Re: [mpich-discuss] ./pm/pmiserv/pmip_cb.c:886): assert (!closed) failed
hi, I can get time to time 6 processs running and sometime it crash when 5 started,... so takeing third machine, what so ever start's the problem,... it's question communication between two slave's,... and crash when two salves are started to work together mpirin -np 2 -hosts ugh,kaak ls File rights should be ok, ports are open, useing rsh,.... Communication, demux engine ? Could PAM controll affect ? Still wondering NFS4 ? joni hosts ====== mpi1:2 ugh:2 kaak:2 Below error's debug after crash ====================== mpiexec -np 5 hostname .... [mpiexec@mpi1] Launch arguments: /mpi3/C3/mpich-3.0.4/bin/hydra_pmi_proxy --control-port 192.168.0.41:7000 --debug --rmk user --launcher rsh --launcher-exec /usr/bin/rsh-redone-rsh --demux poll --pgid 0 --retries 2 --usize -2 --proxy-id 0 [mpiexec@mpi1] Launch arguments: /usr/bin/rsh-redone-rsh 192.168.0.42 "/mpi3/C3/mpich-3.0.4/bin/hydra_pmi_proxy" --control-port 192.168.0.41:7000--debug --rmk user --launcher rsh --launcher-exec /usr/bin/rsh-redone-rsh --demux poll --pgid 0 --retries 2 --usize -2 --proxy-id 1 [mpiexec@mpi1] Launch arguments: /usr/bin/rsh-redone-rsh 192.168.0.43 "/mpi3/C3/mpich-3.0.4/bin/hydra_pmi_proxy" --control-port 192.168.0.41:7000--debug --rmk user --launcher rsh --launcher-exec /usr/bin/rsh-redone-rsh --demux poll --pgid 0 --retries 2 --usize -2 --proxy-id 2 mpi1 mpi1 ^X^C[mpiexec@mpi1] Sending Ctrl-C to processes as requested [mpiexec@mpi1] Press Ctrl-C again to force abort [mpiexec@mpi1] HYDU_sock_write (./utils/sock/sock.c:291): write error (Bad file descriptor) [mpiexec@mpi1] HYD_pmcd_pmiserv_send_signal (./pm/pmiserv/pmiserv_cb.c:170): unable to write data to proxy [mpiexec@mpi1] ui_cmd_cb (./pm/pmiserv/pmiserv_pmci.c:79): unable to send signal downstream [mpiexec@mpi1] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [mpiexec@mpi1] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:197): error waiting for event [mpiexec@mpi1] main (./ui/mpich/mpiexec.c:331): process manager error waiting for completion joni@mpi1:~$ echo $HYDRA_DEMUX select joni@mpi1:~$ sudo killall rsh-redone-rsh [sudo] password for joni: rsh-redone-rsh: ei prosesseja joni@mpi1:~$ Below blcr test after re-compile ====================== root@mpi1:/mpi3/S3/blcr-0.8.5# master kaak errors: 34 child 21967 completed #ST_ALARM:60 035 child 22072 is READY (context=SIGNAL stopped=YES) 036 child 22072 is STOPped !!! Alarm clock expired !!! Missing final DONE !!! Test killed unexpectedly by signal 9 FAIL: stopped.st root@ug:/mpi3/S3/blcr-0.8.5# slave kaak errors: root@kaak:/mpi3/S3/blcr-0.8.5# slave kaak errors: make check 34 child 7472 completed #ST_ALARM:60 035 child 7577 is READY (context=SIGNAL stopped=YES) 036 child 7577 is STOPped !!! Alarm clock expired !!! Missing final DONE !!! Test killed unexpectedly by signal 9 FAIL: stopped.st PASS: edeadlk.st /mpi3/S3/blcr-0.8.5/tests/.libs/lt-filedescriptors[8051]: file "filedescriptors.c", line 270, in check_stat_simple: File attributes changed. 1 mismatches /mpi3/S3/blcr-0.8.5/tests/.libs/lt-filedescriptors[8051]: file "crut.c", line 615, in crut_main: test_restart() unexpectedly returned -1 restart/nonzeroexit (255) FAIL: filedescriptors.ct 2013/8/27 Joni-Pekka Kurronen <[email protected]>
Another:
joni@mpi1:/mpi3/S3/mpich-3.0.4$ mpiexec -np 6 hostname host: 192.168.0.41 host: 192.168.0.42 host: 192.168.0.43
================================================================================================== mpiexec options: ---------------- Base path: /mpi3/C3/mpich-3.0.4/bin/ Launcher: (null) Debug level: 1 Enable X: -1
Global environment: -------------------
MUMPS=/mpi3/S3/MUMPS_4.10.0 LC_PAPER=fi_FI.UTF-8 LC_ADDRESS=fi_FI.UTF-8 SSH_AGENT_PID=12144 LC_MONETARY=fi_FI.UTF-8 MUMPS_I=/mpi3/C3/MUMPS_4.10.0 HYDRA_DEMUX=select GPG_AGENT_INFO=/tmp/keyring-kJwpJQ/gpg:0:1 JPK_LMETISDIR_S5=/mpi3/S3/parmetis-4.0.2 TERM=xterm SHELL=/bin/bash
XDG_SESSION_COOKIE=6d6390cb56a32b6678c10da600000412-1377606907.629665-1922379047 FFT=/mpi3/C3/fftw2 HYDRA_ENV=all JPK_NETGEN=/mpi3/C3/netgen_668 JPK_VER_S=S3 HYDRA_CKPOINTLIB=blcr HYDRA_CKPOINT_INTERVAL=10800 WINDOWID=54602522 LC_NUMERIC=fi_FI.UTF-8 HYDRA_CKPOINT_PREFIX=/mpi3/chekpoint/default.chk GNOME_KEYRING_CONTROL=/tmp/keyring-kJwpJQ JPK_ELMER=/mpi3/C3/elmer_6283 PARDISO_LIC_PATH=/mpi3/C3/pardiso METIS_INCLUDE_DIR=/mpi3/C3/ParMetis-3.2.0 JPK_NETGEN_S=/mpi3/S3/netgen_668 USER=joni
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36: JPK_TOGL=/mpi3/C3/Togl-1.7
LD_LIBRARY_PATH=/mpi3/C3/mpich-3.0.4/lib:/mpi3/C3/mpich-3.0.4/bin:/mpi3/C3/blcr-0.8.5/lib:/mpi3/C3/ParMetis-3.2.0:/mpi3/C3/acml5.3.1/gfortran64_mp/lib:/lib:/mpi3/C3/hypre-2.8.0b/lib:/mpi3/C3/scotch_6.0.0/lib:/mpi3/S3/MUMPS_4.10.0/lib:/mpi3/C3/acml5.3.1/gfortran64_mp/lib:/mpi3/C3/scalapack-2.0.2/lib:/mpi3/C3/hypre-2.8.0b/lib:/mpi3/C3/pardiso:/mpi3/C3/ParMetis-3.2.0:/mpi3/C3/ARPACK:/mpi3/C3/hdf5-1.8.10-patch1/lib:/mpi3/C3/VTK-5.8.0/lib/vtk-5.8:/mpi3/C3/elmer_6283/lib:/mpi3/C3/Togl-1.7:/mpi3/C3/netgen_668/lib:/usr/lib/:/usr/local/lib://mpi3/C3/vrpn/lib://mpi3/C3/hidapi/lib:/usr/include/libusb-1.0 LC_TELEPHONE=fi_FI.UTF-8 XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0 JPK_OCC=/usr/include/oce XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0 HYDRA_HOST_FILE=/mpi4/hosts SSH_AUTH_SOCK=/tmp/ssh-NnhxNTH12143/agent.12143 SCOTCHDIR=/mpi3/C3/scotch_6.0.0 HYDRA_LAUNCHER=rsh JPK_VER_B=B3 SESSION_MANAGER=local/mpi1:@ /tmp/.ICE-unix/4284,unix/mpi1:/tmp/.ICE-unix/4284 DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path ELMER_HOME=/mpi3/C3/elmer_6283 BLACS=/mpi3/C3/scalapack-2.0.2 BLAS32=/mpi3/C3/acml5.3.1/gfortran64_mp METIS_DIR= MPI_LIBS=-L/mpi3/C3/mpich-3.0.4/lib -lmpich -lmpichf90 -lmpl -lopa -lmpichcxx XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg JPK_MPI_DIR=/mpi3 JPK_HDF5_S=/mpi3/S3/hdf5-1.8.10-patch1 MPIEXEC_PORT_RANGE=7000:7500
PATH=/mpi3/C3/cmake-2.8.10.2/bin:/mpi3/C3/blcr-0.8.5/bin:/mpi3/C3/mpich-3.0.4/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/mpi3/C3/elmer_6283/bin:/mpi3/C3/elmer_6283/lib:/mpi3/C3/ParaView3 DESKTOP_SESSION=ubuntu BLAS=/mpi3/C3/acml5.3.1/gfortran64_mp METIS_LIBDIR=/mpi3/C3/ParMetis-3.2.0 CMAKE_COMMAND=/mpi3/C3/cmake-2.8.10.2/bin QT_QMAKE_EXECUTABLE=/usr/bin/qmake-qt4 LC_IDENTIFICATION=fi_FI.UTF-8 JPK_SCOTCHDIR_S=/mpi3/S3/scotch_6.0.0_esmumps JPK_LMETISDIR_S=/mpi3/S3/ParMetis-3.2.0 PWD=/mpi3/S3/mpich-3.0.4 NETGENDIR=/mpi3/C3/netgen_668/bin EDITOR=nano JPK_LMETISDIR=/mpi3/C3/ParMetis-3.2.0 GNOME_KEYRING_PID=4273 LANG=fi_FI.UTF-8 MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path OMPI_77=//mpi3/C3/mpich-3.0.4/bin/mpif77 LC_MEASUREMENT=fi_FI.UTF-8 JPK_HDF5=/mpi3/C3/hdf5-1.8.10-patch1 UBUNTU_MENUPROXY=libappmenu.so COMPIZ_CONFIG_PROFILE=ubuntu ELMER_POST_HOME=/mpi3/C3/elmer_6283/bin JPK_INS=/mpi3/C3 ELMER_LIB=/mpi3/C3/elmer_6283/share/elmersolver/lib HYDRA_PROXY_RETRY_COUNT=3 GDMSESSION=ubuntu JPK_ELMER_S=/mpi3/S3/elmer_6283 JPK_LMETISDIR5=/mpi3/C3/parmetis-4.0.2 JPK_LMETISDIR32=/mpi3/C3/ParMetis-3.2.0 HYDRA_DEBUG=1 JPK_BUI=/mpi3/S3 VTK_INCLUDEPATH=/mpi3/C3/VTK-5.8.0/include SHLVL=1 HOME=/home/joni OMPI_CC=//mpi3/C3/mpich-3.0.4/bin/mpicc LANGUAGE=fi:en OMPI_90=//mpi3/C3/mpich-3.0.4/bin/mpif90 ELMERGUI_HOME=/mpi3/C3/elmer_6283/bin GNOME_DESKTOP_SESSION_ID=this-is-deprecated MPI_IMPLEMENTATION=mpich MKL_SERIAL=YES LOGNAME=joni HYPRE=/mpi3/C3/hypre-2.8.0b JPK_ARPACK_S=/mpi3/S3/ARPACK JPK_JOBS=7 JPK_VTK_DIR=/mpi3/C3/VTK-5.8.0 SCALAPACK=/mpi3/C3/scalapack-2.0.2
XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share/:/usr/share/
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-gAYmjGaklf,guid=26c3f15a7a5ee55e8782415700000034 JPK_ARPACK=/mpi3/C3/ARPACK MPI_HOME=/mpi3/C3/mpich-3.0.4 LESSOPEN=| /usr/bin/lesspipe %s LACPACK=/mpi3/C3/acml5.3.1/gfortran64_mp OMPI_CXX=//mpi3/C3/mpich-3.0.4/bin/mpicxx OMP_NUM_THREADS=6 JPK_TOGL_S=/mpi3/S3/Togl-1.7 HYDRA_LAUNCHER_EXEC=/usr/bin/rsh-redone-rsh JPK_MPICH2=/mpi3/C3/mpich-3.0.4 PARDISO=/mpi3/C3/pardiso PARDISOLICMESSAGE=1 JPK_VER=C3 XDG_CURRENT_DESKTOP=Unity LESSCLOSE=/usr/bin/lesspipe %s %s LC_TIME=fi_FI.UTF-8 JPK_HYPRE_S=/mpi3/S3/hypre-2.8.0b JPK_MPICH2_S=/mpi3/S3/mpich-3.0.4 COLORTERM=gnome-terminal XAUTHORITY=/home/joni/.Xauthority LC_NAME=fi_FI.UTF-8 _=/mpi3/C3/mpich-3.0.4/bin/mpiexec OLDPWD=/home/joni
Hydra internal environment: --------------------------- MPICH_ENABLE_CKPOINT=1 GFORTRAN_UNBUFFERED_PRECONNECTED=y
Proxy information: ********************* [1] proxy: 192.168.0.41 (2 cores) Exec list: hostname (2 processes);
[2] proxy: 192.168.0.42 (2 cores) Exec list: hostname (2 processes);
[3] proxy: 192.168.0.43 (2 cores) Exec list: hostname (2 processes);
[mpiexec@mpi1] Timeout set to -1 (-1 means infinite) [mpiexec@mpi1] Got a control port string of 192.168.0.41:7001
Proxy launch args: /mpi3/C3/mpich-3.0.4/bin/hydra_pmi_proxy --control-port 192.168.0.41:7001 --debug --rmk user --launcher rsh --launcher-exec /usr/bin/rsh-redone-rsh --demux poll --pgid 0 --retries 3 --usize -2 --proxy-id
Arguments being passed to proxy 0: --version 3.0.4 --iface-ip-env-name MPICH_INTERFACE_HOSTNAME --hostname 192.168.0.41 --global-core-map 0,2,6 --pmi-id-map 0,0 --global-process-count 6 --auto-cleanup 1 --pmi-kvsname kvs_12243_0 --pmi-process-mapping (vector,(0,3,2)) --ckpoint-prefix /mpi3/chekpoint/default.chk --ckpoint-num -1 --global-inherited-env 121 'MUMPS=/mpi3/S3/MUMPS_4.10.0' 'LC_PAPER=fi_FI.UTF-8' 'LC_ADDRESS=fi_FI.UTF-8' 'SSH_AGENT_PID=12144' 'LC_MONETARY=fi_FI.UTF-8' 'MUMPS_I=/mpi3/C3/MUMPS_4.10.0' 'HYDRA_DEMUX=select' 'GPG_AGENT_INFO=/tmp/keyring-kJwpJQ/gpg:0:1' 'JPK_LMETISDIR_S5=/mpi3/S3/parmetis-4.0.2' 'TERM=xterm' 'SHELL=/bin/bash' 'XDG_SESSION_COOKIE=6d6390cb56a32b6678c10da600000412-1377606907.629665-1922379047' 'FFT=/mpi3/C3/fftw2' 'HYDRA_ENV=all' 'JPK_NETGEN=/mpi3/C3/netgen_668' 'JPK_VER_S=S3' 'HYDRA_CKPOINTLIB=blcr' 'HYDRA_CKPOINT_INTERVAL=10800' 'WINDOWID=54602522' 'LC_NUMERIC=fi_FI.UTF-8' 'HYDRA_CKPOINT_PREFIX=/mpi3/chekpoint/default.chk' 'GNOME_KEYRING_CONTROL=/tmp/keyring-kJwpJQ' 'JPK_ELMER=/mpi3/C3/elmer_6283' 'PARDISO_LIC_PATH=/mpi3/C3/pardiso' 'METIS_INCLUDE_DIR=/mpi3/C3/ParMetis-3.2.0' 'JPK_NETGEN_S=/mpi3/S3/netgen_668' 'USER=joni' 'LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:' 'JPK_TOGL=/mpi3/C3/Togl-1.7' 'LD_LIBRARY_PATH=/mpi3/C3/mpich-3.0.4/lib:/mpi3/C3/mpich-3.0.4/bin:/mpi3/C3/blcr-0.8.5/lib:/mpi3/C3/ParMetis-3.2.0:/mpi3/C3/acml5.3.1/gfortran64_mp/lib:/lib:/mpi3/C3/hypre-2.8.0b/lib:/mpi3/C3/scotch_6.0.0/lib:/mpi3/S3/MUMPS_4.10.0/lib:/mpi3/C3/acml5.3.1/gfortran64_mp/lib:/mpi3/C3/scalapack-2.0.2/lib:/mpi3/C3/hypre-2.8.0b/lib:/mpi3/C3/pardiso:/mpi3/C3/ParMetis-3.2.0:/mpi3/C3/ARPACK:/mpi3/C3/hdf5-1.8.10-patch1/lib:/mpi3/C3/VTK-5.8.0/lib/vtk-5.8:/mpi3/C3/elmer_6283/lib:/mpi3/C3/Togl-1.7:/mpi3/C3/netgen_668/lib:/usr/lib/:/usr/local/lib://mpi3/C3/vrpn/lib://mpi3/C3/hidapi/lib:/usr/include/libusb-1.0' 'LC_TELEPHONE=fi_FI.UTF-8' 'XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0' 'JPK_OCC=/usr/include/oce' 'XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0' 'HYDRA_HOST_FILE=/mpi4/hosts' 'SSH_AUTH_SOCK=/tmp/ssh-NnhxNTH12143/agent.12143' 'SCOTCHDIR=/mpi3/C3/scotch_6.0.0' 'HYDRA_LAUNCHER=rsh' 'JPK_VER_B=B3' 'SESSION_MANAGER=local/mpi1:@/tmp/.ICE-unix/4284,unix/mpi1:/tmp/.ICE-unix/4284' 'DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path' 'ELMER_HOME=/mpi3/C3/elmer_6283' 'BLACS=/mpi3/C3/scalapack-2.0.2' 'BLAS32=/mpi3/C3/acml5.3.1/gfortran64_mp' 'METIS_DIR=' 'MPI_LIBS=-L/mpi3/C3/mpich-3.0.4/lib -lmpich -lmpichf90 -lmpl -lopa -lmpichcxx' 'XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg' 'JPK_MPI_DIR=/mpi3' 'JPK_HDF5_S=/mpi3/S3/hdf5-1.8.10-patch1' 'MPIEXEC_PORT_RANGE=7000:7500' 'PATH=/mpi3/C3/cmake-2.8.10.2/bin:/mpi3/C3/blcr-0.8.5/bin:/mpi3/C3/mpich-3.0.4/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/mpi3/C3/elmer_6283/bin:/mpi3/C3/elmer_6283/lib:/mpi3/C3/ParaView3' 'DESKTOP_SESSION=ubuntu' 'BLAS=/mpi3/C3/acml5.3.1/gfortran64_mp' 'METIS_LIBDIR=/mpi3/C3/ParMetis-3.2.0' 'CMAKE_COMMAND=/mpi3/C3/cmake-2.8.10.2/bin' 'QT_QMAKE_EXECUTABLE=/usr/bin/qmake-qt4' 'LC_IDENTIFICATION=fi_FI.UTF-8' 'JPK_SCOTCHDIR_S=/mpi3/S3/scotch_6.0.0_esmumps' 'JPK_LMETISDIR_S=/mpi3/S3/ParMetis-3.2.0' 'PWD=/mpi3/S3/mpich-3.0.4' 'NETGENDIR=/mpi3/C3/netgen_668/bin' 'EDITOR=nano' 'JPK_LMETISDIR=/mpi3/C3/ParMetis-3.2.0' 'GNOME_KEYRING_PID=4273' 'LANG=fi_FI.UTF-8' 'MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path' 'OMPI_77=//mpi3/C3/mpich-3.0.4/bin/mpif77' 'LC_MEASUREMENT=fi_FI.UTF-8' 'JPK_HDF5=/mpi3/C3/hdf5-1.8.10-patch1' 'UBUNTU_MENUPROXY=libappmenu.so' 'COMPIZ_CONFIG_PROFILE=ubuntu' 'ELMER_POST_HOME=/mpi3/C3/elmer_6283/bin' 'JPK_INS=/mpi3/C3' 'ELMER_LIB=/mpi3/C3/elmer_6283/share/elmersolver/lib' 'HYDRA_PROXY_RETRY_COUNT=3' 'GDMSESSION=ubuntu' 'JPK_ELMER_S=/mpi3/S3/elmer_6283' 'JPK_LMETISDIR5=/mpi3/C3/parmetis-4.0.2' 'JPK_LMETISDIR32=/mpi3/C3/ParMetis-3.2.0' 'HYDRA_DEBUG=1' 'JPK_BUI=/mpi3/S3' 'VTK_INCLUDEPATH=/mpi3/C3/VTK-5.8.0/include' 'SHLVL=1' 'HOME=/home/joni' 'OMPI_CC=//mpi3/C3/mpich-3.0.4/bin/mpicc' 'LANGUAGE=fi:en' 'OMPI_90=//mpi3/C3/mpich-3.0.4/bin/mpif90' 'ELMERGUI_HOME=/mpi3/C3/elmer_6283/bin' 'GNOME_DESKTOP_SESSION_ID=this-is-deprecated' 'MPI_IMPLEMENTATION=mpich' 'MKL_SERIAL=YES' 'LOGNAME=joni' 'HYPRE=/mpi3/C3/hypre-2.8.0b' 'JPK_ARPACK_S=/mpi3/S3/ARPACK' 'JPK_JOBS=7' 'JPK_VTK_DIR=/mpi3/C3/VTK-5.8.0' 'SCALAPACK=/mpi3/C3/scalapack-2.0.2' 'XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share/:/usr/share/' 'DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-gAYmjGaklf,guid=26c3f15a7a5ee55e8782415700000034' 'JPK_ARPACK=/mpi3/C3/ARPACK' 'MPI_HOME=/mpi3/C3/mpich-3.0.4' 'LESSOPEN=| /usr/bin/lesspipe %s' 'LACPACK=/mpi3/C3/acml5.3.1/gfortran64_mp' 'OMPI_CXX=//mpi3/C3/mpich-3.0.4/bin/mpicxx' 'OMP_NUM_THREADS=6' 'JPK_TOGL_S=/mpi3/S3/Togl-1.7' 'HYDRA_LAUNCHER_EXEC=/usr/bin/rsh-redone-rsh' 'JPK_MPICH2=/mpi3/C3/mpich-3.0.4' 'PARDISO=/mpi3/C3/pardiso' 'PARDISOLICMESSAGE=1' 'JPK_VER=C3' 'XDG_CURRENT_DESKTOP=Unity' 'LESSCLOSE=/usr/bin/lesspipe %s %s' 'LC_TIME=fi_FI.UTF-8' 'JPK_HYPRE_S=/mpi3/S3/hypre-2.8.0b' 'JPK_MPICH2_S=/mpi3/S3/mpich-3.0.4' 'COLORTERM=gnome-terminal' 'XAUTHORITY=/home/joni/.Xauthority' 'LC_NAME=fi_FI.UTF-8' '_=/mpi3/C3/mpich-3.0.4/bin/mpiexec' 'OLDPWD=/home/joni' --global-user-env 0 --global-system-env 2 'MPICH_ENABLE_CKPOINT=1' 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --genv-prop all --proxy-core-count 2 --exec --exec-appnum 0 --exec-proc-count 2 --exec-local-env 0 --exec-wdir /mpi3/S3/mpich-3.0.4 --exec-args 1 hostname
Arguments being passed to proxy 1: --version 3.0.4 --iface-ip-env-name MPICH_INTERFACE_HOSTNAME --hostname 192.168.0.42 --global-core-map 0,2,6 --pmi-id-map 0,2 --global-process-count 6 --auto-cleanup 1 --pmi-kvsname kvs_12243_0 --pmi-process-mapping (vector,(0,3,2)) --ckpoint-prefix /mpi3/chekpoint/default.chk --ckpoint-num -1 --global-inherited-env 121 'MUMPS=/mpi3/S3/MUMPS_4.10.0' 'LC_PAPER=fi_FI.UTF-8' 'LC_ADDRESS=fi_FI.UTF-8' 'SSH_AGENT_PID=12144' 'LC_MONETARY=fi_FI.UTF-8' 'MUMPS_I=/mpi3/C3/MUMPS_4.10.0' 'HYDRA_DEMUX=select' 'GPG_AGENT_INFO=/tmp/keyring-kJwpJQ/gpg:0:1' 'JPK_LMETISDIR_S5=/mpi3/S3/parmetis-4.0.2' 'TERM=xterm' 'SHELL=/bin/bash' 'XDG_SESSION_COOKIE=6d6390cb56a32b6678c10da600000412-1377606907.629665-1922379047' 'FFT=/mpi3/C3/fftw2' 'HYDRA_ENV=all' 'JPK_NETGEN=/mpi3/C3/netgen_668' 'JPK_VER_S=S3' 'HYDRA_CKPOINTLIB=blcr' 'HYDRA_CKPOINT_INTERVAL=10800' 'WINDOWID=54602522' 'LC_NUMERIC=fi_FI.UTF-8' 'HYDRA_CKPOINT_PREFIX=/mpi3/chekpoint/default.chk' 'GNOME_KEYRING_CONTROL=/tmp/keyring-kJwpJQ' 'JPK_ELMER=/mpi3/C3/elmer_6283' 'PARDISO_LIC_PATH=/mpi3/C3/pardiso' 'METIS_INCLUDE_DIR=/mpi3/C3/ParMetis-3.2.0' 'JPK_NETGEN_S=/mpi3/S3/netgen_668' 'USER=joni' 'LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:' 'JPK_TOGL=/mpi3/C3/Togl-1.7' 'LD_LIBRARY_PATH=/mpi3/C3/mpich-3.0.4/lib:/mpi3/C3/mpich-3.0.4/bin:/mpi3/C3/blcr-0.8.5/lib:/mpi3/C3/ParMetis-3.2.0:/mpi3/C3/acml5.3.1/gfortran64_mp/lib:/lib:/mpi3/C3/hypre-2.8.0b/lib:/mpi3/C3/scotch_6.0.0/lib:/mpi3/S3/MUMPS_4.10.0/lib:/mpi3/C3/acml5.3.1/gfortran64_mp/lib:/mpi3/C3/scalapack-2.0.2/lib:/mpi3/C3/hypre-2.8.0b/lib:/mpi3/C3/pardiso:/mpi3/C3/ParMetis-3.2.0:/mpi3/C3/ARPACK:/mpi3/C3/hdf5-1.8.10-patch1/lib:/mpi3/C3/VTK-5.8.0/lib/vtk-5.8:/mpi3/C3/elmer_6283/lib:/mpi3/C3/Togl-1.7:/mpi3/C3/netgen_668/lib:/usr/lib/:/usr/local/lib://mpi3/C3/vrpn/lib://mpi3/C3/hidapi/lib:/usr/include/libusb-1.0' 'LC_TELEPHONE=fi_FI.UTF-8' 'XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0' 'JPK_OCC=/usr/include/oce' 'XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0' 'HYDRA_HOST_FILE=/mpi4/hosts' 'SSH_AUTH_SOCK=/tmp/ssh-NnhxNTH12143/agent.12143' 'SCOTCHDIR=/mpi3/C3/scotch_6.0.0' 'HYDRA_LAUNCHER=rsh' 'JPK_VER_B=B3' 'SESSION_MANAGER=local/mpi1:@/tmp/.ICE-unix/4284,unix/mpi1:/tmp/.ICE-unix/4284' 'DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path' 'ELMER_HOME=/mpi3/C3/elmer_6283' 'BLACS=/mpi3/C3/scalapack-2.0.2' 'BLAS32=/mpi3/C3/acml5.3.1/gfortran64_mp' 'METIS_DIR=' 'MPI_LIBS=-L/mpi3/C3/mpich-3.0.4/lib -lmpich -lmpichf90 -lmpl -lopa -lmpichcxx' 'XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg' 'JPK_MPI_DIR=/mpi3' 'JPK_HDF5_S=/mpi3/S3/hdf5-1.8.10-patch1' 'MPIEXEC_PORT_RANGE=7000:7500' 'PATH=/mpi3/C3/cmake-2.8.10.2/bin:/mpi3/C3/blcr-0.8.5/bin:/mpi3/C3/mpich-3.0.4/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/mpi3/C3/elmer_6283/bin:/mpi3/C3/elmer_6283/lib:/mpi3/C3/ParaView3' 'DESKTOP_SESSION=ubuntu' 'BLAS=/mpi3/C3/acml5.3.1/gfortran64_mp' 'METIS_LIBDIR=/mpi3/C3/ParMetis-3.2.0' 'CMAKE_COMMAND=/mpi3/C3/cmake-2.8.10.2/bin' 'QT_QMAKE_EXECUTABLE=/usr/bin/qmake-qt4' 'LC_IDENTIFICATION=fi_FI.UTF-8' 'JPK_SCOTCHDIR_S=/mpi3/S3/scotch_6.0.0_esmumps' 'JPK_LMETISDIR_S=/mpi3/S3/ParMetis-3.2.0' 'PWD=/mpi3/S3/mpich-3.0.4' 'NETGENDIR=/mpi3/C3/netgen_668/bin' 'EDITOR=nano' 'JPK_LMETISDIR=/mpi3/C3/ParMetis-3.2.0' 'GNOME_KEYRING_PID=4273' 'LANG=fi_FI.UTF-8' 'MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path' 'OMPI_77=//mpi3/C3/mpich-3.0.4/bin/mpif77' 'LC_MEASUREMENT=fi_FI.UTF-8' 'JPK_HDF5=/mpi3/C3/hdf5-1.8.10-patch1' 'UBUNTU_MENUPROXY=libappmenu.so' 'COMPIZ_CONFIG_PROFILE=ubuntu' 'ELMER_POST_HOME=/mpi3/C3/elmer_6283/bin' 'JPK_INS=/mpi3/C3' 'ELMER_LIB=/mpi3/C3/elmer_6283/share/elmersolver/lib' 'HYDRA_PROXY_RETRY_COUNT=3' 'GDMSESSION=ubuntu' 'JPK_ELMER_S=/mpi3/S3/elmer_6283' 'JPK_LMETISDIR5=/mpi3/C3/parmetis-4.0.2' 'JPK_LMETISDIR32=/mpi3/C3/ParMetis-3.2.0' 'HYDRA_DEBUG=1' 'JPK_BUI=/mpi3/S3' 'VTK_INCLUDEPATH=/mpi3/C3/VTK-5.8.0/include' 'SHLVL=1' 'HOME=/home/joni' 'OMPI_CC=//mpi3/C3/mpich-3.0.4/bin/mpicc' 'LANGUAGE=fi:en' 'OMPI_90=//mpi3/C3/mpich-3.0.4/bin/mpif90' 'ELMERGUI_HOME=/mpi3/C3/elmer_6283/bin' 'GNOME_DESKTOP_SESSION_ID=this-is-deprecated' 'MPI_IMPLEMENTATION=mpich' 'MKL_SERIAL=YES' 'LOGNAME=joni' 'HYPRE=/mpi3/C3/hypre-2.8.0b' 'JPK_ARPACK_S=/mpi3/S3/ARPACK' 'JPK_JOBS=7' 'JPK_VTK_DIR=/mpi3/C3/VTK-5.8.0' 'SCALAPACK=/mpi3/C3/scalapack-2.0.2' 'XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share/:/usr/share/' 'DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-gAYmjGaklf,guid=26c3f15a7a5ee55e8782415700000034' 'JPK_ARPACK=/mpi3/C3/ARPACK' 'MPI_HOME=/mpi3/C3/mpich-3.0.4' 'LESSOPEN=| /usr/bin/lesspipe %s' 'LACPACK=/mpi3/C3/acml5.3.1/gfortran64_mp' 'OMPI_CXX=//mpi3/C3/mpich-3.0.4/bin/mpicxx' 'OMP_NUM_THREADS=6' 'JPK_TOGL_S=/mpi3/S3/Togl-1.7' 'HYDRA_LAUNCHER_EXEC=/usr/bin/rsh-redone-rsh' 'JPK_MPICH2=/mpi3/C3/mpich-3.0.4' 'PARDISO=/mpi3/C3/pardiso' 'PARDISOLICMESSAGE=1' 'JPK_VER=C3' 'XDG_CURRENT_DESKTOP=Unity' 'LESSCLOSE=/usr/bin/lesspipe %s %s' 'LC_TIME=fi_FI.UTF-8' 'JPK_HYPRE_S=/mpi3/S3/hypre-2.8.0b' 'JPK_MPICH2_S=/mpi3/S3/mpich-3.0.4' 'COLORTERM=gnome-terminal' 'XAUTHORITY=/home/joni/.Xauthority' 'LC_NAME=fi_FI.UTF-8' '_=/mpi3/C3/mpich-3.0.4/bin/mpiexec' 'OLDPWD=/home/joni' --global-user-env 0 --global-system-env 2 'MPICH_ENABLE_CKPOINT=1' 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --genv-prop all --proxy-core-count 2 --exec --exec-appnum 0 --exec-proc-count 2 --exec-local-env 0 --exec-wdir /mpi3/S3/mpich-3.0.4 --exec-args 1 hostname
Arguments being passed to proxy 2: --version 3.0.4 --iface-ip-env-name MPICH_INTERFACE_HOSTNAME --hostname 192.168.0.43 --global-core-map 0,2,6 --pmi-id-map 0,4 --global-process-count 6 --auto-cleanup 1 --pmi-kvsname kvs_12243_0 --pmi-process-mapping (vector,(0,3,2)) --ckpoint-prefix /mpi3/chekpoint/default.chk --ckpoint-num -1 --global-inherited-env 121 'MUMPS=/mpi3/S3/MUMPS_4.10.0' 'LC_PAPER=fi_FI.UTF-8' 'LC_ADDRESS=fi_FI.UTF-8' 'SSH_AGENT_PID=12144' 'LC_MONETARY=fi_FI.UTF-8' 'MUMPS_I=/mpi3/C3/MUMPS_4.10.0' 'HYDRA_DEMUX=select' 'GPG_AGENT_INFO=/tmp/keyring-kJwpJQ/gpg:0:1' 'JPK_LMETISDIR_S5=/mpi3/S3/parmetis-4.0.2' 'TERM=xterm' 'SHELL=/bin/bash' 'XDG_SESSION_COOKIE=6d6390cb56a32b6678c10da600000412-1377606907.629665-1922379047' 'FFT=/mpi3/C3/fftw2' 'HYDRA_ENV=all' 'JPK_NETGEN=/mpi3/C3/netgen_668' 'JPK_VER_S=S3' 'HYDRA_CKPOINTLIB=blcr' 'HYDRA_CKPOINT_INTERVAL=10800' 'WINDOWID=54602522' 'LC_NUMERIC=fi_FI.UTF-8' 'HYDRA_CKPOINT_PREFIX=/mpi3/chekpoint/default.chk' 'GNOME_KEYRING_CONTROL=/tmp/keyring-kJwpJQ' 'JPK_ELMER=/mpi3/C3/elmer_6283' 'PARDISO_LIC_PATH=/mpi3/C3/pardiso' 'METIS_INCLUDE_DIR=/mpi3/C3/ParMetis-3.2.0' 'JPK_NETGEN_S=/mpi3/S3/netgen_668' 'USER=joni' 'LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:' 'JPK_TOGL=/mpi3/C3/Togl-1.7' 'LD_LIBRARY_PATH=/mpi3/C3/mpich-3.0.4/lib:/mpi3/C3/mpich-3.0.4/bin:/mpi3/C3/blcr-0.8.5/lib:/mpi3/C3/ParMetis-3.2.0:/mpi3/C3/acml5.3.1/gfortran64_mp/lib:/lib:/mpi3/C3/hypre-2.8.0b/lib:/mpi3/C3/scotch_6.0.0/lib:/mpi3/S3/MUMPS_4.10.0/lib:/mpi3/C3/acml5.3.1/gfortran64_mp/lib:/mpi3/C3/scalapack-2.0.2/lib:/mpi3/C3/hypre-2.8.0b/lib:/mpi3/C3/pardiso:/mpi3/C3/ParMetis-3.2.0:/mpi3/C3/ARPACK:/mpi3/C3/hdf5-1.8.10-patch1/lib:/mpi3/C3/VTK-5.8.0/lib/vtk-5.8:/mpi3/C3/elmer_6283/lib:/mpi3/C3/Togl-1.7:/mpi3/C3/netgen_668/lib:/usr/lib/:/usr/local/lib://mpi3/C3/vrpn/lib://mpi3/C3/hidapi/lib:/usr/include/libusb-1.0' 'LC_TELEPHONE=fi_FI.UTF-8' 'XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0' 'JPK_OCC=/usr/include/oce' 'XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0' 'HYDRA_HOST_FILE=/mpi4/hosts' 'SSH_AUTH_SOCK=/tmp/ssh-NnhxNTH12143/agent.12143' 'SCOTCHDIR=/mpi3/C3/scotch_6.0.0' 'HYDRA_LAUNCHER=rsh' 'JPK_VER_B=B3' 'SESSION_MANAGER=local/mpi1:@/tmp/.ICE-unix/4284,unix/mpi1:/tmp/.ICE-unix/4284' 'DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path' 'ELMER_HOME=/mpi3/C3/elmer_6283' 'BLACS=/mpi3/C3/scalapack-2.0.2' 'BLAS32=/mpi3/C3/acml5.3.1/gfortran64_mp' 'METIS_DIR=' 'MPI_LIBS=-L/mpi3/C3/mpich-3.0.4/lib -lmpich -lmpichf90 -lmpl -lopa -lmpichcxx' 'XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg' 'JPK_MPI_DIR=/mpi3' 'JPK_HDF5_S=/mpi3/S3/hdf5-1.8.10-patch1' 'MPIEXEC_PORT_RANGE=7000:7500' 'PATH=/mpi3/C3/cmake-2.8.10.2/bin:/mpi3/C3/blcr-0.8.5/bin:/mpi3/C3/mpich-3.0.4/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/mpi3/C3/elmer_6283/bin:/mpi3/C3/elmer_6283/lib:/mpi3/C3/ParaView3' 'DESKTOP_SESSION=ubuntu' 'BLAS=/mpi3/C3/acml5.3.1/gfortran64_mp' 'METIS_LIBDIR=/mpi3/C3/ParMetis-3.2.0' 'CMAKE_COMMAND=/mpi3/C3/cmake-2.8.10.2/bin' 'QT_QMAKE_EXECUTABLE=/usr/bin/qmake-qt4' 'LC_IDENTIFICATION=fi_FI.UTF-8' 'JPK_SCOTCHDIR_S=/mpi3/S3/scotch_6.0.0_esmumps' 'JPK_LMETISDIR_S=/mpi3/S3/ParMetis-3.2.0' 'PWD=/mpi3/S3/mpich-3.0.4' 'NETGENDIR=/mpi3/C3/netgen_668/bin' 'EDITOR=nano' 'JPK_LMETISDIR=/mpi3/C3/ParMetis-3.2.0' 'GNOME_KEYRING_PID=4273' 'LANG=fi_FI.UTF-8' 'MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path' 'OMPI_77=//mpi3/C3/mpich-3.0.4/bin/mpif77' 'LC_MEASUREMENT=fi_FI.UTF-8' 'JPK_HDF5=/mpi3/C3/hdf5-1.8.10-patch1' 'UBUNTU_MENUPROXY=libappmenu.so' 'COMPIZ_CONFIG_PROFILE=ubuntu' 'ELMER_POST_HOME=/mpi3/C3/elmer_6283/bin' 'JPK_INS=/mpi3/C3' 'ELMER_LIB=/mpi3/C3/elmer_6283/share/elmersolver/lib' 'HYDRA_PROXY_RETRY_COUNT=3' 'GDMSESSION=ubuntu' 'JPK_ELMER_S=/mpi3/S3/elmer_6283' 'JPK_LMETISDIR5=/mpi3/C3/parmetis-4.0.2' 'JPK_LMETISDIR32=/mpi3/C3/ParMetis-3.2.0' 'HYDRA_DEBUG=1' 'JPK_BUI=/mpi3/S3' 'VTK_INCLUDEPATH=/mpi3/C3/VTK-5.8.0/include' 'SHLVL=1' 'HOME=/home/joni' 'OMPI_CC=//mpi3/C3/mpich-3.0.4/bin/mpicc' 'LANGUAGE=fi:en' 'OMPI_90=//mpi3/C3/mpich-3.0.4/bin/mpif90' 'ELMERGUI_HOME=/mpi3/C3/elmer_6283/bin' 'GNOME_DESKTOP_SESSION_ID=this-is-deprecated' 'MPI_IMPLEMENTATION=mpich' 'MKL_SERIAL=YES' 'LOGNAME=joni' 'HYPRE=/mpi3/C3/hypre-2.8.0b' 'JPK_ARPACK_S=/mpi3/S3/ARPACK' 'JPK_JOBS=7' 'JPK_VTK_DIR=/mpi3/C3/VTK-5.8.0' 'SCALAPACK=/mpi3/C3/scalapack-2.0.2' 'XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share/:/usr/share/' 'DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-gAYmjGaklf,guid=26c3f15a7a5ee55e8782415700000034' 'JPK_ARPACK=/mpi3/C3/ARPACK' 'MPI_HOME=/mpi3/C3/mpich-3.0.4' 'LESSOPEN=| /usr/bin/lesspipe %s' 'LACPACK=/mpi3/C3/acml5.3.1/gfortran64_mp' 'OMPI_CXX=//mpi3/C3/mpich-3.0.4/bin/mpicxx' 'OMP_NUM_THREADS=6' 'JPK_TOGL_S=/mpi3/S3/Togl-1.7' 'HYDRA_LAUNCHER_EXEC=/usr/bin/rsh-redone-rsh' 'JPK_MPICH2=/mpi3/C3/mpich-3.0.4' 'PARDISO=/mpi3/C3/pardiso' 'PARDISOLICMESSAGE=1' 'JPK_VER=C3' 'XDG_CURRENT_DESKTOP=Unity' 'LESSCLOSE=/usr/bin/lesspipe %s %s' 'LC_TIME=fi_FI.UTF-8' 'JPK_HYPRE_S=/mpi3/S3/hypre-2.8.0b' 'JPK_MPICH2_S=/mpi3/S3/mpich-3.0.4' 'COLORTERM=gnome-terminal' 'XAUTHORITY=/home/joni/.Xauthority' 'LC_NAME=fi_FI.UTF-8' '_=/mpi3/C3/mpich-3.0.4/bin/mpiexec' 'OLDPWD=/home/joni' --global-user-env 0 --global-system-env 2 'MPICH_ENABLE_CKPOINT=1' 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --genv-prop all --proxy-core-count 2 --exec --exec-appnum 0 --exec-proc-count 2 --exec-local-env 0 --exec-wdir /mpi3/S3/mpich-3.0.4 --exec-args 1 hostname
[mpiexec@mpi1] Launch arguments: /mpi3/C3/mpich-3.0.4/bin/hydra_pmi_proxy --control-port 192.168.0.41:7001 --debug --rmk user --launcher rsh --launcher-exec /usr/bin/rsh-redone-rsh --demux poll --pgid 0 --retries 3 --usize -2 --proxy-id 0 [mpiexec@mpi1] Launch arguments: /usr/bin/rsh-redone-rsh 192.168.0.42 "/mpi3/C3/mpich-3.0.4/bin/hydra_pmi_proxy" --control-port 192.168.0.41:7001 --debug --rmk user --launcher rsh --launcher-exec /usr/bin/rsh-redone-rsh --demux poll --pgid 0 --retries 3 --usize -2 --proxy-id 1 [mpiexec@mpi1] Launch arguments: /usr/bin/rsh-redone-rsh 192.168.0.43 "/mpi3/C3/mpich-3.0.4/bin/hydra_pmi_proxy" --control-port 192.168.0.41:7001 --debug --rmk user --launcher rsh --launcher-exec /usr/bin/rsh-redone-rsh --demux poll --pgid 0 --retries 3 --usize -2 --proxy-id 2 mpi1 m
2013/8/27 Pavan Balaji <[email protected]>
Please don't drop [email protected] from the cc list.
I doubt demux, --assert-level and blcr are relevant here. Also, the output of "make testing" is not helpful for us because those tests can fail even if your machines are too slow.
Did you try my suggestion from the previous email? Could you try them and report back (just with that information)?
-- Pavan
On 08/27/2013 09:35 AM, Joni-Pekka Kurronen wrote:
hi,
I have allraedy cheked up. This is not new install, just jumped up from mpich2 to 3 and gcc 4.6 to gcc 4.7.
I have rsh-redone-rsh as main but tested ssh as well,... due at crash clinet's keep running at slave's and useing harddisk,...
Following work's: any machine alone mpi1 and kaak or mpi1 and ugh but not all to gether except hostname,...
This could be realated: - demux ( have tried select and poll, whit poll have to restart slave machine's) - nfs4 ( some reason nfs4 must be manually mounted at moment after restart at slave's) - have changed --assert-level to 0 (default 2) - blcr
ch3:socket setting:
============= hosts file,.. 192.168.0.41:2 <http://192.168.0.41:2> 192.168.0.42:2 <http://192.168.0.42:2> #192.168.0.43:2 <http://192.168.0.43:2>
============= summary.xml errors <MPITEST> <NAME>spawninfo1</NAME> <NP>1</NP> <WORKDIR>./spawn</WORKDIR> <STATUS>fail</STATUS> <TESTDIFF> [mpiexec@mpi1] APPLICATION TIMED OUT [proxy:0:0@mpi1] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:886): assert (!closed) failed [proxy:0:0@mpi1] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:**77): callback returned error status [proxy:0:0@mpi1] main (./pm/pmiserv/pmip.c:206): demux engine error waiting for event [proxy:1:0@mpi1] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:886): assert (!closed) failed [proxy:1:0@mpi1] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:**77): callback returned error status [proxy:1:0@mpi1] main (./pm/pmiserv/pmip.c:206): demux engine error waiting for event [mpiexec@mpi1] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_**wait.c:76): one of the processes terminated badly; aborting [mpiexec@mpi1] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_**wait.c:23): launcher returned error waiting for completion [mpiexec@mpi1] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:**188): launcher returned error waiting for completion [mpiexec@mpi1] main (./ui/mpich/mpiexec.c:331): process manager error waiting for completion </TESTDIFF> </MPITEST> <MPITEST> <NAME>rdwrord</NAME> <NP>4</NP> <WORKDIR>./io</WORKDIR> <STATUS>fail</STATUS> <TESTDIFF> Fatal error in PMPI_Bcast: Other MPI error [cli_2]: aborting job: Fatal error in PMPI_Bcast: Other MPI error Fatal error in PMPI_Bcast: Other MPI error [cli_0]: aborting job: Fatal error in PMPI_Bcast: Other MPI error
==============================**==============================** ======================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ==============================**==============================** ======================= </TESTDIFF> </MPITEST> <MPITEST> <NAME>rdwrzero</NAME> <NP>4</NP> <WORKDIR>./io</WORKDIR> <STATUS>fail</STATUS> <TESTDIFF> Fatal error in PMPI_Bcast: Other MPI error [cli_2]: aborting job: Fatal error in PMPI_Bcast: Other MPI error Fatal error in PMPI_Bcast: Other MPI error [cli_0]: aborting job: Fatal error in PMPI_Bcast: Other MPI error
==============================**==============================** ======================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ==============================**==============================** ======================= </TESTDIFF> </MPITEST> <MPITEST> <NAME>getextent</NAME> <NP>2</NP> <WORKDIR>./io</WORKDIR> <STATUS>pass</STATUS> </MPITEST> <MPITEST> <NAME>setinfo</NAME> <NP>4</NP> <WORKDIR>./io</WORKDIR> <STATUS>fail</STATUS> <TESTDIFF> Fatal error in PMPI_Bcast: Other MPI error [cli_2]: aborting job: Fatal error in PMPI_Bcast: Other MPI error Fatal error in PMPI_Bcast: Other MPI error [cli_0]: aborting job: Fatal error in PMPI_Bcast: Other MPI error
==============================**==============================** ======================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ==============================**==============================** ======================= </TESTDIFF> </MPITEST> <MPITEST> <NAME>setviewcur</NAME> <NP>4</NP> <WORKDIR>./io</WORKDIR> <STATUS>fail</STATUS> <TESTDIFF> Fatal error in PMPI_Bcast: Other MPI error [cli_2]: aborting job: Fatal error in PMPI_Bcast: Other MPI error Fatal error in PMPI_Bcast: Other MPI error [cli_0]: aborting job: Fatal error in PMPI_Bcast: Other MPI error
============ ============ hosts file,.. 192.168.0.41:2 <http://192.168.0.41:2> 192.168.0.42:2 <http://192.168.0.42:2> 192.168.0.43:2 <http://192.168.0.43:2>
When needed more than 4 process will hang,..
Unexpected output in allred3: [mpiexec@mpi1] APPLICATION TIMED OUT Unexpected output in allred3: [proxy:0:0@mpi1] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:886): assert (!closed) failed Unexpected output in allred3: [proxy:0:0@mpi1] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:**77): callback returned error status Unexpected output in allred3: [proxy:0:0@mpi1] main (./pm/pmiserv/pmip.c:206): demux engine error waiting for event
if useing ch3:nemesis hardisk is not running all the time as whit sockets's,...
==============================**================== This is read by rsh-redone-rsh for every process,... ==============================**================== #!/bin/bash
# JPK-Integration for Ubuntu 12.4 LTS # https://sites.google.com/site/**jpsdatareviewstheboy007/** ubuntu-lts-12-4-companion-**whit-ltsp-mpich2-elmer-**openfoam<https://sites.google.com/site/jpsdatareviewstheboy007/ubuntu-lts-12-4-companion-whit-ltsp-mpich2-elmer-openfoam> # # CMAKE goes loop and can not build, cmake build under development says documentation
# gcc 4.7 # bdver1 optimization
shopt -s expand_aliases export JPK_MPI_DIR=/mpi3 # MAIN DIRECTORY, SUBDIRCTORYES: export JPK_VER=C3 # BINARY CODE export JPK_VER_S=S3 # SOURCE CODE export JPK_VER_B=B3 # BASH FILES TO COMPILE AND CONFIGURE export JPK_INS=$JPK_MPI_DIR/$JPK_VER export JPK_BUI=$JPK_MPI_DIR/$JPK_VER_**S export JPK_ELMER=$JPK_INS/elmer_6283 #035 export JPK_ELMER_S=$JPK_BUI/elmer_**6283 export JPK_NETGEN_S=$JPK_BUI/netgen_**668 export JPK_NETGEN=$JPK_INS/netgen_668
#GCC #export JPK_FLAGS="-Wl,--no-as-needed -fPIC -DAdd_ -m64 -pthread -O3 -fopenmp -lgomp -march=bdver1 -ftree-vectorize -funroll-loops" #export CFLAGS="-Wl,--no-as-needed -fPIC -DAdd_ -m64 -pthread -fopenmp -lgomp"
# M A K E
export JPK_JOBS=7
# O P E N MP export OMP_NUM_THREADS=6
# M P I C 3 # http://wiki.mcs.anl.gov/**mpich2/index.php/Using_the_** Hydra_Process_Manager<http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager> export JPK_MPICH2_S=$JPK_BUI/mpich-3.**0.4 export JPK_MPICH2=$JPK_INS/mpich-3.0.**4 export PATH=$JPK_MPICH2/bin:$PATH export MPI_HOME=$JPK_MPICH2 export MPI_LIBS="-L$JPK_MPICH2/lib -lmpich -lmpichf90 -lmpl -lopa -lmpichcxx" export LD_LIBRARY_PATH=$JPK_MPICH2/**lib:$JPK_MPICH2/bin # FIRST
# M P I
export MPI_IMPLEMENTATION=mpich
export OMPI_CC=/$JPK_MPI_DIR/$JPK_**VER/mpich-3.0.4/bin/mpicc export OMPI_CXX=/$JPK_MPI_DIR/$JPK_**VER/mpich-3.0.4/bin/mpicxx export OMPI_77=/$JPK_MPI_DIR/$JPK_**VER/mpich-3.0.4/bin/mpif77 export OMPI_90=/$JPK_MPI_DIR/$JPK_**VER/mpich-3.0.4/bin/mpif90
# http://wiki.mcs.anl.gov/**mpich2/index.php/Using_the_** Hydra_Process_Manager<http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager> export HYDRA_DEBUG=0 export HYDRA_HOST_FILE=/mpi4/hosts export HYDRA_LAUNCHER=rsh #export HYDRA_LAUNCHER=ssh #export HYDRA_LAUNCHER_EXEC=/usr/bin/**netkit-rsh export HYDRA_LAUNCHER_EXEC=/usr/bin/**rsh-redone-rsh #export HYDRA_LAUNCHER_EXEC=/usr/bin/**ssh export HYDRA_DEMUX=select #export HYDRA_DEMUX=select #more porseses than core's export HYDRA_PROXY_RETRY_COUNT=3 #export HYDRA_RMK=pbs #export HYDRA_DEFAULT_RMK=pbs export HYDRA_ENV=all export MPIEXEC_PORT_RANGE=7000:7500 #mpirun -launcher rsh -launcher-exec /usr/bin/netkit-rsh -demux select -n 21 ddd ./cpi
# b l c r
export HYDRA_CKPOINTLIB=blcr export HYDRA_CKPOINT_PREFIX=/mpi3/**chekpoint/default.chk export HYDRA_CKPOINT_INTERVAL=10800 export PATH=$JPK_INS/blcr-0.8.5/bin:$**PATH export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$JPK_INS/blcr-0.8.5/lib #-ckpoint-num 5
# C M A K E - BUILD export PATH=$JPK_INS/cmake-2.8.10.2/**bin:$PATH export CMAKE_COMMAND=$JPK_INS/cmake-**2.8.10.2/bin
# T O G L - UI netgen
export JPK_TOGL="$JPK_INS/Togl-1.7" export JPK_TOGL_S="$JPK_BUI/Togl-1.7"
# OCC export JPK_OCC=/usr/include/oce
# M A T H
export JPK_ARPACK_S=$JPK_BUI/ARPACK export JPK_ARPACK=$JPK_INS/ARPACK
export BLAS=$JPK_INS/acml5.3.1/**gfortran64_mp export BLAS32=$JPK_INS/acml5.3.1/**gfortran64_mp #export BLAS=$JPK_INS/clAmdBlas-1.10.**321/lib64 #export BLAS32=$JPK_INS/clAmdBlas-1.**10.321/include export FFT=$JPK_INS/fftw2 export LACPACK=$BLAS export SCALAPACK=$JPK_INS/scalapack-**2.0.2 export BLACS=$SCALAPACK
export JPK_LMETISDIR_S=$JPK_BUI/**ParMetis-3.2.0 export JPK_LMETISDIR=$JPK_INS/**ParMetis-3.2.0 export JPK_LMETISDIR32=$JPK_LMETISDIR export JPK_LMETISDIR_S5=$JPK_BUI/**parmetis-4.0.2 export JPK_LMETISDIR5=$JPK_INS/**parmetis-4.0.2
export METIS_DIR="" #$JPK_LMETISDIR MUST BE EMPTY export METIS_INCLUDE_DIR=$JPK_**LMETISDIR export METIS_LIBDIR=$JPK_LMETISDIR export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$JPK_LMETISDIR:$BLAS/lib:** $FTT/lib #/mpi4/S/metis-5.0.2/GKlib
export SCOTCHDIR=$JPK_INS/scotch_6.0.**0 export JPK_SCOTCHDIR_S=$JPK_BUI/**scotch_6.0.0_esmumps
export MUMPS_I=$JPK_INS/MUMPS_4.10.0 export MUMPS=$JPK_BUI/MUMPS_4.10.0
export HYPRE=$JPK_INS/hypre-2.8.0b export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$HYPRE/lib export JPK_HYPRE_S=$JPK_BUI/hypre-2.**8.0b
export PARDISOLICMESSAGE=1 export PARDISO=$JPK_INS/pardiso export PARDISO_LIC_PATH=$PARDISO export MKL_SERIAL=YES
export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$SCOTCHDIR/lib:$MUMPS/** lib:$BLAS/lib:$SCALAPACK/lib:$**HYPRE/lib:$PARDISO:$METIS_** LIBDIR:$JPK_ARPACK
#HDF5 #export JPK_HDF5_S=$JPK_BUI/hdf5-1.8.**10-patch1 for vtk testing #export JPK_HDF5=$JPK_INS/hdf5-1.8.10-**patch1 export JPK_HDF5_S=$JPK_BUI/hdf5-1.8.**10-patch1 export JPK_HDF5=$JPK_INS/hdf5-1.8.10-**patch1 export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$JPK_HDF5/lib
# V T K export JPK_VTK_DIR=$JPK_INS/VTK-5.8.0 export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$JPK_VTK_DIR/lib/vtk-5.8 export VTK_INCLUDEPATH=$JPK_VTK_DIR/**include
# Q T export QT_QMAKE_EXECUTABLE=/usr/bin/**qmake-qt4
# O P E N F O A M # http://www.openfoam.org/**download/source.php<http://www.openfoam.org/download/source.php>
#export WM_SCHEDULER=wmakeScheduler #export WM_HOSTS="192.168.0.41:6 <http://192.168.0.41:6> 192.168.0.42:6 <http://192.168.0.42:6> 192.168.0.43:6 <http://192.168.0.43:6>"
#export WM_NCOMPPROCS=$($WM_SCHEDULER -count) #export WM_COLOURS="black blue green cyan red magenta yellow"
#export FOAM_INST_DIR=/mpi2/OpenFOAM #foamDotFile=$FOAM_INST_DIR/**OpenFOAM-2.1.x/etc/bashrc #[ -f $foamDotFile ] && . $foamDotFile #source /mpi3/OpenFOAM/OpenFOAM-2.1.x/**etc/bashrc
#export FOAM_RUN=/mpi2/om #export OpenBIN=/mpi2/OpenFOAM/**OpenFOAM-2.1.x/bin/tools #export PATH=OpenBIN$:$PATH #export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:/apps/OpenFOAM/tools/**lib64
#export ParaView_DIR=/mpi2/OpenFOAM/**ThirdParty-2.1.x/platforms/** linux64Gcc/paraview-3.12.0 #export PATH=$ParaView_DIR/bin:$PATH #export PV_PLUGIN_PATH=$FOAM_LIBBIN/**paraview-3.12
# E L M E R export ELMER_HOME=$JPK_ELMER export ELMER_LIB=$JPK_ELMER/share/**elmersolver/lib export PATH=$PATH:$ELMER_HOME/bin:$**ELMER_HOME/lib export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$ELMER_HOME/lib export ELMERGUI_HOME=$ELMER_HOME/bin export ELMER_POST_HOME=$ELMER_HOME/**bin
# S a l o m é #cd /mpi2/salome-meca/SALOME-MECA-**2012.2-LGPL ; source envSalomeMeca.sh #cd ~/
# Paraview #export PATH=$PATH:$JPK_INS/ParaView-**3.14.1-Linux-64bit export PATH=$PATH:$JPK_INS/ParaView3
# N E T G E N P A R A L L E L $JPK_TCL/lib:$JPK_TK/lib: #export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$JPK_TOGL:$JPK_NETGEN\** par/lib:/usr/lib/ #export NETGENDIR=$JPK_NETGEN\par/bin # NETGEN export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:$JPK_TOGL:$JPK_NETGEN/** lib:/usr/lib/ export NETGENDIR=$JPK_NETGEN/bin
#crontab, ext editor export EDITOR=nano
#space ball export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:/usr/local/lib
#vrpn & hidapi export LD_LIBRARY_PATH=$LD_LIBRARY_**PATH:/$JPK_MPI_DIR/$JPK_VER/** vrpn/lib:/$JPK_MPI_DIR/$JPK_**VER/hidapi/lib:/usr/include/**libusb-1.0
2013/8/27 Pavan Balaji <[email protected] <mailto:[email protected]>>
This is almost certainly a network issue with your third machine (kaak, I presume?).
Thanks for making sure "hostname" works fine on all machines. That means that your ssh connections are setup correctly. But a non-MPI program, such as hostname, does not check the connection from kaak back to mpi1.
Can you try a simple program like "examples/cpi" in the build directory on all machines? Try it on 2 machines (mpiexec -np 4) and 3 machines (mpiexec -np 6).
If the third machine is in fact having problems running the application:
1. Make sure there's no firewall on the third machines.
2. Make sure the /etc/hosts file is consistent on both the machines (mpi1 and kaak).
-- Pavan
On 08/27/2013 06:46 AM, Joni-Pekka Kurronen wrote:
I have: -Ubuntu 12.4 -rsh-redo-rsh -three machines -mpich3 -have tried export HYDRA_DEMUX=select / poll -have tried ssh/rsh -have added to LIBS: event_core event_pthreads
I can run test at on to two machines whitout error but when I take third machine to cluster demux engine goes mad,... there is connection hanging,... and nothing happens,...
<MPITEST> <NAME>uoplong</NAME> <NP>11</NP> <WORKDIR>./coll</WORKDIR> <STATUS>fail</STATUS> <TESTDIFF> [mpiexec@mpi1] APPLICATION TIMED OUT [proxy:0:0@mpi1] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:886): assert (!closed) failed [proxy:0:0@mpi1] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:__**77): callback returned error status
[proxy:0:0@mpi1] main (./pm/pmiserv/pmip.c:206): demux engine error waiting for event [mpiexec@mpi1] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_**__wait.c:76): one of the processes
terminated badly; aborting [mpiexec@mpi1] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci___**wait.c:23): launcher returned
error waiting for completion [mpiexec@mpi1] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:_**_188): launcher returned error
Also I can run joni@mpi1:/mpi3/S3/hpcc-1.4.2$ mpiexec -np 6 hostname mpi1 mpi1 ugh ugh kaak kaak
but if I run joni@mpi1:/mpi3/S3/hpcc-1.4.2$ mpiexec -np 6 ls I get only one directory as output and system will cease until I have re-started slave machines !
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
-- Joni-Pekka Kurronen [email protected] <mailto:Joni.Kurronen@gmail.**com<[email protected]>
gsm. +358 50 521 2279
[email protected] gsm. +358 50 521 2279
-- Joni-Pekka Kurronen [email protected] gsm. +358 50 521 2279
participants (1)
Joni-Pekka Kurronen
