Re: [mpich-discuss] installing mpich-1.2.6 to create libmpich.so.1.0
Alternatively, if you have access to a package manager on your machine, you can just do something like apt-get install mpich2. The version available from most package managers is a little old, but it does simplify the installation process. If you do need to build from source, make sure you read through the README file in the top level directory of MPICH. It has lots of instructions for installation and will show you the best way to report issues to this mailing list so we can help you most efficiently. Let us know if you're still having trouble after you try those things. Wesley On Jun 25, 2013, at 7:19 AM, Jeff Hammond <[email protected]> wrote:
Try MPICH 3.0.4. MPICH 1.2.6 is ancient and not supported.
This is how I build MPICH 3.0.4. You will have to edit the prefix option appropriately.
wget http://www.mpich.org/static/downloads/3.0.4/mpich-3.0.4.tar.gz tar -xzf mpich-3.0.4.tar.gz cd mpich-3.0.4 mkdir build-gcc cd build-gcc/ ../configure CC=gcc CXX=g++ FC=gfortran F77=gfortran --enable-fc --enable-f77 --enable-threads --enable-g=dbg --with-device=ch3:nemesis --with-pm=hydra --prefix=.
Jeff
----- Original Message ----- From: "Andre Pattantyus" <[email protected]> To: [email protected] Sent: Tuesday, June 25, 2013 3:15:55 AM Subject: [mpich-discuss] installing mpich-1.2.6 to create libmpich.so.1.0
Hello,
I am not familiar with installing mpich and am having problems with installation. I have found from searching online that mpich-1.2.6 produces libmpich.so.1.0 which I require run a certain program in parallel. I am unable to follow the installation documentation I have found online for this version because when i configure for ch_p4mpd I get an error when I run make. Therefore I just run ./configure and make but this does not produce my required libmpich.so.1.0. What do I need to specify prior to either configure or make in order to build this? I am building on a linux86-64 with pgi/10.2 compiler.
-- Andre Pattantyus Graduate Student Research Assistant Department of Meteorology University of Hawaii at Manoa 2525 Correa Rd, HIG 350 Honolulu, HI 96822 Phone: (845) 264-3582
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
