Re: [mpich-discuss] Is there a way to set timeout to mpi process launch?
There is no way to do that in Hydra. The only way is for the user to set timers in the application and MPI_Abort if MPI_Init is taking too long. It is up to the user to determine what "taking too long" would mean. Halim www.mcs.anl.gov/~aamer On 10/31/16 6:18 PM, Pranav Ladkat wrote:
Specifying MPIEXEC_TIMEOUT would not be possible since the execution times would vary depending on the different job. Is there any solution available within mpich?
Thanks, Pranav
On Thu, Oct 27, 2016 at 10:15 PM, Halim Amer <[email protected]> wrote:
You can try setting MPIEXEC_TIMEOUT=<timeout value in seconds> to force the job to abort after running for the specified period. This is for the whole execution though, not just for the process launching step.
On 10/26/16 6:30 PM, Pranav Ladkat wrote:
When I run mpi program on multiple hosts, if executable fails to start on any of the host (due to missing library etc. type of reasons), other hosts just keep waiting for the process to come up. The program just hangs forever. Is there any way to set a timeout in such cases such that MPI should abort if not all processes were launched in a given timeout period?
Thanks, Pranav
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Halim Amer
