Re: [mpich-discuss] [petsc-dev] Is mpich/master:a8a2b30fd21 tested with Petsc?
This bug is present in Ubuntu 18.10, which distributes unpatched mpich-3.3b2. I just submitted a bug report: https://bugs.launchpad.net/ubuntu/+source/mpich/+bug/1802372 Eric Chamberland <[email protected]> writes:
mainly for PETSc users: please do no waste your time using MPI released with Intel Parallel Studio 2019 since it is the buggy MPICH 3.3b2 for which this initial thread has been created...
I just wrote a remind about this also on Intel forum:
https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/to...
Eric
On 19/04/18 09:01 AM, Eric Chamberland wrote:
this morning, mpich/master with PETSc is 100% working again for us.
Thanks to both commits:
https://github.com/pmodels/mpich/commit/c597c8d79deea220a42751fda0f01ce70764...
https://github.com/pmodels/mpich/commit/8edabc7373b82dd660019e53d24613176581...
and thanks to everybody who helped:
Satish Min Wesley Ken Rob Jed
Eric
On 17/04/18 04:58 PM, Min Si wrote:
Hi all,
Thanks for narrowing down the problem. I checked the MPICH code and believe this is a bug in MPICH. I just created a PR to fix it: https://github.com/pmodels/mpich/pull/3097
It should be merged into MPICH master branch soon.
Thanks, Min
On 2018/04/17 14:10, Eric Chamberland wrote:
are we talking about the "tag" passed to MPI_Isend for example?
but does that mean there is something to change for any MPI call which involves tags usage or is it only a PETSc "bad" tag usage?
thanks Satish for your finding!
Eric
On 16/04/18 11:31 PM, Satish Balay wrote:
On Tue, 13 Mar 2018, Eric Chamberland wrote:
each night we are testing mpich/master with our petsc-based code. I don't know if PETSc team is doing the same thing with mpich/master? (Maybe it is a good idea?)
Everything was fine (except the issue https://github.com/pmodels/mpich/issues/2892) up to commit 7b8d64debd, but since commit mpich:a8a2b30fd21), I have a segfault on a any parallel nightly test.
I attempted a bisect of the above range of commits - and narrowed down to:
db11d4c4a70e39a28be88ed32f00542301699e08 is the first bad commit <<<<<<<
balay@asterix /home/balay/soft/build/mpich ((db11d4c4a...)|BISECTING) $ git show db11d4c4a70e39a28be88ed32f00542301699e08 commit db11d4c4a70e39a28be88ed32f00542301699e08 (HEAD, refs/bisect/bad) Author: Ken Raffenetti <[email protected]> Date: Thu Feb 15 11:37:59 2018 -0600
init: Fix tag upper limit initialization The starting point for this value is equivalent to the usable tag bits macro. This value should be set before device initialization, otherwise devices will assume they have more bits than are actually available. Signed-off-by: Wesley Bland <[email protected]>
diff --git a/src/mpi/init/initthread.c b/src/mpi/init/initthread.c index cbc41f4d5..b31ae2f07 100644 --- a/src/mpi/init/initthread.c +++ b/src/mpi/init/initthread.c @@ -403,7 +403,7 @@ int MPIR_Init_thread(int *argc, char ***argv, int required, int *provided) MPIR_Process.attrs.host = MPI_PROC_NULL; MPIR_Process.attrs.io = MPI_PROC_NULL; MPIR_Process.attrs.lastusedcode = MPI_ERR_LASTCODE; - MPIR_Process.attrs.tag_ub = 0; + MPIR_Process.attrs.tag_ub = MPIR_TAG_USABLE_BITS; MPIR_Process.attrs.universe = MPIR_UNIVERSE_SIZE_NOT_SET; MPIR_Process.attrs.wtime_is_global = 0; @@ -531,13 +531,6 @@ int MPIR_Init_thread(int *argc, char ***argv, int required, int *provided) MPIR_Assert(((unsigned) MPIR_Process. attrs.tag_ub & ((unsigned) MPIR_Process.attrs.tag_ub + 1)) == 0); - /* Set aside tag space for tagged collectives and failure notification */ -#ifdef HAVE_TAG_ERROR_BITS - MPIR_Process.attrs.tag_ub >>= 3; -#else - MPIR_Process.attrs.tag_ub >>= 1; -#endif - /* Assert: tag_ub is at least the minimum asked for in the MPI spec */ MPIR_Assert(MPIR_Process.attrs.tag_ub >= 32767); <<<<<<<<<<<<<<<<<
Reverthing this patch gets mpich-3.3b2 working with petsc
Satish
participants (1)
Jed Brown
