Re: [mpich-discuss] [EXTERNAL] Re: Maximum number of inter-communicators?
Hui, just one process on a particular node failed (without any error message). We just had an O/S upgrade on the whole cluster, and may an error was made on that node in the upgrade. I’m trying to figure out what is different about that node. Kurt From: Zhou, Hui <[email protected]> Sent: Friday, November 19, 2021 4:29 PM To: [email protected] Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]> Subject: [EXTERNAL] Re: Maximum number of inter-communicators? Kurt, That usually means the process went away without telling the process manager (hydra) first. Those messages are from hydra when the connection to the process disconnected unexpectedly. Did all processes call `MPI_Finalize` before exit? -- Hui Zhou From: Mccall, Kurt E. (MSFC-EV41) via discuss <[email protected]<mailto:[email protected]>> Date: Friday, November 19, 2021 at 2:26 PM To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>> Subject: Re: [mpich-discuss] Maximum number of inter-communicators? Thanks Hui, replacing MPI_LOGICAL with MPI_CXX_BOOL enabled the code to run without the segfault (using 4.0a2). Do you have any clue what this error message means? [[email protected]] control_cb (../../../../mpich-4.0a2/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:206): assert (!closed) failed [[email protected]] HYDT_dmxu_poll_wait_for_event (../../../../mpich-4.0a2/src/pm/hydra/tools/demux/demux_poll.c:76): callback returned error status [[email protected]] HYD_pmci_wait_for_completion (../../../../mpich-4.0a2/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:160): error waiting for event [[email protected]] main (../../../../mpich-4.0a2/src/pm/hydra/ui/mpich/mpiexec.c:325): process manager error waiting for completion [proxy:0:[email protected]] HYD_pmcd_pmip_control_cmd_cb (../../../../mpich-4.0a2/src/pm/hydra/pm/pmiserv/pmip_cb.c:896): assert (!closed) failed [proxy:0:[email protected]] HYDT_dmxu_poll_wait_for_event (../../../../mpich-4.0a2/src/pm/hydra/tools/demux/demux_poll.c:76): callback returned error status [proxy:0:[email protected]] main (../../../../mpich-4.0a2/src/pm/hydra/pm/pmiserv/pmip.c:169): de[proxy:0:[email protected]] HYD_pmcd_pmip_control_cmd_cb (../../../../mpich-4.0a2/src/pm/hydra/pm/pmiserv/pmip_cb.c:896): assert (!closed) failed [proxy:0:[email protected]] HYDT_dmxu_poll_wait_for_event (../../../../mpich-4.0a2/src/pm/hydra/tools/demu[proxy:0:[email protected]] HYD_pmcd_pmip_control_cmd_cb (../../../../mpich-4.0a2/src/pm/hydra/pm/pmiserv/pmip_cb.c:896): assert (!closed) failed [proxy:0:[email protected]] HYDT_dmxu_poll_wait_for_event (../../../../mpich-4.0a2/src/pm/hydra/tools/demu[proxy:0:[email protected]] HYD_pmcd_pmip_control_cmd_cb (../../../../mpich-4.0a2/src/pm/hydra/pm/pmiserv/pmip_cb.c:896): assert (!closed) failed [proxy:0:[email protected]] HYDT_dmxu_poll_wait_for_event (../../../../mpich-4.0a2/src/pm/hydra/tools/demu[proxy:0:[email protected]] HYD_pmcd_pmip_control_cmd_cb (../../../../mpich-4.0a2/src/pm/hydra/pm/pmiserv/pmip_cb.c:896): assert (!closed) failed [proxy:0:[email protected]] HYDT_dmxu_poll_ Thanks, Kurt From: Zhou, Hui <[email protected]<mailto:[email protected]>> Sent: Monday, November 15, 2021 9:44 PM To: [email protected]<mailto:[email protected]> Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>> Subject: [EXTERNAL] Re: Maximum number of inter-communicators? Hi Kurt, Did you build mpich with Fortran disabled? MPI_LOGICAL is a Fortran datatype and is unavailable when Fortran binding is disabled. Try use MPI_C_BOOL instead. If you didn't disable cxx, you may also try use MPI_CXX_BOOL since you are programming in C++. Hui ________________________________ From: Mccall, Kurt E. (MSFC-EV41) via discuss <[email protected]<mailto:[email protected]>> Sent: Saturday, November 13, 2021 2:56 PM To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>> Subject: Re: [mpich-discuss] Maximum number of inter-communicators? Hui, I built MPICH 4.0a2 with gcc 4.8.5, and included the -enable-g=all flag to “configure” so that debugging symbols would be present. The code is crashing my call to MPI_Type_commit, in libpthreads.so. gdb give this stack trace below. Since MPICH 3.3.2, has there been changes in how custom types are created (the code worked in 3.3.2)? I included my type-creating code after the stack trace. Program received signal SIGSEGV, Segmentation fault. MPIR_Typerep_create_struct (count=count@entry=8, array_of_blocklengths=array_of_blocklengths@entry=0x128b6b0, array_of_displacements=array_of_displacements@entry=0x7fffcaa243c0, array_of_types=array_of_types@entry=0x7fffcaa24410, newtype=newtype@entry=0x7fec8bedd258 <MPIR_Datatype_direct+1400>) at ../mpich-4.0a2/src/mpi/datatype/typerep/src/typerep_dataloop_create.c:659 659 MPIR_Ensure_Aint_fits_in_int(old_dtp->builtin_element_size); (gdb) where #0 MPIR_Typerep_create_struct (count=count@entry=8, array_of_blocklengths=array_of_blocklengths@entry=0x128b6b0, array_of_displacements=array_of_displacements@entry=0x7fffcaa243c0, array_of_types=array_of_types@entry=0x7fffcaa24410, newtype=newtype@entry=0x7fec8bedd258 <MPIR_Datatype_direct+1400>) at ../mpich-4.0a2/src/mpi/datatype/typerep/src/typerep_dataloop_create.c:659 #1 0x00007fec8b9b2608 in type_struct (count=count@entry=8, blocklength_array=blocklength_array@entry=0x128b6b0, displacement_array=displacement_array@entry=0x7fffcaa243c0, oldtype_array=oldtype_array@entry=0x7fffcaa24410, newtype=newtype@entry=0x7fffcaa242dc) at ../mpich-4.0a2/src/mpi/datatype/type_create.c:206 #2 0x00007fec8b9b4b9e in type_struct (newtype=0x7fffcaa242dc, oldtype_array=0x7fffcaa24410, displacement_array=0x7fffcaa243c0, blocklength_array=0x128b6b0, count=8) at ../mpich-4.0a2/src/mpi/datatype/type_create.c:227 #3 MPIR_Type_struct (count=count@entry=8, blocklength_array=0x128b6b0, displacement_array=displacement_array@entry=0x7fffcaa243c0, oldtype_array=oldtype_array@entry=0x7fffcaa24410, newtype=newtype@entry=0x7fffcaa242dc) at ../mpich-4.0a2/src/mpi/datatype/type_create.c:235 #4 0x00007fec8b9b7b08 in MPIR_Type_create_struct_impl (count=count@entry=8, array_of_blocklengths=array_of_blocklengths@entry=0x7fffcaa24440, array_of_displacements=array_of_displacements@entry=0x7fffcaa243c0, array_of_types=array_of_types@entry=0x7fffcaa24410, newtype=newtype@entry=0x12853fc) at ../mpich-4.0a2/src/mpi/datatype/type_create.c:908 #5 0x00007fec8b85ad26 in internal_Type_create_struct (newtype=0x12853fc, array_of_types=0x7fffcaa24410, array_of_displacements=<optimized out>, array_of_blocklengths=0x7fffcaa24440, count=8) at ../mpich-4.0a2/src/binding/c/datatype/type_create_struct.c:79 #6 PMPI_Type_create_struct (count=8, array_of_blocklengths=0x7fffcaa24440, array_of_displacements=0x7fffcaa243c0, array_of_types=0x7fffcaa24410, newtype=0x12853fc) at ../mpich-4.0a2/src/binding/c/datatype/type_create_struct.c:164 #7 0x0000000000438dfb in needles::MpiMsgBasic::createMsgDataType (this=0x12853fc) at src/MsgBasic.cpp:97 #8 0x0000000000412b77 in needles::NeedlesMpiManager::init (this=0x12853a0, argc=23, argv=0x7fffcaa24e08, rank=20, world_size=21) at src/NeedlesMpiManager.cpp:204 #9 0x000000000040605f in main (argc=23, argv=0x7fffcaa24e08) at src/NeedlesMpiManagerMain.cpp:142 (gdb) Here is my code that creates the custom type and then calls MPI_Type_commit: MsgBasic obj; int struct_len = 8, i; int block_len[struct_len]; MPI_Datatype types[struct_len]; MPI_Aint displacements[struct_len]; i = 0; block_len[i] = 1; types[i] = MPI_LOGICAL; displacements[i] = (size_t) &obj.tuple_valid_ - (size_t) &obj; ++i; block_len[i] = 1; types[i] = MPI_LOGICAL; displacements[i] = (size_t) &obj.tuple_seq_valid_ - (size_t) &obj; // the int array "start_" member ++i; block_len[i] = Tuple::N_INDICES_MAX_; types[i] = MPI_SHORT; displacements[i] = (size_t) &obj.start_ - (size_t) &obj; // the int array "end_" member ++i; block_len[i] = Tuple::N_INDICES_MAX_; types[i] = MPI_SHORT; displacements[i] = (size_t) &obj.end_ - (size_t) &obj; // the integer "opcode_" member ++i; block_len[i] = 1; types[i] = MPI_INT; displacements[i] = (size_t) &obj.opcode_ - (size_t) &obj; // the boolean "success_" member ++i; block_len[i] = 1; types[i] = MPI_LOGICAL; // NOTE: might be MPI_BOOLEAN in later version displacements[i] = (size_t) &obj.success_ - (size_t) &obj; // the double "run_time_sec_" member ++i; block_len[i] = 1; types[i] = MPI_DOUBLE; displacements[i] = (size_t) &obj.run_time_sec_ - (size_t) &obj; // the char array "error_msg_" member ++i; block_len[i] = NeedlesMpi::ERROR_MSG_LEN_ + 1; types[i] = MPI_CHAR; displacements[i] = (size_t) &obj.error_msg_[0] - (size_t) &obj; MPI_Type_create_struct(struct_len, block_len, displacements, types, &msg_data_type_); MPI_Type_commit(&msg_data_type_); Thanks, Kurt From: Zhou, Hui <[email protected]<mailto:[email protected]>> Sent: Sunday, October 24, 2021 6:46 PM To: [email protected]<mailto:[email protected]> Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>> Subject: [EXTERNAL] Re: Maximum number of inter-communicators? Hi Kurt, There is indeed a limit on maximum number of communicators that you can have, including both intra communicators and inter-communicators. Try free the communicators that you no longer need. In older version of MPICH, there may be additional limit on how many dynamic processes one can connect. If you still hit crash after making sure there isn't too many simultaneous active communicators, could you try the latest release -- http://www.mpich.org/static/downloads/4.0a2/mpich-4.0a2.tar.gz<https://gcc02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.mpich.org%2Fstatic%2Fdownloads%2F4.0a2%2Fmpich-4.0a2.tar.gz&data=04%7C01%7Ckurt.e.mccall%40nasa.gov%7C10ccb7bc3eb949606a3208d9abacc240%7C7005d45845be48ae8140d43da96dd17b%7C0%7C0%7C637729583619855292%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=%2FEAbJEoq2JeBho5Ruhy5gFKx7tNkmtW9R1hyd8PT3yY%3D&reserved=0>, and see if the issue persist? -- Hui ________________________________ From: Mccall, Kurt E. (MSFC-EV41) via discuss <[email protected]<mailto:[email protected]>> Sent: Sunday, October 24, 2021 2:37 PM To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Cc: Mccall, Kurt E. (MSFC-EV41) <[email protected]<mailto:[email protected]>> Subject: [mpich-discuss] Maximum number of inter-communicators? Hi, Based on a paper I read about giving an MPI job some fault tolerance, I’m exclusively connecting my processes with inter-communicators. I’ve found that if I increase the number of processes beyond a certain point, many processes don’t get created at all and the whole job crashes. Am I running up against an operating system limit (like the number of open file descriptors – it is set at 1024), or some sort of MPICH limit? If it matters, my process architecture (a tree) is as follows: one master process connected to 21 manager processes on 21 other nodes, and each manager connected to 8 worker processes on the manager’s own node. This is the largest job I’ve been able to create without it crashing. Attempting to increase the number of workers beyond 8 results in a crash. I’m using MPICH 3.3.2 on Centos 3.10.0. MPICH was compiled with the Portland Group compiler pgc++ 19.5-0. Thanks, Kurt
participants (1)
