Re: [mpich-discuss] mpich-3.1 (stable release): make error.
Dear Rajeev, Now "All 814 tests passed!" In the present case, since I was also doing an installation in a second cluster, I realized that there might be an inconsistency in the values of environment variables among server and nodes. Then, I go back to the first cluster, where the installation was carried out as root, and noticed that, in particular, the LD_LIBRARY_PATH values were different among server and nodes. Then, I made the configure (with all options) and make steps as an end user, with a consistent environment among server and nodes, and the "unknown size for unsigned int." error vanished. I attached the relevant files of the last successful installation. Thanks for your time and the links. Regards, Jorge. ----- Mensaje original -----
De: "Rajeev Thakur" <[email protected]> Para: [email protected] Enviado: Domingo, 23 de Marzo 2014 13:26:10 Asunto: Re: [mpich-discuss] mpich-3.1 (stable release): make error.
There have been a few sporadic reports of the same error, but I don't know what the resolution was.
https://www.google.com/search?q=error:+%23error+%22unknown+size+for+unsigned...
Rajeev
On Mar 23, 2014, at 7:04 AM, Jorge D'Elia <[email protected]> wrote:
Here I send the files obtained using only the prefix option (c.txt, m.txt and config.log).
Regards, Jorge.
De: "Rajeev Thakur" <[email protected]> Para: [email protected] CC: [email protected] Enviado: Sábado, 22 de Marzo 2014 23:46:25 Asunto: Re: [mpich-discuss] mpich-3.1 (stable release): make error.
Can you try configuring with just the --prefix option.
Rajeev
On Mar 22, 2014, at 12:01 PM, Jorge D'Elia <[email protected]> wrote:
I tried to install mpich-3.1 (stable release) but I find an error in the build step. I attached the files c.txt (configure step) and m.txt (make step with the VERBOSE=1 value). Please, any clue? Thanks in advance. Regards. Jorge.
CIMEC (UNL-CONICET) Predio CONICET-Santa Fe, Colectora Ruta Nac 168, Paraje El Pozo, S3000GLN Santa Fe, ARGENTINA, http://www.cimec.org.ar/ Tel +54 342 451.15.94/95 ext 1018, fax: +54-342-451.11.69 txt>txt>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <only-prefix.tgz>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jorge D'Elia
