Re: [mpich-discuss] _get_addr error while running application using MPICH
Hi Hui, Here are the outputs. I tried the following commands mpirun --version ./cpi mpirun ./cpi mpirun -np 1 ./cpi [vy57456@maya-usr1 em_real]$mpirun --version HYDRA build details: Version: 3.2.1 Release Date: Fri Nov 10 20:21:01 CST 2017 CC: gcc CXX: g++ F77: gfortran F90: gfortran Configure options: '--disable-option-checking' '--prefix=/umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/mpich-3.2.1' 'CC=gcc' 'CXX=g++' 'FC=gfortran' 'F77=gfortran' '--cache-file=/dev/null' '--srcdir=.' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS=-lpthread ' 'CPPFLAGS= -I/home/vy57456/zzbatmos_user/application/gfortran/source_code/mpich-3.2.1/src/mpl/include -I/home/vy57456/zzbatmos_user/application/gfortran/source_code/mpich-3.2.1/src/mpl/include -I/home/vy57456/zzbatmos_user/application/gfortran/source_code/mpich-3.2.1/src/openpa/src -I/home/vy57456/zzbatmos_user/application/gfortran/source_code/mpich-3.2.1/src/openpa/src -D_REENTRANT -I/home/vy57456/zzbatmos_user/application/gfortran/source_code/mpich-3.2.1/src/mpi/romio/include' 'MPLLIBNAME=mpl' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs cobalt Checkpointing libraries available: Demux engines available: poll select [vy57456@maya-usr1 examples]$./cpi Process 0 of 1 is on maya-usr1 pi is approximately 3.1415926544231341, Error is 0.0000000008333410 wall clock time = 0.000066 [vy57456@maya-usr1 examples]$mpirun ./cpi Process 0 of 1 is on maya-usr1 pi is approximately 3.1415926544231341, Error is 0.0000000008333410 wall clock time = 0.000095 [vy57456@maya-usr1 examples]$mpirun -np 1 ./cpi Process 0 of 1 is on maya-usr1 pi is approximately 3.1415926544231341, Error is 0.0000000008333410 wall clock time = 0.000093 There is no error. Zhifeng On Mon, Nov 19, 2018 at 10:33 AM Zhou, Hui <[email protected]> wrote:
On Mon, Nov 19, 2018 at 10:14:54AM -0500, Zhifeng Yang wrote:
Thank you for helping me on this error. Actually, real.exe is a portion of a very large weather model. It is very difficult to extract it or duplicate the error in a simple fortran code, since I am not sure where the problem is. From your discussion, I barely can understand them, in fact. Even I do not know what is "_get_addr". Is it related to MPI?
It is difficult to pin-point the problem without reproducing it.
Anyway, let's start with mpirun. What is your output if you try:
mpirun --version
Next, what is your mpich version? If you built mpich, locate the `cpi` program in the examples folder and try `./cpi` and `mpirun ./cpi`. Do you have error?
-- Hui Zhou
participants (1)
Zhifeng Yang
