$ ./mpi-run.sh Running cpi on machines.u2.mpi Process 0 of 1 is on UNIT2 pi is approximately 3.1415926544231341, Error is 0.0000000008333410 wall clock time =3D 0.001327 Done! If I edit the script to change the mpiexec line like this: sudo -E LD_LIBRARY_PATH=3D${ELIBS} mpiexec --allow-run-as-root -machinefile= /home/linaro/.machines.u2.mpi -n 1 /home/linaro/myMPI/cpi Now I get (edited for brevity): $ ./mpi-run.sh Running cpi on machines.u2.mpi linaro@UNIT2's password: PATH=3D/usr/local/bin[...]: Command not found. export: Command not found. LD_LIBRARY_PATH=3D/usr/local/lib[...]: Command not found. export: Command not found. DYLD_LIBRARY_PATH: Undefined variable. And it just stops there. Note that the LD_LIBRARY_PATH being reported is *= not* the one passed in by the script. I don't think it's managing to reach= the mpi execution stage itself. If the machinefile lists more than one host, the password prompts appear tw= o at a time and interfere with each other such that no login succeeds (alth= ough all machines have the same password). Googling around, I've seen this series of error outputs in a wide variety o= f other contexts, including Open MPI but also some completely unrelated app= lication suites and SDKs. My problem is that the mpi binaries I need to run on the hosts absolutely r= equire sudo elevation. Is sudo mpiexec the way to go? What is going on in= my example case? Daniel U. Thibault RDDC - Centre de recherches de Valcartier | DRDC - Valcartier Research Cent= re NAC: 918V QSDJ<http://www.travelgis.com/map.asp?addr=3D918V%20QSDJ> <http:= //www.travelgis.com/map.asp?addr=3D918V%20QSDJ> Gouvernement du Canada | Government of Canada <http: //www.valcartier.drdc-rddc.gc.ca/> --_000_48CF5AC71E61DB46B70D0F388054EFFD86F70ED5VALE02valcartie_ Content-Type: text/html; charset="us-ascii" Content-Transfer-Encoding: quoted-printable <html><head> <meta http-equiv=3D"Content-Type" content=3D"text/html; charset=3Dus-ascii"=
<meta name=3D"Generator" content=3D"Microsoft Exchange Server"> <!-- converted from rtf --> <style><!-- .EmailQuote { margin-left: 1pt; padding-left: 4pt; border-left:= #800000 2px solid; } --></style> </head> <body> <font face=3D"Calibri" size=3D"2"><span style=3D"font-size: 11pt;"> <div> I have a small network of machines all running the same O= S (Linaro Ubuntu Linux); they were all cloned from the same disk image and = differ only in their machine names (UNIT1 through UNIT4).</div> <div> </div> <div> I can ssh between them at will, trusty has been establish= ed and I no longer get asked for a password upon connecting. MPICH is= installed from the Ubuntu repository (not quite the latest version: mpiexe= c reports version OpenRTE 1.8.1, the mpich package is 3.0.4-6ubuntu1), and I can run a demo like cpi with no issues, using a l= ittle mpi-run.sh bash script (the default shell is tcsh, however): </div> <div> </div> <div>(begin script)</div> <div>#!/bin/bash</div> <div> </div> <div>set -e</div> <div> </div> <div>ESDK=3D${EPIPHANY_HOME}</div> <div>ELIBS=3D${ESDK}/tools/host/lib: ${LD_LIBRARY_PATH}</div> <div>EHDF=3D${EPIPHANY_HDF}</div> <div> </div> <div>echo "Running cpi on machines.u2.mpi"</div> <div>LD_LIBRARY_PATH=3D${ELIBS} mpiexec --allow-run-as-root -machinefile /h= ome/linaro/.machines.u2.mpi -n 1 /home/linaro/myMPI/cpi</div> <div>echo "Done!"</div> <div>(end script)</div> <div> </div> <div>.machines.u2.mpi consists of the one line: </div> <div> </div> <div>linaro@UNIT2</div> <div> </div> <div>From UNIT1, if I do: </div> <div> </div> <div>$ ./mpi-run.sh</div> <div>Running cpi on machines.u2.mpi</div> <div>Process 0 of 1 is on UNIT2</div> <div>pi is approximately 3.1415926544231341, Error is 0.0000000008333410</d= iv> <div>wall clock time =3D 0.001327</div> <div>Done!</div> <div> </div> <div>If I edit the script to change the mpiexec line like this: </div> <div> </div> <div>sudo -E LD_LIBRARY_PATH=3D${ELIBS} mpiexec --allow-run-as-root -machin= efile /home/linaro/.machines.u2.mpi -n 1 /home/linaro/myMPI/cpi</div> <div> </div> <div>Now I get (edited for brevity): </div> <div> </div> <div>$ ./mpi-run.sh</div> <div>Running cpi on machines.u2.mpi</div> <div>linaro@UNIT2’s password: </div> <div>PATH=3D/usr/local/bin[…]: Command not found.</div> <div>export: Command not found.</div> <div>LD_LIBRARY_PATH=3D/usr/local/lib[…]: Command not found.</div> <div>export: Command not found.</div> <div>DYLD_LIBRARY_PATH: Undefined variable.</div> <div> </div> <div>And it just stops there. Note that the LD_LIBRARY_PATH being rep= orted is *<b>not</b>* the one passed in by the script. I don’t = think it’s managing to reach the mpi execution stage itself.</div> <div> </div> <div>If the machinefile lists more than one host, the password prompts appe= ar two at a time and interfere with each other such that no login succeeds = (although all machines have the same password).</div> <div> </div> <div>Googling around, I’ve seen this series of error outputs in a wid= e variety of other contexts, including Open MPI but also some completely un= related application suites and SDKs.</div> <div> </div> <div>My problem is that the mpi binaries I need to run on the hosts absolut= ely require sudo elevation. Is sudo mpiexec the way to go? What= is going on in my example case?</div> <div> </div> <div><font face=3D"Consolas">Daniel U. Thibault<br> RDDC - Centre de recherches de Valcartier | DRDC - Valcartier Research Cent= re<br> NAC : <a href=3D"http://www.travelgis.com/map.asp?addr=3D918V%20QSDJ">= <font face=3D"Courier New" size=3D"2" color=3D"blue"><span style=3D"font-si= ze: 10pt;"><u>918V QSDJ</u></span></font></a><font face=3D"Calibri" color=3D= "#1F497D"> </font><font face=3D"Calibri"><</font><font face=3D"Courier N= ew" size=3D"2" color=3D"blue"><span style=3D"font-size: 10pt;"><u><a href=3D= "http: //www.travelgis.com/map.asp?addr=3D918V%20QSDJ">http://www.travelgis.= com/map.asp?addr=3D918V%20QSDJ</a></u></span></font><font face=3D"Calibri">= ><br> </font>Gouvernement du Canada | Government of Canada<br> <font face=3D"Calibri"><</font><a href=3D"http: //www.valcartier.drdc-rdd= c.gc.ca/"><font face=3D"Courier New" size=3D"2" color=3D"blue"><span style= =3D"font-size: 10pt;"><u>http://www.valcartier.drdc-rddc.gc.ca/</u></span></= font></a><font face=3D"Calibri">></font></font></div> <div> </div> </span></font> </body> </html> --_000_48CF5AC71E61DB46B70D0F388054EFFD86F70ED5VALE02valcartie_-- --===============9162204499992570155== Content-Type: text/plain; charset="us-ascii" Content-Transfer-Encoding: 7bit Content-Disposition: inline _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss --===============9162204499992570155==-- Message-ID: <[email protected]>
participants (1)
None
