Re: [mpich-discuss] MPI Hello world Program failes for large no. of process
If you’re only using two machines, you might be running out of resources when you try to use that many processes. If you want to run hundred of processes, you need hundreds of cores. On Oct 28, 2013, at 9:16 AM, heshsham basit <[email protected]> wrote:
Whenever I launch more than 400 processes I get the following error. But for less than 400 process every thing goes perfectly fine.
I am running my code on two machines: hesh and Ubuntu (from which I am launching the jobs)
root@ubuntu:/home# mpiexec -f hosts.cfg -n 500 ./hello
===================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 139 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================== [proxy:0:0@hesh] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
[proxy:0:0@hesh] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [proxy:0:0@hesh] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event [mpiexec@ubuntu] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
[mpiexec@ubuntu] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion [mpiexec@ubuntu] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher returned error waiting for completion
[mpiexec@ubuntu] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Also some I time I got the following error:
root@ubuntu:/home# mpiexec -f hosts.cfg -n 400 ./hello
[proxy:0:1@ubuntu] send_cmd_downstream (./pm/pmiserv/pmip_pmi_v1.c:80): assert (!closed) failed [proxy:0:1@ubuntu] fn_get (./pm/pmiserv/pmip_pmi_v1.c:349): error sending PMI response [proxy:0:1@ubuntu] pmi_cb (./pm/pmiserv/pmip_cb.c:327): PMI handler returned error
[proxy:0:1@ubuntu] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [proxy:0:1@ubuntu] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event [mpiexec@ubuntu] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
[mpiexec@ubuntu] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [mpiexec@ubuntu] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:181): error waiting for event
Also I raised the open file limit on both the PCs by using ulimit -n 2048. But still the same result. The code is the simple one:
/* C Example */ #include <mpi.h> #include <stdio.h> #include <stddef.h> #include <stdlib.h>
int main (int argc, char* argv[]) { int rank, size; int buffer_length = MPI_MAX_PROCESSOR_NAME; char hostname[buffer_length];
MPI_Init (&argc, &argv); /* starts MPI */ MPI_Comm_rank (MPI_COMM_WORLD, &rank); /* get current process id */ MPI_Comm_size (MPI_COMM_WORLD, &size); /* get number of processes */
MPI_Get_processor_name(hostname, &buffer_length); /* get hostname */
printf( "Hello world from process %d running on %s of %d\n", rank, hostname, size ); MPI_Finalize(); return 0; }
For 10000 process the program is unresponsive and I have to close the terminal to exit.t How do i solve this issue? _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
