Good morning, I wanted to present an issue I am having with MPICH and validate whether this is a configuration problem, a limitation with MPICH, or a bug. I am writing an application which uses a large number of MPI windows, each window is given a relatively large amount of memory. This has never been a problem before, however we discovered if you allocate more than 2045 windows, you get an exception thrown. Notes: I am compiling using g++, version 4.8.5 on Red Hat Enterprise Linux version 7.2. My MPICH version is listed at the bottom of this email. It was installed via yum and is the RHEL default. I have attached sample output, to include the stdout/stderr. Also included is a Makefile and a simple example. The boundary of failure is between 2045 and 2046 windows. I have verified on my system this problem repeats even if I distribute windows between multiple communicators. I have not tested yet against ompi or mvapich. #-----------------------------------------------------------------------------------------------# #- Here is my output -# #-----------------------------------------------------------------------------------------------# mpirun -np 2 -hosts localhost ./mpi-win-test 2046 1 Initialized Rank: 0, Number Processors: 2, Hostname: test-machine Initialized Rank: 1, Number Processors: 2, Hostname: test-machine Fatal error in MPI_Win_create_dynamic: Other MPI error, error stack: MPI_Win_create_dynamic(154)..........: MPI_Win_create_dynamic(MPI_INFO_NULL, MPI_COMM_WORLD, win=0x10c1464) failed MPID_Win_create_dynamic(139).........: win_init(254)........................: MPIR_Comm_dup_impl(55)...............: MPIR_Comm_copy(1552).................: MPIR_Get_contextid(799)..............: MPIR_Get_contextid_sparse_group(1146): Cannot allocate context ID because of fragmentation (0/2048 free on this process; ignore_id=0) Fatal error in MPI_Win_create_dynamic: Other MPI error, error stack: MPI_Win_create_dynamic(154)..........: MPI_Win_create_dynamic(MPI_INFO_NULL, MPI_COMM_WORLD, win=0x19ef444) failed MPID_Win_create_dynamic(139).........: win_init(254)........................: MPIR_Comm_dup_impl(55)...............: MPIR_Comm_copy(1552).................: MPIR_Get_contextid(799)..............: MPIR_Get_contextid_sparse_group(1146): Cannot allocate context ID because of fragmentation (0/2048 free on this process; ignore_id=0) =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== make: *** [run] Error 1 #------------------------------------------------------------------------------------------# #- Here is my Sample Makefile -# #------------------------------------------------------------------------------------------# # Path to mpich on RHEL7 MPI_INCL=-I/usr/include/mpich-x86_64 MPI_LIBS=-L/usr/lib64/mpich/lib -lmpich # C++11 Bindings (Being lazy with string) CXX_ARGS=-std=c++11 # Make th test all: mpi-win-test mpi-win-test: mpi-win-test.cpp g++ $< -o $@ $(MPI_INCL) $(MPI_LIBS) $(CXX_ARGS) # Args for application NUM_WINDOWS=2046 USE_DYNAMIC=1 # Sample run usage # # Args: # - Number of Windows # - Type of windows (1 dynamic, 0 static) run: mpirun -np 2 -hosts localhost ./mpi-win-test $(NUM_WINDOWS) $(USE_DYNAMIC) #------------------------------------------------------------------------------------------# #- Here is my Sample Application -# #------------------------------------------------------------------------------------------# #include <mpi.h> #include <iostream> #include <string> #include <vector> using namespace std; int main( int argc, char* argv[] ) { // Number of MPI Windows int num_windows = std::stoi(argv[1]); bool use_dynamic = std::stoi(argv[2]); // Initialize MPI MPI_Init( &argc, &argv ); // Get the rank and size int rank, nprocs; MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); // Get the processor name char hostname[MPI_MAX_PROCESSOR_NAME]; int hostname_len; MPI_Get_processor_name( hostname, &hostname_len); // Print Message for( int i=0; i<nprocs; i++ ){ MPI_Barrier(MPI_COMM_WORLD); if( i == rank ){ std::cout << "Initialized Rank: " << rank << ", Number Processors: " << nprocs << ", Hostname: " << hostname << std::endl; } } // MPI Variables vector<MPI_Aint> sdisp_remotes(num_windows); vector<MPI_Aint> sdisp_locals(num_windows); // Create MPI Windows vector<MPI_Win> windows(num_windows); int64_t buffer_size = 1000; char* buffer = new char[buffer_size]; for( int i=0; i<num_windows; i++ ) { if( use_dynamic ) { MPI_Win_create_dynamic( MPI_INFO_NULL, MPI_COMM_WORLD, &windows[i] ); } else { MPI_Win_create( &buffer, buffer_size, 1, MPI_INFO_NULL, MPI_COMM_WORLD, &windows[i] ); } } // Exception always occurs prior to reaching this point. // More Code Here that I am removing for brevity // Wait at the barrier MPI_Barrier( MPI_COMM_WORLD ); // Remove all windows for( int i=0; i<num_windows; i++) { // Destroy the MPI Window MPI_Win_free( &windows[i] ); } windows.clear(); // Clear buffer delete [] buffer; buffer = nullptr; // Close MPI MPI_Finalize(); return 0; } #--------------------------------------------------------------------------# #- MPICH Version Output -# #--------------------------------------------------------------------------# MPICH Version: 3.0.4 MPICH Release date: Wed Apr 24 10:08:10 CDT 2013 MPICH Device: ch3:nemesis MPICH configure: --build=x86_64-redhat-linux-gnu --host=x86_64-redhat-linux-gnu --program-prefix= --disable-dependency-tracking --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib64 --libexecdir=/usr/libexec --localstatedir=/var --sharedstatedir=/var/lib --mandir=/usr/share/man --infodir=/usr/share/info --enable-sharedlibs=gcc --enable-shared --enable-lib-depend --disable-rpath --enable-fc --with-device=ch3:nemesis --with-pm=hydra:gforker --sysconfdir=/etc/mpich-x86_64 --includedir=/usr/include/mpich-x86_64 --bindir=/usr/lib64/mpich/bin --libdir=/usr/lib64/mpich/lib --datadir=/usr/share/mpich --mandir=/usr/share/man/mpich --docdir=/usr/share/mpich/doc --htmldir=/usr/share/mpich/doc --with-hwloc-prefix=system FC=gfortran F77=gfortran CFLAGS=-m64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC CXXFLAGS=-m64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC FCFLAGS=-m64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC FFLAGS=-m64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC LDFLAGS=-Wl,-z,noexecstack MPICH2LIB_CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic MPICH2LIB_CXXFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic MPICH2LIB_FCFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic MPICH2LIB_FFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic MPICH CC: cc -m64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC -O2 MPICH CXX: c++ -m64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC -O2 MPICH F77: gfortran -m64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC -O2 MPICH FC: gfortran -m64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fPIC -O2 CONFIDENTIALITY NOTICE - SNC EMAIL: This email and any attachments are confidential, may contain proprietary, protected, or export controlled information, and are intended for the use of the intended recipients only. Any review, reliance, distribution, disclosure, or forwarding of this email and/or attachments outside of Sierra Nevada Corporation (SNC) without express written approval of the sender, except to the extent required to further properly approved SNC business purposes, is strictly prohibited. If you are not the intended recipient of this email, please notify the sender immediately, and delete all copies without reading, printing, or saving in any manner. --- Thank You. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Marvin Smith
