Re: [mpich-discuss] unable to build 3.2
Configuring mpich-3.2can be done as ./configure -prefix=/home/software/mpich3.2-install |& tee c.txt To build mpich Make |& tee m.txt I think it will work. Sanjesh On 14 Mar 2016 19:48, "Rob Latham" <[email protected]> wrote:
On 03/14/2016 07:06 AM, Peter Steinbach wrote:
Hi -
I just downloaded mpich 3.2 and wanted to build it on a centos 6.3 based system (gcc 4.9.2). The configure call looked like this: $ ./configure --with-ibverbs --with-ibverbs-include=/usr/include --with-ibverbs-lib=/usr/lib64 --enable-fast --enable-shared --with-java --prefix=$HOME/software/mpich/3.2
the configure runs through, but the make call finishes with: $ make ... ( cd . && \ ./maint/extracterrmsgs -careful=unusederr.txt \ -skip=src/util/multichannel/mpi.c \ `cat maint/errmsgdirs` > .tmp 2>.err ) ( cd . && if test -s .err ; then rm -f .tmp ; cat .err ; exit 1 ; fi ) Warning: attempt to redefine **fail. Duplicate ignored. Warning: **fail . . src/mpid/ch3/channels/nemesis/netmod/llc/errnames.txt : 15 make: *** [src/mpi/errhan/defmsg.h] Error 1
The problem appears to be coming from: $ egrep '^\*\*fail:' `find -name "errnames.txt"` ./src/mpi/errhan/errnames.txt:**fail: ./src/mpid/ch3/channels/nemesis/netmod/llc/errnames.txt:**fail:fail failed
I thought we fixed this? Maybe it went in just after the mpich-3.2 release.
Any idea how to resolve it?
Ah, it sure did. 4 commits after 3.2 was tagged in fact. Simply delete the **fail line from src/mpid/ch3/channels/nemesis/netmod/llc/errnames.txt. I've attached a patch if that's easier for you:
==rob
Best,
P
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
sanjesh pant
