Re: [mpich-discuss] undefined symbol: MPI_UNWEIGHTED
you are probably linking to the wrong MPICH. You installed MPICH to /opt/mpich_gfc but the error occurs for MPICH installed at /opt/mpich. Do you have /opt/mpich in LD_LIBRARY_PATH? If that's the case, then you should remove it or place /opt/mpich_gfc before it. --Halim www.mcs.anl.gov/~aamer On 8/2/16 11:33 AM, Robert Baurle wrote:
Hello,
I have installed MPICH 3.2 on a CENTOS 6 machine with the following configuration options:
setenv CC /usr/bin/gcc setenv FC /usr/bin/gfortran setenv CXX /usr/bin/c++ setenv INS_DIR /opt/mpich_gfc
../mpich-3.2/configure --prefix=$INS_DIR --with-device=ch3:nemesis |& tee configure.log
make --jobs 4 |& tee make.log
make install
and the installation appeared to have completed without error (see the attached configure.log and make.log files). However, when I attempt to run a simple hello_world FORTRAN 90 program, I get the following error:
hyp22 rbaurle 2293> mpirun -n 3 a.out < hello.inp a.out: symbol lookup error: /opt/mpich/lib/libmpifort.so.12: undefined symbol: MPI_UNWEIGHTED
If I repeat the installation, but change the Fortran90 compiler from GFORTRAN to the Lahey 8.1 compiler, i.e.:
setenv FC /opt/lahey-64/bin/lf95
then the hello_world program runs just fine. Do you have any idea what might be going on here? I should also mention that the same error appears if I install MPICH 3.1.3.
Rob
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Halim Amer
