Re: [mpich-discuss] Mpich won't compile with gcc-5
Yes, here. Thank you Jan On 18.02.2015 11:52, Balaji, Pavan wrote:
Can you send the config.log file?
-- Pavan
On Feb 18, 2015, at 4:28 AM, Jan Wittke <[email protected]> wrote:
Yes,
I only want to use gfortran-5.
Regards, Jan
On 18.02.2015 11:26, Balaji, Pavan wrote:
Are you using gfortran-5 as well? That seems to be giving an issue. If you don't need fortran, you can disable it by passing --disable-fortran to configure.
-- Pavan
On Feb 18, 2015, at 4:14 AM, Jan Wittke <[email protected]> wrote:
after installing gcc-5-20150208 from source with
/opt/gcc-5-20150208/configure --program-suffix=-5 --prefix=/usr/local --enable-languages=c,c++,fortran --disable-multilib
I am not able to run the mpich ./configure script properly. Doing:
CC=/usr/local/bin/gcc-5 FC=/usr/local/bin/gfortran-5 ./configure --enable-threads
in the mpich-3.2a2 directory I got the error:
configure: error: Unable to configure with Fortran support because configure could not determine the size of a Fortran INTEGER. Consider setting CROSS_F77_SIZEOF_INTEGER to the length in bytes of a Fortran INTEGER
Is there any fix around ?
Thank you, Jan
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jan Wittke
