Re: [mpich-discuss] MPICH build errors, cannot find -levent(_pthreads)
Hi Sajid, So does adding /lib64 to your `LIBRARY_PATH` help? -- Hui Zhou From: Sajid Ali <[email protected]> Date: Tuesday, March 17, 2020 at 3:09 PM To: "Zhou, Hui" <[email protected]> Cc: "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] MPICH build errors, cannot find -levent(_pthreads) Hi Hui, libevent(-2.0.so.5) is at available at /lib64. pmix depends on libevent as per the spack recipe<https://github.com/spack/spack/blob/develop/var/spack/repos/builtin/packages/pmix/package.py>. Checking for libpmix linkage I do see that it is linked to libevent : [sas4990@quser10 lib64]$ pwd /usr/local/pmix-3.1.5/lib64 [sas4990@quser10 lib64]$ ldd libpmix.so.2.2.25 linux-vdso.so.1 => (0x00007fffbfbe7000) libm.so.6 => /lib64/libm.so.6 (0x00002b413ffb3000) libutil.so.1 => /lib64/libutil.so.1 (0x00002b41402b5000) libevent-2.0.so.5 => /lib64/libevent-2.0.so.5 (0x00002b41404b8000) libevent_pthreads-2.0.so.5 => /lib64/libevent_pthreads-2.0.so.5 (0x00002b4140700000) libz.so.1 => /home/sas4990/packages/spack/opt/spack/linux-rhel7-ivybridge/gcc-4.8.5/zlib-1.2.11-dy4p76tgbhwcznwvv7rcagzfcbxyhsbo/lib/libz.so.1 (0x00002b4140903000) libdl.so.2 => /lib64/libdl.so.2 (0x00002b4140b1a000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00002b4140d1e000) libc.so.6 => /lib64/libc.so.6 (0x00002b4140f3a000) /lib64/ld-linux-x86-64.so.2 (0x00002b413fa75000) [sas4990@quser10 lib64]$ I’m confused as to why libtool is unable to read use the dependency listing of pmix to find libevent. readelf tells me that libpmix doesn’t have rpaths set for it’s dependencies, could this be the cause of the linker being unable to find libevent ? Thank You Sajid Ali | PhD Candidate Applied Physics Northwestern University s-sajid-ali.github.io<http://s-sajid-ali.github.io>
participants (1)
Zhou, Hui
