Re: [mpich-discuss] hydra, stdin close(), and SLURM
Thanks, Aaron. That seems like a reasonable workaround (though the error is really in the slurm code for assuming that fd 0 is already stdin). Do you think you can provide a git patch? I can signoff on it (which is our way of "reviewing it") and include it in the upcoming release. Regards, -- Pavan On 7/25/15, 9:26 PM, "Aaron Knister" <[email protected]> wrote:
I sent this off to the mvapich list yesterday and it was suggested I raise it here since this is the upstream project:
This is a bit of a cross post from a thread I started on the slurm dev list: http://article.gmane.org/gmane.comp.distributed.slurm.devel/8176
I'd like to get feedback on the idea that "--input none" be passed to srun when using the SLURM hydra bootstrap mechanism. I figured it would be inserted somewhere around here http://trac.mpich.org/projects/mpich/browser/src/pm/hydra/tools/bootstrap/ex....
Without this argument I'm getting spurious job aborts and confusing errors. The gist of it is mpiexec.hydra closes stdin before it exec's srun. srun then (possibly via the munge libraries) calls some function that does a look up via nss. We use sssd for AAA so libnss_sssd will handle this request. Part of the caching mechanism sssd uses will cause the library to open() the cache file. The lowest fd available is 0 so the cache file is opened on fd 0. srun then believes it's got stdin attached and it causes the issues outlined in the slurm dev post. I think passing "--input none" is the right thing to do here since hydra has in fact closed stdin to srun. I tested this via the HYDRA_LAUNCHER_EXTRA_ARGS environment variable and it does resolve the errors I described.
Thanks! -Aaron
-- Aaron Knister NASA Center for Climate Simulation (Code 606.2) Goddard Space Flight Center (301) 286-2776
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
