unable to bind socket to port
Hi, all I'm using SLEPc as an eigensolver, which implemented MPICH for multiprocess usage. I compile SLEPc code into a .so library B. My executable program A calls .so library B, and .so libraryB calls SLEPclibrary. I used to put MPI_Init() only in A. But it will got stuck. Then I try to put it in A,B( and C,SLEPc init will call this function). INTERNAL ERROR: Invalid error class (59) encountered while returning from MPI_Init. Please file a bug report. Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port INTERNAL ERROR: Invalid error class (59) encountered while returning from MPI_Init. Please file a bug report. Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port [cli_1]: aborting job: Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port INTERNAL ERROR: Invalid error class (59) encountered while returning from MPI_Init. Please file a bug report. INTERNAL ERROR: Invalid error class (59) encountered while returning from MPI_Init. Please file a bug report. Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port [cli_3]: aborting job: Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port [cli_0]: aborting job: Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port [cli_2]: aborting job: Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== root@altria-Aspire-5830TG:/home/altria/software/rememode-1.1alpha/Examples/c++# /home/altria/software/petsc-3.4.4/arch-linux2-c-debug/bin/mpiexec -np 4 ./fd_guide INTERNAL ERROR: Invalid error class (59) encountered while returning from MPI_Init. Please file a bug report. INTERNAL ERROR: Invalid error class (59) encountered while returning from MPI_Init. Please file a bug report. Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port [cli_1]: aborting job: Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port INTERNAL ERROR: Invalid error class (59) encountered while returning from MPI_Init. Please file a bug report. Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port [cli_2]: aborting job: Fatal error in MPI_Init: Unknown error. Please file a bug report., error stack: (unknown)(): unable to bind socket to port =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== I think it is because I called MPI_Init for more than one times. Because if I only call it in A, and C(SLEPc call), code in A,B will be executed, but stuck at C. If I call it in A,B,C. Code in A will be executed, and stop at B. I think even if I call MPI_Init for more than one times, it should return to me something like "MPI_Init has been called". Do anyone know how to fix it?Thanks. Your sincerely, Guoxi
participants (1)
张国熙
