Re: [mpich-discuss] Running an mpi program that needs to access /dev/mem
Jeff, Does that put you into the same environment as sudo bash? Because I have already tried that with no success. Eibhlin ________________________________________ From: [email protected] [[email protected]] on behalf of Jeff Hammond [[email protected]] Sent: 13 June 2013 13:58 To: [email protected] Subject: Re: [mpich-discuss] Running an mpi program that needs to access /dev/mem Just su to root instead of using sudo. Jeff On Thu, Jun 13, 2013 at 6:56 AM, Lee, Eibhlin <[email protected]> wrote:
Hello all,
I am trying to use two raspberry-pi to sample and then process some data. The first process samples while the second processes and vice versa. To do this I use gpio and also mpich-3.0.4 with the process manager smpd. I have successfully run cpi on both machines (from the master machine). I have also managed to run a similar program but without the MPI, this involved compiling with gcc and when running putting sudo in front of the binary file.
When I combine these two processes I get various error messages. For input: mpiexec -phrase cat -machinefile machinefile -n 2 ~/main the error is: Can't open /dev/mem Did you forget to use 'sudo .. ?'
For input: sudo mpiexec -phrase cat -machinefile machinefile -n 2 ~/main the error is: sudo: mpiexec: Command not found
I therefore put mpiexec into /usr/bin
now for input: sudo mpiexec -phrase cat -machinefile machinefile -n 2 ~/main the error is: Can't open /dev/mem Did you forget to use 'sudo .. ?'
Does anyone know how I can work around this? Thanks, Eibhlin
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Lee, Eibhlin
