On 06/06/2016 02:22 AM, phani sri wrote:
I am having a problem in installing MPICH in my Ubuntu OS. I would like to know about the following issues: 1) Are MPICH and MPICH2 are same or different.
MPICH2 was renamed to just MPICH when version 3.0 was released. MPICH is the name of the software from now on.
2) How can I check if MPICH is installed or not.
Assuming the installation directory is in your PATH, you can run "mpichversion" to see if it is installed and what version. If you just installed using "apt-get install mpich" you should be mostly set. If you built from source and encountered and error, post it here and we can determine the issue. Ken _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
