Re: [mpich-discuss] mpich3 error with ch3
Similar issues can be very different in causes. Checking the referenced discussion, I wasn’t sure what was the original issues. We suggested to try ch4 as to get more data points rather than as a solution. Nevertheless, ch4 is the current recommended device as it is more actively developed. Ch3 is not broken as far as we know. Could you describe your issue in more details? -- Hui Zhou From: Alim Akhtar via discuss <[email protected]> Date: Wednesday, May 26, 2021 at 10:51 PM To: [email protected] <[email protected]> Cc: Alim Akhtar <[email protected]> Subject: [mpich-discuss] mpich3 error with ch3 Hi mpich dev team, I am facing one issue similar to discussed in below discussion https://lists.mpich.org/pipermail/devel/2021-January/000826.html Someone in the mailing list suggested recompiling the mpi bench using CH4. as below: https://lists.mpich.org/pipermail/devel/2021-January/000828.html "MPICH with ch4, with `--with-device=ch4:ofi`" Actually this fixes the failure on this CPU architecture. Questions: 1. Is this a known issue with MPI bench on the recent CPU architecture? (I am running on ARM's Cortex -A 75), like ch3 is broken? 2. With no error after using CH4, does this mean the CPU is all good? Note: using ch3 was working fine on our previous CPU (A-72) Any input will be really appreciated. -- Regards, Alim _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Zhou, Hui
