Re: [mpich-discuss] Different architectures
It appears you're trying to use the 64b library (ELFCLASS64...) on the 32b master. In any case, I don't believe MPICH works in the heterogeneous case. In theory, you should be able to use a 32b library across both machines though. Jeff On Sun, Dec 9, 2012 at 1:40 PM, Peter Kroon <[email protected]> wrote:
Hello,
I've installed mpich2 on ubuntu i386(master) via https://help.ubuntu.com/community/MpichCluster I have another machine amd64(slave).
When i run my script on master I get an error: error while loading shared libraries: linbmpich.so.3: wrong ELF CLASS: ELFCLASS64
Is mpich compatible with different architectures? If so what's the easiest way for me to get rid of my error?
Also note that I need this to work with x86-64 as well.
Best, Peter
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
