Re: [mpich-discuss] MPI_Send and recv
On Jul 2, 2013, at 9:03 PM, Matthieu Dorier <[email protected]> wrote:
These messages piqued my curiosity;
If I have two processes, process 0 does an MPI_Send to process 1 and eventually, process 1 posts a matching MPI_Recv or MPI_Irecv; does process 0 waits for the MPI_Recv/Irecv to be posted before returning from the MPI_Send? (in other words if process 0 does 2 MPI_Send and process 1 does 2 MPI_Recv, is the linearization "Send; Send; Recv; Recv" possible?)
It is possible that process 0 could return from the MPI_Send before process 1 posts the corresponding MPI_Recv, but it's not guaranteed. The only thing that is guaranteed from the standard is that when MPI_Send returns, the buffer is available to use again. It is valid to wait for the MPI_Recv to post as well. So to answer your example, S - S - R - R is valid, as is S - R - S - R.
Second question: in the situation described by Sufeng, where a process does a MPI_Send to itself, MPI has enough information to see that the process is sending to itself while it has not posted any matching receive, why would MPI block instead of printing an error and aborting? Is it because in a multithreaded program, the matching receive could be posted by another thread? (Yet in that case I always thought it was unsafe to use the same communicator from multiple threads…)
There are probably many reasons why MPI doesn't try to do internal error checking. The first is performance. If a program is correct, then checking for all of the cases that might cause a deadlock would be not only very difficult, but also expensive. Therefore, we just say that the user needs to write a correct program and MPI makes no guarantees that anything smart will happen in the background. It's possible that someone could write Nice-MPI that does lots of error checking and verification, but I would think that most users wouldn't want it as it would add overhead. Second, it's not always unsafe to use the same communicator in multiple threads. If you use different tags for each thread, then it shouldn't be a problem to communicate between them. Wesley
Matthieu
De: "Sufeng Niu" <[email protected]> À: "Pavan Balaji" <[email protected]> Cc: [email protected] Envoyé: Mardi 2 Juillet 2013 17:20:25 Objet: Re: [mpich-discuss] MPI_Send and recv
Thank you so much! Now I make sense
Sufeng
On Tue, Jul 2, 2013 at 5:19 PM, Pavan Balaji <[email protected]> wrote:
On 07/02/2013 05:18 PM, Sufeng Niu wrote: Thanks a lot, that is most confusing part for me in MPI. I would like to clear this type of problems.
So the blocking begins to send message to itself, but there is no receive posted. Thus, the MPI block it. Am I right here?
Correct.
Thus, I need a nonblocking receive to wait the message here. Can I use blocking receive?
If you use blocking receive, you'll block in the receive; how will you reach the send?
-- Pavan
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
-- Best Regards, Sufeng Niu ECASP lab, ECE department, Illinois Institute of Technology Tel: 312-731-7219
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
