [proxy:0:0@sunpc0] HYDT_dmxu_poll_wait_for_event (../../../../mpich-3.0.2/src/pm/hydra/tools/demux/demux_poll.c:77): callback returned error status [proxy:0:0@sunpc0] main (../../../../mpich-3.0.2/src/pm/hydra/pm/pmiserv/pmip.c:206): demux engine error waiting for event
The programs are available on both machines.
sunpc1 fd1026 105 which init_finalize /home/fd1026/SunOS/x86_64/bin/init_finalize sunpc1 fd1026 106 ssh linpc1 which init_finalize /home/fd1026/Linux/x86_64/bin/init_finalize sunpc1 fd1026 107
I wasn't able to build the package on the following architectures.
openSuSE Linux 12.1, x86_64, Sun C 5.12, 32-bit openSuSE Linux 12.1, x86_64, GNU C 4.7.1, 32-bit ------------------------------------------------
tyr mpich-3.0.2-Linux.x86_64.32_cc 158 tail log.make.Linux.x86_64.32_cc CC mplstr.lo CC mpltrmem.lo CC mplenv.lo CCLD libmpl.la /usr/lib/libxml2.so: could not read symbols: File in wrong format make[2]: *** [libmpl.la] Error 2 make[2]: Leaving directory `.../src/mpl' make[1]: *** [all-recursive] Error 1
openSuSE Linux 12.1, x86_64, GNU C 4.7.1, 64-bit ------------------------------------------------
tyr mpich-3.0.2-Linux.x86_64.64_gcc 171 tail log.make.Linux.x86_64.64_gcc CC mpltrmem.lo CC mplenv.lo CCLD libmpl.la /usr/local/bin/ld: libmpl.so.1: No such file: No such file or directory collect2: error: ld returned 1 exit status make[2]: *** [libmpl.la] Error 1 make[2]: Leaving directory `.../src/mpl'
Solaris 10, x86_64, Sun C 5.12, 32-bit --------------------------------------
hangs
Solaris 10, x86_64, GNU C 4.7.1, 32-bit ---------------------------------------
tyr mpich-3.0.2-SunOS.x86_64.32_gcc 193 tail -12 log.make.SunOS.x86_64.32_gcc CC src/mpi/coll/barrier_group.lo CC src/mpi/coll/helper_fns.lo Assembler: helper_fns.c "/var/tmp//ccIdXgrh.s", line 912 : Syntax error Near line: "mov $PREFETCHBLOCK/16, %eax" "/var/tmp//ccIdXgrh.s", line 920 : Syntax error Near line: "mov $PREFETCHBLOCK/8, %eax" make[2]: *** [src/mpi/coll/helper_fns.lo] Error 1
Solaris 10, x86_64, GNU C 4.7.1, 64-bit Solaris 10, sparc, GNU C 4.7.1, 32-bit Solaris 10, sparc, GNU C 4.7.1, 64-bit ---------------------------------------
tyr mpich-3.0.2-SunOS.x86_64.64_gcc 195 tail log.make.SunOS.x86_64.64_gcc CXX src/binding/cxx/initcxx.lo CXXLD lib/libmpichcxx.la ld: fatal: file libmpichcxx.so.10: open failed: No such file or directory ld: fatal: file processing errors. No output written to lib/.libs/libmpichcxx.so.10.0.2 collect2: error: ld returned 1 exit status make[2]: *** [lib/libmpichcxx.la] Error 1
Kind regards
Siegmar
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
