Re: [mpich-discuss] mpich hangs
On 06/27/2013 10:08 PM, Syed. Jahanzeb Maqbool Hashmi wrote:
P4-businesscard=description#weiser2$port#57651$ifname#192.168.0.102$ P5-businesscard=description#weiser2$port#52622$ifname#192.168.0.102$ P6-businesscard=description#weiser2$port#55935$ifname#192.168.0.102$ P7-businesscard=description#weiser2$port#54952$ifname#192.168.0.102$ P0-businesscard=description#weiser1$port#41958$ifname#127.0.1.1$ P2-businesscard=description#weiser1$port#35049$ifname#127.0.1.1$ P1-businesscard=description#weiser1$port#39634$ifname#127.0.1.1$ P3-businesscard=description#weiser1$port#51802$ifname#127.0.1.1$
I have two concerns with your output. Let's start with the first. Did you look at this question on the FAQ page? "Is your /etc/hosts file consistent across all nodes? Unless you are using an external DNS server, the /etc/hosts file on every machine should contain the correct IP information about all hosts in the system." -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
