Re: [mpich-discuss] How to use non-blocking send/receive without calling MPI_Wait
Hi Lei, As far as I know, all current MPI implementations do not support true asynchronous communication for now. i.e., If there is no MPI calls in your iterations, MPICH will not be able to make progress on communication. One solution is to poll the MPI runtime regularly to make progress by inserting MPI_Test to your iteration (even though you do not want to check the data). Another solution is to enable MPI's asynchronous progress thread to make progress for you. -- Huiwei On Thu, Apr 2, 2015 at 11:44 PM, Lei Shi <[email protected]> wrote:
Hi Junchao,
Thanks for your reply. For my case, I don't want to check the data have been received or not. So I don't want to call MPI_Test or any function to verify it. But my problem is like if I ignore calling the MPI_Wait, just call Isend/Irev, my program freezes for several sec and then continues to run. My guess is probably I messed up the MPI library internal buffer by doing this.
On Thu, Apr 2, 2015 at 7:25 PM, Junchao Zhang <[email protected]> wrote:
Does MPI_Test fit your needs?
--Junchao Zhang
On Thu, Apr 2, 2015 at 7:16 PM, Lei Shi <[email protected]> wrote:
I want to use non-blocking send/rev MPI_Isend/MPI_Irev to do communication. But in my case, I don't really care what kind of data I get or it is ready to use or not. So I don't want to waste my time to do any synchronization by calling MPI_Wait or etc API.
But when I avoid calling MPI_Wait, my program is freezed several secs after running some iterations (after multiple MPI_Isend/Irev callings), then continues. It takes even more time than the case with MPI_Wait. So my question is how to do a "true" non-blocking communication without waiting for the data ready or not. Thanks.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Huiwei Lu
