Re: [mpich-discuss] Running mpi from bash script
Hi I've installed a new MPICH version but the problem persists. I looked at mpich.org download page, the version por Ubuntu 12.04 is mpich2-1.4.1 The problem still remains when running from batch. If I run my script from command line everything works fine, if I launch the job with at no processes appear on the cluster nodes and no output files are produced. In master node some processes appear: ps -ef | grep rams meteo 8288 7559 0 13:03 ? 00:00:00 time /usr/bin/mpirun -n 40 -f machinefile ./rams60 -f RAMSIN.operatiu meteo 8289 8288 0 13:03 ? 00:00:00 /usr/bin/mpirun -n 40 -f machinefile ./rams60 -f RAMSIN.operatiu meteo 8295 8290 0 13:03 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 8296 8290 0 13:03 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 8297 8290 0 13:03 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 8298 8290 0 13:03 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 8299 8290 0 13:03 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 8300 8290 0 13:03 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 8301 8290 0 13:03 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 8302 8290 0 13:03 ? 00:00:00 ./rams60 -f RAMSIN.operatiu Should I set some environment when launching the job? Thanks Paco El 17/04/2014 11:06, Reuti escribi�:
Am 17.04.2014 um 10:04 schrieb Francisco Pastor:
I need to daily run an mpi job from a bash script. I have prepared the script and run from the command line, this works fine. But when I try to execute at a later time with at (at -f my_script now +1 minute) the parallel processes do not start.
These are the significant parts of my script:
# path to mpi executables ruta_mpi=/usr/local/mpich2-1.0.5p4/bin This version of MPICH is quite old. Please use a more recent one, where the necessity for starting an MPD beforehand does no longer exist.
-- Reuti
# Function that checks if mpd processes are ok (checks mpdtrace output, five nodes should be up) Comprueba_MPD() { mpdtrace > log.mpd wc -l log.mpd > check.mpd check1=`awk '{ print $1 }' check.mpd` if [ $check1 -eq 5 ]; then echo "Salida de mpdtrace correcta, hosts=$check1" else echo "Salida de mpdtrace incorrecta, hosts=$check1" $ruta_mpi/mpdboot -n 5 & sleep 10 mpdtrace fi }
# Run rams60 program with mpirun time $ruta_mpi/mpirun -n 21 ./rams60 -f RAMSIN.operatiu
I am sure missing something but I can't find out what's going on.
Thanks in advance
-- ----------- Dr. Francisco Pastor Meteorology department, Instituto Universitario CEAM-UMH http://www.ceam.es ----------- Mendeley profile: http://www.mendeley.com/profiles/francisco-pastor1/ Google Scholar: http://scholar.google.com/citations?user=V3mmCdkAAAAJ&hl=es Researcher ID: http://www.researcherid.com/rid/B-8331-2008 Cosis profile: http://www.cosis.net/profile/francisco.pastor ----------- mail: [email protected] skype: paco.pastor.guzman ----------- Parque Tecnologico, C/ Charles R. Darwin, 14 46980 PATERNA (Valencia), Spain Tlf. 96 131 82 27 - Fax. 96 131 81 90
--------------------------------------------------------------------- Este mensaje y los ficheros anexos son confidenciales. Los mismos contienen informaci�n reservada de la empresa que no puede ser difundida. Si usted ha recibido este correo por error, tenga la amabilidad de eliminarlo de su sistema y avisar al remitente mediante reenv�o a su direcci�n electr�nica; no deber� copiar el mensaje ni divulgar su contenido a ninguna persona.
Su direcci�n de correo electr�nico junto a sus datos personales forman parte de un fichero titularidad de la Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213, cuya finalidad es la de mantener el contacto con Ud. De acuerdo con la Ley Org�nica 15/1999, usted puede ejercitar sus derechos de acceso, rectificaci�n, cancelaci�n y, en su caso, oposici�n enviando una solicitud por escrito, acompa�ada de una fotocopia de su DNI dirigida a: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
This message and the attached files are confidential. They contain reserved information belonging to our centre and are not to be broadcast. If you have received this email by mistake, please delete it from your system and alert the sender by returning it to his/her email address. You must not copy or divulge the contents of the message to anyone.
Your email address and personal data are included in a file belonging to the Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213. The purpose of this file is to allow us to keep in contact with you. In accordance with Organic Law 15/1999, you are permitted to access, rectify, cancel or oppose the contents of this file by submitting a written request, accompanied by a photocopy of your DNI, to: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- ----------- Dr. Francisco Pastor Meteorology department, Instituto Universitario CEAM-UMH http://www.ceam.es ----------- Mendeley profile: http://www.mendeley.com/profiles/francisco-pastor1/ Google Scholar: http://scholar.google.com/citations?user=V3mmCdkAAAAJ&hl=es Researcher ID: http://www.researcherid.com/rid/B-8331-2008 Cosis profile: http://www.cosis.net/profile/francisco.pastor ----------- mail: [email protected] skype: paco.pastor.guzman ----------- Parque Tecnologico, C/ Charles R. Darwin, 14 46980 PATERNA (Valencia), Spain Tlf. 96 131 82 27 - Fax. 96 131 81 90 --------------------------------------------------------------------- Este mensaje y los ficheros anexos son confidenciales. Los mismos contienen informaci�n reservada de la empresa que no puede ser difundida. Si usted ha recibido este correo por error, tenga la amabilidad de eliminarlo de su sistema y avisar al remitente mediante reenv�o a su direcci�n electr�nica; no deber� copiar el mensaje ni divulgar su contenido a ninguna persona. Su direcci�n de correo electr�nico junto a sus datos personales forman parte de un fichero titularidad de la Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213, cuya finalidad es la de mantener el contacto con Ud. De acuerdo con la Ley Org�nica 15/1999, usted puede ejercitar sus derechos de acceso, rectificaci�n, cancelaci�n y, en su caso, oposici�n enviando una solicitud por escrito, acompa�ada de una fotocopia de su DNI dirigida a: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia). This message and the attached files are confidential. They contain reserved information belonging to our centre and are not to be broadcast. If you have received this email by mistake, please delete it from your system and alert the sender by returning it to his/her email address. You must not copy or divulge the contents of the message to anyone. Your email address and personal data are included in a file belonging to the Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213. The purpose of this file is to allow us to keep in contact with you. In accordance with Organic Law 15/1999, you are permitted to access, rectify, cancel or oppose the contents of this file by submitting a written request, accompanied by a photocopy of your DNI, to: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
participants (1)
Francisco Pastor
