Default behavior of mpif90/ifort on MacOSX (MH_BUNDLE, MH_DYLIB)
Hello, After upgrading to mpich-3.0.4 today I was presented with the following error on my MacOSX 10.8.4 machine when using mpif90 (installation/compiler info at e-mail bottom). For the simple code:
[02:23 PM Wed Jul 24] > cat main.f90 Program MAIN
Print *, "F: Hello, World!"
End Program MAIN
The compilation gives
[02:26 PM Wed Jul 24] > mpif90 main.f90 ld: can't link with bundle (MH_BUNDLE) only dylibs (MH_DYLIB) for architecture x86_64
and no executable is built. Using mpif90 -link-info and chasing down the libraries I found that the bundle libmpichf90.so was being linked instead of libmpichf90.dylib (which is not created) or the static library libmpichf90.a. (That libmpichf90.so was a bundle was confirmed using otool -hV /usr/local/lib/libmpichf90.so.) After hiding the library libmpichf90.so so the static version libmpichf90.a is used, compile proceeds normally. This behavior was not seen earlier when using mpich2-1.4.1 through mpich-3.0.1 (I think). COMPILER INFO:
[02:36 PM Wed Jul 24] > ifort -V Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.3.198 Build 20130606
[02:36 PM Wed Jul 24] > icc -V Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.3.198 Build 20130606
[02:36 PM Wed Jul 24] > icpc -V Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.3.198 Build 20130606
MPICH INFO: (build used ifort/icc/icpc as above)
[02:38 PM Wed Jul 24] > head config.log This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake.
It was created by MPICH configure 3.0.4, which was generated by GNU Autoconf 2.69. Invocation command line was
$ ./configure --enable-f77 --enable-fc --enable-cxx --enable-shared --enable-romio --enable-mpe
Cheers, Dan -- Daniel J. Bodony Associate Professor of Aerospace Engineering Affiliate Professor of Mechanical Science & Engineering University of Illinois at Urbana-Champaign
participants (1)
Bodony, Daniel J
