Re: [mpich-discuss] Errors building MPICH on Windows 10 Ubuntu subsystem
Because OpenCoarrays calls MPI from C, the possible Fortran ABI variation across major versions of GCC should not be an issue. Damian should be fine to apt-get install mpich and then use the resulting C library. I imagine that cafc='mpicc -cc=gfortran-6' would work, but this is just a guess. Intel recently approved Windows 10. If I can get the VM for this, I'll try to debug this. Jeff On Tue, Oct 11, 2016 at 10:57 AM, Kenneth Raffenetti <[email protected]> wrote:
mpicc and friends are wrappers around the regular gcc/g++/gfortran compilers. If you have the version you want listed first in your PATH, things will probably work as you want. You can test by running 'mpicc -show' or 'mpicc -version' and check the underlying compiler.
Ken
On 10/11/2016 12:22 PM, Rob Latham wrote:
On 10/11/2016 10:05 AM, Kenneth Raffenetti wrote:
On 10/11/2016 09:45 AM, Damian Rouson wrote:
Also, if you have Ubuntu, can you simply apt-get install mpich?
On this system, apt-get installs GCC 4.8. My goal is to support users of OpenCoarrays, which requires at least GCC 5.1.0 and preferably GCC 6.1.0. Is there a Debian dpkg file that I could use to install MPICH?
Yes, try 'apt-get install mpich'.
I think he's saying "apt-get install mpich" brings in gcc-4.8 as a dependency.
Perhaps "apt-get source mpich" or maybe with the "-b" flag for bulid-dependencies, then re-building the debian package will get you what you need?
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
