Re: [mpich-discuss] Problems with running make
Gus and others, many thanks for your comments and suggestions. I am unsure whether I need fortran included as I am not in control of the software to be run on this linux cluster. I have asked but not yet got a reply... However, I did a yum search gfortran and installed the gcc-gfortran.x86_64 (I hope that was the one you referred to). I followed up with the ./configure ... as per your suggestion. That did not work. I then tried with only ./configure --prefix=/my/bin/folder. That worked so I also did make and make install. I have a machinefile with three linux computers, all sharing the same mpi binaries. Running hostname on all 20 cores works, so I guess I should conclude that mpi works, right? I then tried the software I am supposed to run on the cluster. It works on all nodes on the master computer, but not if other computers are involved. I have captured the output from such failed attempt to run that software on all available nodes on all available computers in the cluster, see below. I have attached c2.txt and m2.txt (and the output of the failed run) in the attached gzipped file (the failed run in run2.txt and in the image below may not be from the same failed run...). So, is it an issue for the software developers or is it an issue with mpich? I would appreciate if you could let me know if mpich is properly compiled and installed and whether I should follow up with the application developers instead. I now that they are successfully running this code on V1.4.1. Thanks for your prompt support. Cheers, Ron On 1/03/2014 08:19, Gus Correa wrote:
Hi Ron
Your config.log shows that configure is picking up Gnu /usr/bin/f77 as the Fortran compiler. See an excerpt of config.log below.
The Gnu f77/g77, which cannot compile Fortran-90 and later code.
You may want to install gfortran. Configure didn't find gfortran. However, you can install it easily from RPM through yum.
Once you install gfortran, to avoid picking up wrong compilers, you can also point configure to the compilers. Assuming you want to use all Gnu compilers, this would do it:
./configure CC=gcc, CXX=g++, F77=gfortran, FC=gfortran, --prefix=/wherever/you/want ...
Another possibility is follow Reuti's suggestion of not compiling the MPICH Fortran-90 interface.
I hope this helps, Gus Correa
******* from your config.log ********* ... configure:17977: result: no configure:17947: checking for gfortran configure:17977: result: no configure:17947: checking for f77 configure:17963: found /usr/bin/f77 configure:17974: result: f77 configure:18000: checking for Fortran 77 compiler version configure:18009: f77 --version >&5 GNU Fortran (GCC) 3.4.6 20060404 (Red Hat 3.4.6-19.el6) ... *****************************************
On 02/28/2014 05:02 AM, Reuti wrote:
Am 28.02.2014 um 09:22 schrieb Ron Palmer:
I am struggling with running make on MPICH, V3.1. I believe that ./configure went well but I do not understand what caused the errors in make. I thought it may be associated with the fortran compile but I have F77 installed (though somewhat confused whether fortran 90 is also installed). The README file suggested that I send an email to this list with nominated four text files attached.
You can try to skip f90:
$ ./configure --disable-fc ...
-- Reuti
The end of the m.txt file is included here for easy access, full details are attached...
CC src/mpi/topo/nhb_alltoallw.lo CC src/binding/f90/create_f90_int.lo CC src/binding/f90/create_f90_real.lo src/binding/f90/create_f90_real.c: In function 'PMPI_Type_create_f90_real': src/binding/f90/create_f90_real.c:73: error: expected expression before ',' token src/binding/f90/create_f90_real.c:74: error: expected expression before ',' token make[2]: *** [src/binding/f90/create_f90_real.lo] Error 1 make[2]: Leaving directory `/inv/mpich-3.1' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/inv/mpich-3.1' make: *** [all] Error 2
I look forward to any suggestions any of you may have. Regards, Ron
<mpi_logs.tar.gz>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Ron Palmer
