Re: [mpich-discuss] installing mpich-1.2.6 to create libmpich.so.1.0
Any compiler is fine. But use the latest version of mpich. You don't need all the configure flags that Jeff sent. In fact, I'd recommend that you not use them. For example, --enable-g is only for developers. My recommendation is just this: ./configure --prefix=<where_to_install> CC=pgcc CXX=pgCC F77=pgf77 FC=pgfc -- Pavan On 06/25/2013 02:54 PM, Andre Pattantyus wrote:
Jeff,
Are you saying that this file will only build with a gnu compiler? or can I build with pgf compiler with mpich 3.0.4?
-Andre
On Tue, Jun 25, 2013 at 2:19 AM, Jeff Hammond <[email protected] <mailto:[email protected]>> wrote:
Try MPICH 3.0.4. MPICH 1.2.6 is ancient and not supported.
This is how I build MPICH 3.0.4. You will have to edit the prefix option appropriately.
wget http://www.mpich.org/static/downloads/3.0.4/mpich-3.0.4.tar.gz tar -xzf mpich-3.0.4.tar.gz cd mpich-3.0.4 mkdir build-gcc cd build-gcc/ ../configure CC=gcc CXX=g++ FC=gfortran F77=gfortran --enable-fc --enable-f77 --enable-threads --enable-g=dbg --with-device=ch3:nemesis --with-pm=hydra --prefix=.
Jeff
----- Original Message ----- From: "Andre Pattantyus" <[email protected] <mailto:[email protected]>> To: [email protected] <mailto:[email protected]> Sent: Tuesday, June 25, 2013 3:15:55 AM Subject: [mpich-discuss] installing mpich-1.2.6 to create libmpich.so.1.0
Hello,
I am not familiar with installing mpich and am having problems with installation. I have found from searching online that mpich-1.2.6 produces libmpich.so.1.0 which I require run a certain program in parallel. I am unable to follow the installation documentation I have found online for this version because when i configure for ch_p4mpd I get an error when I run make. Therefore I just run ./configure and make but this does not produce my required libmpich.so.1.0. What do I need to specify prior to either configure or make in order to build this? I am building on a linux86-64 with pgi/10.2 compiler.
-- Andre Pattantyus Graduate Student Research Assistant Department of Meteorology University of Hawaii at Manoa 2525 Correa Rd, HIG 350 Honolulu, HI 96822 Phone: (845) 264-3582
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
