Re: [mpich-discuss] error spawning processes in mpich-3.2rc1
Hi Siegmar, We have had a quick fix for the issue in the spawn programs. But the unaligned memory access may exist in every received packet inside MPICH, thus we decided to completely fix it and will add this fix in future release (not mpich-3.2rc2). Attached patch is our quick fix for received eager packets, it solves the issue in your spawn programs. You can patch it to mpich-3.2rc1 for temporary use. cd <mpich-3.2rc1 source dir> gpatch -p1 < unalign_access.patch autoconf -f ./configure <your options> make && make install Please also track the ticket for official fix. Best regards, Min On 11/10/15 3:40 AM, Siegmar Gross wrote:
Hi Min,
yesterday I installed mpich-3.2rc2 and it still breaks. Are you still trying to solve the problem?
Best regards
Siegmar
Min Si<[email protected]> 10/21/15 6:36 PM >>> Hi Siegmar,
Thanks for providing us the test machine. We have confirmed this failure is caused by unaligned memory access inside MPICH. So the failure only happens on SPARC, which is alignment-sensitive.
We will fix it. You can track the progress from this ticket. https://trac.mpich.org/projects/mpich/ticket/2309#ticket
Because we do not have other SPARC platform, would you mind if we use your machine for testing during this fix ?
Best regards, Min On 10/12/15 9:24 AM, Siegmar Gross wrote:
Hi Min,
It seems you already enabled the most detailed error outputs. We could not think out any clue for now. If you can give us access to your machine, we are glad to help you debug on it. Can you send me your email address because I don't want to send login data to this list.
Kind regards
Siegmar
Min
On 10/8/15 12:02 AM, Siegmar Gross wrote:
Hi Min,
thank you very much for your answer.
We cannot reproduce this error on our test machines (Solaris i386, Ubuntu x86_64) by using your programs. And unfortunately we do not have Solaris Sparc machine thus could not verify it. The programs work fine on my Solaris x86_64 and Linux machines as well. I only have a problem on Solaris Sparc.
Sometime, it can happen that you need to add "./" in front of the program path, could you try it ?
For example, in spawn_master.c MPI: A Message-Passing Interface Standard
#define SLAVE_PROG "./spawn_slave" No, it wil not work, because the programs are stored in a different directory ($HOME/{SunOS, Linux}/{sparc, x86_64}/bin) which is part of PATH (as well as ".").
Can I do anything to track the source of the error?
Kind regards
Siegmar
Min
On 10/7/15 5:03 AM, Siegmar Gross wrote:
today I've built mpich-3.2rc1 on my machines (Solaris 10 Sparc, Solaris 10 x86_64, and openSUSE Linux 12.1 x86_64) with gcc-5.1.0 and Sun C 5.13. I still get the following errors on my Sparc machine which I'd already reported September 8th. "mpiexec" is aliased to 'mpiexec -genvnone'. It still doesn't matter if I use my cc- or gcc-version of MPICH.
tyr spawn 119 mpichversion MPICH Version: 3.2rc1 MPICH Release date: Wed Oct 7 00:00:33 CDT 2015 MPICH Device: ch3:nemesis MPICH configure: --prefix=/usr/local/mpich-3.2_64_cc --libdir=/usr/local/mpich-3.2_64_cc/lib64 --includedir=/usr/local/mpich-3.2_64_cc/include64 CC=cc CXX=CC F77=f77 FC=f95 CFLAGS=-m64 CXXFLAGS=-m64 FFLAGS=-m64 FCFLAGS=-m64 LDFLAGS=-m64 -L/usr/lib/sparcv9 -R/usr/lib/sparcv9 --enable-fortran=yes --enable-cxx --enable-romio --enable-debuginfo --enable-smpcoll --enable-threads=multiple --with-thread-package=posix --enable-shared MPICH CC: cc -m64 -O2 MPICH CXX: CC -m64 -O2 MPICH F77: f77 -m64 MPICH FC: f95 -m64 -O2 tyr spawn 120
tyr spawn 111 mpiexec -np 1 spawn_master
Parent process 0 running on tyr.informatik.hs-fulda.de I create 4 slave processes
Fatal error in MPI_Comm_spawn: Unknown error class, error stack: MPI_Comm_spawn(144)...........: MPI_Comm_spawn(cmd="spawn_slave", argv=0, maxprocs=4, MPI_INFO_NULL, root=0, MPI_COMM_WORLD, intercomm=ffffffff7fffde50, errors=0) failed MPIDI_Comm_spawn_multiple(274): MPID_Comm_accept(153).........: MPIDI_Comm_accept(1057).......: MPIR_Bcast_intra(1287)........: MPIR_Bcast_binomial(310)......: Failure during collective
tyr spawn 112 mpiexec -np 1 spawn_multiple_master
Parent process 0 running on tyr.informatik.hs-fulda.de I create 3 slave processes.
Fatal error in MPI_Comm_spawn_multiple: Unknown error class, error stack: MPI_Comm_spawn_multiple(162)..: MPI_Comm_spawn_multiple(count=2, cmds=ffffffff7fffde08, argvs=ffffffff7fffddf8, maxprocs=ffffffff7fffddf0, infos=ffffffff7fffdde8, root=0, MPI_COMM_WORLD, intercomm=ffffffff7fffdde4, errors=0) failed MPIDI_Comm_spawn_multiple(274): MPID_Comm_accept(153).........: MPIDI_Comm_accept(1057).......: MPIR_Bcast_intra(1287)........: MPIR_Bcast_binomial(310)......: Failure during collective
tyr spawn 113 mpiexec -np 1 spawn_intra_comm Parent process 0: I create 2 slave processes Fatal error in MPI_Comm_spawn: Unknown error class, error stack: MPI_Comm_spawn(144)...........: MPI_Comm_spawn(cmd="spawn_intra_comm", argv=0, maxprocs=2, MPI_INFO_NULL, root=0, MPI_COMM_WORLD, intercomm=ffffffff7fffded4, errors=0) failed MPIDI_Comm_spawn_multiple(274): MPID_Comm_accept(153).........: MPIDI_Comm_accept(1057).......: MPIR_Bcast_intra(1287)........: MPIR_Bcast_binomial(310)......: Failure during collective tyr spawn 114
I would be grateful if somebody can fix the problem. Thank you very much for any help in advance. I've attached my programs. Please let me know if you need anything else.
Kind regards
Siegmar
_______________________________________________ discuss [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Min Si
