Re: [mpich-discuss] Have constants available in shared library
There will be sufficient warning when the MPICH ABI changes, so Jeff's approach should work. The MPICH constant values will also be valid for derivatives listed here: http://www.mpich.org/abi/ Ken On 04/14/2016 02:31 PM, Jeff Hammond wrote:
Erik:
MPICH ABI is standardized so just parse the header once and forget about it.
Jeff
On Thursday, April 14, 2016, Erik Schnetter <[email protected] <mailto:[email protected]>> wrote:
Rajeev
Apologies; I sent an identical request to the OpenMPI developers as well. I meant the MPICH library here.
In Julia, it is straightforward to call a function in a shared library, but it is not possible to access constants that are defined in a C header file, as this would require parsing C code. It would thus be convenient to access these constant in a different manner, e.g. by looking at the value of a global variable or constant.
-erik
On Thu, Apr 14, 2016 at 1:50 PM, Thakur, Rajeev <[email protected] <javascript:;>> wrote: >> Could you add similar constants to the OpenMPI shared library? > > This list is for MPICH. Open MPI has a different mailing list. > > In MPICH, these constants are defined in the mpi.h header file. > > Rajeev > > >> On Apr 14, 2016, at 9:04 AM, Erik Schnetter <[email protected] <javascript:;>> wrote: >> >> I am one of the maintainers of the MPI wrapper package for Julia >> <https://github.com/JuliaParallel/MPI.jl>. This package provides Julia >> language bindings for MPI, essentially wrapping various MPI functions, >> comparable to what mpi4py <http://pythonhosted.org/mpi4py/> does for >> Python. >> >> It is in Julia straightforward to call C functions in a shared >> library. The MPI API is standardized, so that part is straightforward. >> What is not standardized are the values of various constants, such as >> e.g. MPI_INT, MPI_MAX, or MPI_ANY_TAG. >> >> We currently use a cmake function that builds and runs a small >> executable that outputs the (implementation-specific) values of these >> constants, and auto-generates Julia code that defines these constants. >> We do this when the Julia MPI package is installed or updated. This >> works fine, but I think there could be a better way. >> >> The HDF5 library <https://www.hdfgroup.org/HDF5/> puts global >> constants into the data section of their library, with names derived >> from the preprocessor constants (with a _g suffix, I believe). This >> makes it straightforward to access the values of these constants at >> run time. For example, there exists a constant H5T_NATIVE_INT_g. >> >> Could you add similar constants to the OpenMPI shared library? This >> would simplify wrapping the library. >> >> Thanks, >> -erik >> >> -- >> Erik Schnetter <[email protected] <javascript:;>> >> http://www.perimeterinstitute.ca/personal/eschnetter/ >> _______________________________________________ >> discuss mailing list [email protected] <javascript:;> >> To manage subscription options or unsubscribe: >> https://lists.mpich.org/mailman/listinfo/discuss > > _______________________________________________ > discuss mailing list [email protected] <javascript:;> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss
-- Erik Schnetter <[email protected] <javascript:;>> http://www.perimeterinstitute.ca/personal/eschnetter/ _______________________________________________ discuss mailing list [email protected] <javascript:;> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
