Re: [mpich-discuss] Buffer corruption due to an excessive number of messages
If you run into the same issue with different MPI implementations, this actually sounds like an issue in the application. Either the sender overwrites the buffer between the isend and the wait, or the receiver side overwrites the receive buffer between the recv and your buffer verification. We are wrapping up a MUST release that tackles the detection of this kind of issues. You would need to compile your code with either LLVM or GNU compiler. If you are interested in the details, just let me know. - Joachim Am 15.09.23 um 17:00 schrieb Mccall, Kurt E. (MSFC-EV41) via discuss:
Yes, I tried it with OpenMPI and the same problem occurred.
Kurt
-----Original Message----- From: Thakur, Rajeev <[email protected]> Sent: Friday, September 15, 2023 9:59 AM To: [email protected] Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]> Subject: [EXTERNAL] [BULK] Re: [mpich-discuss] Buffer corruption due to an excessive number of messages
Does it happen with other MPI implementations?
Rajeev
-----Original Message----- From: "Mccall, Kurt E. (MSFC-EV41) via discuss" <[email protected] <mailto:[email protected]>> Reply-To: "[email protected] <mailto:[email protected]>" <[email protected] <mailto:[email protected]>> Date: Friday, September 15, 2023 at 9:43 AM To: "[email protected] <mailto:[email protected]>" <[email protected] <mailto:[email protected]>> Cc: "Mccall, Kurt E. (MSFC-EV41)" <[email protected] <mailto:[email protected]>> Subject: Re: [mpich-discuss] Buffer corruption due to an excessive number of messages
Joachim,
Unfortunately, using MPI_Improbe/MPI_Mrecv didn't solve the problem -- I still am receiving buffers with invalid data objects near the ends of the buffers. The problem goes away when I reduce the size of the job (number of nodes), making me think it is the large number of messages that is causing the problem.
1. Is there a way to detect this kind of overload with an MPI call? 2. Is there an upper bound on the number of messages that can be "in flight"? 3. Is there a upper bound on message length?
Or is there some other possible cause that I haven't thought of?
Thanks, Kurt
-----Original Message----- From: Joachim Jenke via discuss <[email protected] <mailto:[email protected]>> Sent: Thursday, September 14, 2023 3:10 PM To: [email protected] <mailto:[email protected]> Cc: Joachim Jenke <[email protected] <mailto:[email protected]>> Subject: [EXTERNAL] [BULK] Re: [mpich-discuss] Buffer corruption due to an excessive number of messages
CAUTION: This email originated from outside of NASA. Please take care when clicking links or opening attachments. Use the "Report Message" button to report suspicious messages to the NASA SOC.
Hi Kurt,
just a thought: do you execute single-threaded or multi-threaded?
In case of multi-threaded execution, you should look into MPI_Improbe/MPI_Mrecv just to make sure that you really receive the message you probed for. Even in single-threaded execution you might try whether using these functions instead fixes your issue.
Best Joachim
Am 14.09.23 um 22:02 schrieb Mccall, Kurt E. (MSFC-EV41) via discuss:
It seems that when I send a process too many non-blocking messages (with MPI_Isend) , MPI_Iprobe/MPI_Recv sometimes returns a buffer
with corrupted data for some of the messages. Usually the corrupted data objects are at the end of the array that was sent. I checked the
buffers passed to MPI_Isend, and they are uncorrupted.
Kurt
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://list/ s.mpich.org%2Fmailman%2Flistinfo%2Fdiscuss&data=05%7C01%7Ckurt.e.mccal l%40nasa.gov%7C9e8bfd71610243562ce808dbb55eaace%7C7005d45845be48ae8140 d43da96dd17b%7C0%7C0%7C638303190427564481%7CUnknown%7CTWFpbGZsb3d8eyJW IjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000% 7C%7C%7C&sdata=yplpEqPO1a8OpC2Nt3z55G2UtfA0lBqV4Zn5OrMRRx0%3D&reserved =0
-- Dr. rer. nat. Joachim Jenke
IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected] <mailto:[email protected]> http://www.itc.rwth-aachen.de/ <http://www.itc.rwth-aachen.de/>
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Dr. rer. nat. Joachim Jenke IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected] www.itc.rwth-aachen.de
participants (1)
Joachim Jenke
