loads and stores in the MPI_Win_lock_all epochs using MPI_Fetch_and_op (see= attached files).<br> <br> This version behaves very similar to the original code and also fails from = time to time. Putting a sleep into the acquire busy loop (usleep(100)) will= make the code "much more robust" (I hack, I know, but indicating= some underlying race condition?!). Let me know if you see any problems in = the way I am using MPI_Fetch_and_op in a busy loop. Flushing or syncing is = not necessary in this case, right?<br> <br> All work is done with export MPIR_CVAR_ASYNC_PROGRESS=3D1 on mpich-3.2 and = mpich-3.3a2<br> <br> On Wed, Mar 8, 2017 at 4: 21 PM, Halim Amer <<a href=3D"mailto:aamer@anl.= gov" target=3D"_blank">[email protected]</a>> wrote: <br> I cannot claim that I thoroughly verified the correctness of that code, so = take it with a grain of salt. Please keep in mind that it is a test code fr= om a tutorial book; those codes are meant for learning purposes not for dep= loyment.<br> <br> If your goal is to have a high performance RMA lock, I suggest you to look = into the recent HPDC'16 paper: "High-Performance Distributed RMA Locks= ".<br> <br> Halim<br> <a href=3D"http: //www.mcs.anl.gov/~aamer" rel=3D"noreferrer" target=3D"_bla= nk">www.mcs.anl.gov/~aamer</a><br> <br> On 3/8/17 3: 06 AM, Ask Jakobsen wrote:<br> You are absolutely correct, Halim. Removing the test lmem[nextRank] =3D=3D = -1<br> in release fixes the problem. Great work. Now I will try to understand why<= br> you are right. I hope the authors of the book will credit you for<br> discovering the bug.<br> <br> So in conclusion you need to remove the above mentioned test AND enable<br> asynchronous progression using the environment variable<br> MPIR_CVAR_ASYNC_PROGRESS=3D1 in MPICH (BTW I still can't get the code to wo= rk<br> in openmpi).<br> <br> On Tue, Mar 7, 2017 at 5: 37 PM, Halim Amer <<a href=3D"mailto:aamer@anl.= gov" target=3D"_blank">[email protected]</a>> wrote: <br> <br> detect that another process is being or already enqueued in the MCS<br> queue.<br> <br> Actually the problem occurs only when the waiting process already enqueued<= br> itself, i.e., the accumulate operation on the nextRank field succeeded.<br> <br> Halim<br> <a href=3D"http: //www.mcs.anl.gov/~aamer" rel=3D"noreferrer" target=3D"_bla= nk">www.mcs.anl.gov/~aamer</a> <<a href=3D"http: //www.mcs.anl.gov/%7Eaam= er" rel=3D"noreferrer" target=3D"_blank">http: //www.mcs.anl.gov/%7Eaam<wbr>= er</a>><br> <br> <br> On 3/7/17 10: 29 AM, Halim Amer wrote:<br> <br> In the Release protocol, try removing this test: <br> <br> if (lmem[nextRank] =3D=3D -1) {<br> If-Block;<br> }<br> <br> but keep the If-Block.<br> <br> The hang occurs because the process releasing the MCS lock fails to<br> detect that another process is being or already enqueued in the MCS queue.<= br> <br> Halim<br> <a href=3D"http: //www.mcs.anl.gov/~aamer" rel=3D"noreferrer" target=3D"_bla= nk">www.mcs.anl.gov/~aamer</a> <<a href=3D"http: //www.mcs.anl.gov/%7Eaam= er" rel=3D"noreferrer" target=3D"_blank">http: //www.mcs.anl.gov/%7Eaam<wbr>= er</a>><br> <br> <br> On 3/7/17 6: 43 AM, Ask Jakobsen wrote:<br> <br> Thanks, Halim. I have now enabled asynchronous progress in MPICH (can't<br> find something similar in openmpi) and now all ranks acquire the lock and<b= r> the program finish as expected. However if I put a while(1) loop<br> around the<br> acquire-release code in main.c it will fail again at random and go<br> into an<br> infinite loop. The simple unfair lock does not have this problem.<br> <br> On Tue, Mar 7, 2017 at 12: 44 AM, Halim Amer <<a href=3D"mailto:aamer@anl= .gov" target=3D"_blank">[email protected]</a>> wrote: <br> <br> My understanding is that this code assumes asynchronous progress.<br> An example of when the processes hang is as follows: <br> <br> 1) P0 Finishes MCSLockAcquire()<br> 2) P1 is busy waiting in MCSLockAcquire() at<br> do {<br> MPI_Win_sync(win);<br> } while (lmem[blocked] =3D=3D 1);<br> 3) P0 executes MCSLockRelease()<br> 4) P0 waits on MPI_Win_lock_all() inside MCSLockRlease()<br> <br> Hang!<br> <br> For P1 to get out of the loop, P0 has to get out of<br> MPI_Win_lock_all() and<br> executes its Compare_and_swap().<br> <br> For P0 to get out MPI_Win_lock_all(), it needs an ACK from P1 that it<br> got<br> the lock.<br> <br> P1 does not make communication progress because MPI_Win_sync is not<br> required to do so. It only synchronizes private and public copies.<br> <br> For this hang to disappear, one can either trigger progress manually by<br> using heavy-duty synchronization calls instead of Win_sync (e.g.,<br> Win_unlock_all + Win_lock_all), or enable asynchronous progress.<br> <br> To enable asynchronous progress in MPICH, set the<br> MPIR_CVAR_ASYNC_PROGRESS<br> env var to 1.<br> <br> Halim<br> <a href=3D"http: //www.mcs.anl.gov/~aamer" rel=3D"noreferrer" target=3D"_bla= nk">www.mcs.anl.gov/~aamer</a> <<a href=3D"http: //www.mcs.anl.gov/%7Eaam= er" rel=3D"noreferrer" target=3D"_blank">http: //www.mcs.anl.gov/%7Eaam<wbr>= er</a>> <<br> <a href=3D"http: //www.mcs.anl.gov/%7Eaamer" rel=3D"noreferrer" target=3D"_b= lank">http: //www.mcs.anl.gov/%7Eaame<wbr>r</a>><br> <br> <br> On 3/6/17 1: 11 PM, Ask Jakobsen wrote:<br> <br> I am testing on x86_64 platform.<br> <br> I have tried to built both the mpich and the mcs lock code with -O0 to<br> avoid agressive optimization. After your suggestion I have also<br> tried to<br> make volatile int *pblocked pointing to lmem[blocked] in the<br> MCSLockAcquire<br> function and volatile int *pnextrank pointing to lmem[nextRank] in<br> MCSLockRelease, but it does not appear to make a difference.<br> <br> On suggestion from Richard Warren I have also tried building the code<br> using<br> openmpi-2.0.2 without any luck (however it appears to acquire the<br> lock a<br> couple of extra times before failing) which I find troubling.<br> <br> I think I will give up using local load/stores and will see if I can<br> figure<br> out if rewrite using MPI calls like MPI_Fetch_and_op as you suggest.<= br> Thanks for your help.<br> <br> On Mon, Mar 6, 2017 at 7: 20 PM, Jeff Hammond <<a href=3D"mailto:jeff.sci= [email protected]" target=3D"_blank">[email protected]</a>><br> wrote: <br> <br> What processor architecture are you testing?<br> <br> <br> Maybe set lmem to volatile or read it with MPI_Fetch_and_op rather<br> than a<br> load. MPI_Win_sync cannot prevent the compiler from caching *lmem<br> in a<br> register.<br> <br> Jeff<br> <br> On Sat, Mar 4, 2017 at 12: 30 AM, Ask Jakobsen <<a href=3D"mailto:afj@qey= e-labs.com" target=3D"_blank">[email protected]</a>><br> wrote: <br> <br> Hi,<br> <br> <br> I have downloaded the source code for the MCS lock from the excellent<br> book "Using Advanced MPI" from <a href=3D"http: //www.mcs.anl.gov/= researc" rel=3D"noreferrer" target=3D"_blank">http: //www.mcs.anl.gov/resear= c</a><br> h/projects/mpi/usingmpi/exampl<wbr>es-advmpi/rma2/mcs-lock.c<br> <br> I have made a very simple piece of test code for testing the MCS lock<br> but<br> it works at random and often never escapes the busy loops in the<br> acquire<br> and release functions (see attached source code). The code appears<br> semantically correct to my eyes.<br> <br> #include <stdio.h><br> #include <mpi.h><br> #include "mcs-lock.h"<br> <br> int main(int argc, char *argv[])<br> {<br> MPI_Win win;<br> MPI_Init( &argc, &argv );<br> <br> MCSLockInit(MPI_COMM_WORLD, &win);<br> <br> int rank, size;<br> MPI_Comm_rank(MPI_COMM_WORLD, &rank);<br> MPI_Comm_size(MPI_COMM_WORLD, &size);<br> <br> printf("rank: %d, size: %d\n", rank, size);<br> <br> <br> MCSLockAcquire(win);<br> printf("rank %d aquired lock\n", rank); fflush(= stdout);<br> MCSLockRelease(win);<br> <br> <br> MPI_Win_free(&win);<br> MPI_Finalize();<br> return 0;<br> }<br> <br> <br> I have tested on several hardware platforms and mpich-3.2 and<br> mpich-3.3a2<br> but with no luck.<br> <br> It appears that the MPI_Win_Sync are not "refreshing" the local<b= r> data or<br> I<br> have a bug I can't spot.<br> <br> A simple unfair lock like <a href=3D"http: //www.mcs.anl.gov/researc" rel=3D= "noreferrer" target=3D"_blank">http: //www.mcs.anl.gov/researc</a><br> h/projects/mpi/usingmpi/exampl<wbr>es-advmpi/rma2/ga_mutex1.c works<br> perfectly.<br> <br> Best regards, Ask Jakobsen<br> <br> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> <br> <br> <br> --<br> Jeff Hammond<br> <a href=3D"mailto: [email protected]" target=3D"_blank">jeff.science@gm= ail.com</a><br> <a href=3D"http: //jeffhammond.github.io/" rel=3D"noreferrer" target=3D"_bla= nk">http: //jeffhammond.github.io/</a><br> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> <br> <br> <br> <br> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> ______________________________<wbr>_________________<br> <br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> <br> <br> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> <br> <br> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <main.c><mcs-lock-fop.c><mcs-l<wbr>ock.h>________________= ________<wbr>_______________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> </blockquote> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> <br> <br> --<br> Ask Jakobsen<br> R&D<br> <br> Qeye Labs<br> Lers=C3=B8 Parkall=C3=A9 107<br> 2100 Copenhagen =C3=98<br> Denmark<br> <br> mobile: <a href=3D"tel:%2B45%202834%206936" value=3D"+4528346936" targe= t=3D"_blank">+45 2834 6936</a><br> email: [email protected]<br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> </blockquote> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> </blockquote> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a><br> <br> </blockquote> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank">https: //lists.mpich.org/mailma<wbr>n/listinfo/discus= s</a></div></div></blockquote></div><br><br clear=3D"all"><div><br></div>--= <br><div class=3D"m_-9117170903988053540gmail_signature" data-smartmail=3D= "gmail_signature"><div dir=3D"ltr"><div><div dir=3D"ltr"><font size=3D"1"><= b>Ask Jakobsen</b><br>R&D<br><br><span style=3D"color: rgb(255,153,102)"=
Q</span>eye Labs<br>Lers=C3=B8 Parkall=C3=A9 107<br>2100 Copenhagen =C3=98= <br>Denmark<br><br>mobile: <a href=3D"tel:+45%2028%2034%2069%2036" val= ue=3D"+4528346936" target=3D"_blank">+45 2834 6936</a><br>email: af= [email protected]<br></font></div></div></div></div> </div> </div></div></blockquote></div><br><br clear=3D"all"><div><br></div>-- <br>= <div class=3D"gmail_signature" data-smartmail=3D"gmail_signature"><div dir= =3D"ltr"><div><div dir=3D"ltr"><font size=3D"1"><b>Ask Jakobsen</b><br>R&am= p;D<br><br><span style=3D"color: rgb(255,153,102)">Q</span>eye Labs<br>Lers= =C3=B8 Parkall=C3=A9 107<br>2100 Copenhagen =C3=98 <br>Denmark<br><br>mobil= e: +45 2834 6936<br>email: [email protected]<br></font></div></div></di= v></div> </div>
--001a113d3a84bc7a97054aa1fd98-- --===============6869846251208948639== Content-Type: text/plain; charset="us-ascii" Content-Transfer-Encoding: 7bit Content-Disposition: inline _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss --===============6869846251208948639==-- Message-ID: <[email protected]>
participants (1)
None
