Code works with -ppn, fails without using MPICH 3.2
All, I've been evaluating different MPI stacks on our cluster and found that MPICH 3.2 does really well on some simple little benchmarks. It also runs Hello World just fine, so I decided to apply it to our climate model (GEOS). However, the first time I did that, things went a bit nuts. Essentially:
(1065) $ mpirun -np 96 ./GEOSgcm.x | & tee withoutppn.log srun.slurm: cluster configuration lacks support for cpu binding Fatal error in PMPI_Comm_create: Unknown error class, error stack: PMPI_Comm_create(564).................: MPI_Comm_create(MPI_COMM_WORLD, group=0x88000000, new_comm=0x106d1740) failed PMPI_Comm_create(541).................: MPIR_Comm_create_intra(215)...........: MPIR_Get_contextid_sparse_group(500)..: MPIR_Allreduce_impl(764)..............: MPIR_Allreduce_intra(257).............: allreduce_intra_or_coll_fn(163).......: MPIR_Allreduce_intra(417).............: MPIDU_Complete_posted_with_error(1137): Process failed MPIR_Allreduce_intra(417).............: MPIDU_Complete_posted_with_error(1137): Process failed MPIR_Allreduce_intra(268).............: MPIR_Bcast_impl(1452).................: MPIR_Bcast(1476)......................: MPIR_Bcast_intra(1287)................: MPIR_Bcast_binomial(310)..............: Failure during collective
(NOTE: The srun.slurm thing is just an error/warning we always get. Doesn't matter if it's MPT, Open MPI, MVAPICH2, Intel MPI...it happens.) The thing is, it works just fine at (NX-by-NY) of 1x6 and 2x12, but once I go to 3x18, boom, collapse. As I am on 28-core nodes, my first thought was it was due to crossing nodes. But, those benchmarks I ran did just fine for 192 nodes, so...hmm. Out of desperation, I finally thought, what if it was the fact that 28 doesn't divide 96 and passed in -ppn and:
(1068) $ mpirun -ppn 12 -np 96 ./GEOSgcm.x |& tee withppn.log srun.slurm: cluster configuration lacks support for cpu binding
In MAPL_Shmem: NumCores per Node = 12 NumNodes in use = 8 Total PEs = 96 ...
Starts up just fine! Note that every other MPI stack (MPT, Intel MPI, MVAPICH2, and Open MPI) handle the non-ppn type job just fine, but it's possible that they are evenly distributing the processes themselves. And the "MAPL_Shmem" lines you see are just reporting what the process structure looks like. I've added some print statements including this: if (present(CommIn)) then CommCap = CommIn else CommCap = MPI_COMM_WORLD end if if (.not.present(CommIn)) then call mpi_init(status) VERIFY_(STATUS) end if write (*,*) "MPI Initialized." So, boring, and CommIn is *not* present, so we are using MPI_COMM_WORLD, and mpi_init is called as one would. Now if I run: mpirun -np 96 ./GEOSgcm.x | grep 'MPI Init' | wc -l to count the number initialized, multiple times, I get results like: 40, 56, 56, 45, 68. Never consistent. So, I'm a bit at a loss. I freely admit I might have built MPICH3 incorrectly. It was essentially my first time. I configured with:
./configure --prefix=$SWDEV/MPI/mpich/3.2/intel_17.0.4.196 \ --disable-wrapper-rpath CC=icc CXX=icpc FC=ifort F77=ifort \ --enable-fortran=all --enable-cxx | & tee configure.intel_17.0.4.196.log
which might be too vanilla for a SLURM/Infiniband cluster, but, yet, it works with -ppn. But maybe I need extra options to work at all times? --with-ibverbs? --with-slurm? Any ideas on what's happening and what I might have done wrong? Thanks, Matt -- Matt Thompson, SSAI, Sr Scientific Programmer/Analyst NASA GSFC, Global Modeling and Assimilation Office Code 610.1, 8800 Greenbelt Rd, Greenbelt, MD 20771 Phone: 301-614-6712 Fax: 301-614-6246 http://science.gsfc.nasa.gov/sed/bio/matthew.thompson _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Thompson, Matt (GSFC-610.1)[SCIENCE SYSTEMS AND APPLICATIONS INC]
