Re: [mpich-discuss] package issue on fedora
The answer is in the link provided by Zbyszek : " MPI implementation specific files MUST be installed in the directories used by the used MPI compiler ($MPI_BIN, $MPI_LIB and so on)." With my binaries installed under /usr/lib64/mpich/bin, I have the good requires -----Message d'origine----- De : Zbigniew Jędrzejewski-Szmek [mailto:[email protected]] Envoyé : mardi 27 novembre 2018 15:01 À : bruno via discuss Cc : GUERRAZ Bruno TGI/OLS Objet : Re: [mpich-discuss] package issue on fedora On Tue, Nov 27, 2018 at 01:40:32PM +0000, bruno via discuss wrote:
Hi all, I am packaging a software that use MPICH on fedora. When I try to install the package, dnf tells me : conflicting requests - nothing provides libmpi.so.12()(64bit) needed by khiops-9.0.x86_64 - nothing provides libmpicxx.so.12()(64bit) needed by khiops-9.0.x86_64
And when I run "rpm -q --provides mpich" I have : libmpi.so.12()(64bit)(mpich-x86_64) libmpicxx.so.12()(64bit)(mpich-x86_64)
The mpi libraries are not installed in the normal library search path in Fedora, hence the provides/requires tags use a suffix. This suffix also allows multiple mpi implementations to provide libmpi. See https://docs.fedoraproject.org/en-US/packaging-guidelines/MPI/. If you post your .spec file somewhere, I can take a look. Zbyszek _________________________________________________________________________________________________________________________ Ce message et ses pieces jointes peuvent contenir des informations confidentielles ou privilegiees et ne doivent donc pas etre diffuses, exploites ou copies sans autorisation. Si vous avez recu ce message par erreur, veuillez le signaler a l'expediteur et le detruire ainsi que les pieces jointes. Les messages electroniques etant susceptibles d'alteration, Orange decline toute responsabilite si ce message a ete altere, deforme ou falsifie. Merci. This message and its attachments may contain confidential or privileged information that may be protected by law; they should not be distributed, used or copied without authorisation. If you have received this email in error, please notify the sender and delete this message and its attachments. As emails may be altered, Orange is not liable for messages that have been modified, changed or falsified. Thank you.
participants (1)
bruno.guerraz@orange.com
