Re: [mpich-discuss] VA_ARGS support
$ pgcc foo.c $ ./a.out foo $ On Feb 25, 2014, at 3:51 PM, Balaji, Pavan wrote:
Thanks. Can you try compiling the below program with your pgi compiler:
#include <stdio.h> #define conftest_va_arg_macro(...) printf(__VA_ARGS__)
int main() { conftest_va_arg_macro("foo\n"); return 0; }
— Pavan
On Feb 25, 2014, at 5:23 PM, James Long <[email protected]> wrote:
hydra_config.h:
On Feb 25, 2014, at 2:13 PM, Balaji, Pavan wrote:
This is weird. Configure detected VA_ARGS correctly:
configure:13475: checking for variable argument list macro functionality configure:13520: pgcc -o conftest -O2 -V -O2 -DNDEBUG -DpgiFortran -I/home/boss/mpich-3.1/src/mpl/include -I/home/boss/mpich-3.1/src/mpl/include -I/home/boss/mpich-3.1/src/openpa/src -I/home/boss/mpich-3.1/src/openpa/src -I/home/boss/mpich-3.1/src/mpi/romio/include conftest.c > pac_test.log 2>&1 configure:13520: $? = 0
Can you send us your src/pm/hydra/include/hydra_config.h file?
— Pavan
On 2/25/14, 3:43 PM, "James Long" <[email protected]> wrote:
In two parts:
http://pastebin.com/zip0pYB5 http://pastebin.com/qj0xNh7s
On Feb 25, 2014, at 11:27 AM, Balaji, Pavan wrote:
Is there a compiler that actually does not support VA_ARGS in 2014?
You’ll need to send us the config.log in src/pm/hydra.
— Pavan
On 2/25/14, 2:06 PM, "James Long" <[email protected]> wrote:
Under debian 7.4, trying to compile mpich-3.1 with Portland Group 13.6, or 14.2, same error results in both cases:
make[3]: Entering directory `/home/user/mpich-3.1/src/pm/hydra' CC utils/alloc/alloc.lo PGC/x86-64 Linux 13.6-0 Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved. Copyright 2000-2013, STMicroelectronics, Inc. All Rights Reserved. PGC-F-0249-#error -- "hydra requires VA_ARGS support" (./include/hydra.h: 79) PGC/x86-64 Linux 13.6-0: compilation aborted
environment variables used: $ unset F90 $ export CC=pgcc $ export FC=pgf90 $ export CXX=pgCC $ export CPPFLAGS="-DNDEBUG -DpgiFortran" $ export CFLAGS="-O2 -V" $ export FFLAGS="-O2 -w -V"
Jim --
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% James Long International Arctic Research Center University of Alaska Fairbanks jlong|at|alaska.edu (907) 474-2440 %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% James Long International Arctic Research Center University of Alaska Fairbanks jlong|at|alaska.edu (907) 474-2440 %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
participants (1)
James Long
