Re: [mpich-discuss] MPI_Win RMA with threads
Please see the attached. You can run with something like mpic++ -std=c++17 -g -ggdb -fno-omit-frame-pointer -lpthread -O0 thread_test_2.cpp -o thread_test_2 && mpirun -n 2 thread_test_2 1 5 8 A follow-up question: it seems that MPICH creates a duplicate MPI_Comm for each window, as I mentioned above. Is that something that's enforced by the standard or just an MPICH implementation detail? On Thu, Feb 27, 2020 at 2:47 PM Thakur, Rajeev <[email protected]> wrote:
Can you send us the whole program?
Rajeev
-----Original Message----- From: Mark Davis via discuss <[email protected]> Reply-To: "[email protected]" <[email protected]> Date: Thursday, February 27, 2020 at 12:47 PM To: "[email protected]" <[email protected]> Cc: Mark Davis <[email protected]> Subject: [mpich-discuss] MPI_Win RMA with threads
Hello,
I'm experimenting with using MPI + threads with one-sided communication with PSCW synchronization. I'm running into a deadlock situation and I want to clarify my understanding of these concepts.
In a simple benchmark, I'm creating 2 MPI processes, each with 8 pthreads. I'm running MPI in MPI_THREAD_MULIPLE mode. Before I create the threads, the parent processes each create 8 MPI_Win's in the same order, each with an allocated and attached buffer on rank 1's side (and a zero-sized window on rank 1's side). I verified that I'm creating each of them in the same order, storing the resulting MPI_Win handle in an 8-element array wins. All windows are created in the same MPI_Comm (MPI_COMM_WORLD).
My understanding from MPICH 3.3.1 mpid_rma.c:274 is that each MPI_Win object actually creates its own communicator that's used internally for this particular window. I mention this because I would have assumed that this would obviate this issue, but it doesn't seem to.
Then I spawn the 8 threads on each of the two MPI ranks, resulting in 16 threads total in the system across the two MPI ranks. Each thread is given its own dedicated MPI window; that is, thread i gets wins[i]. wins[0] on rank 0, thread 0 should correspond to wins[0] on rank 1, thread 0, for example.
Here is the pseudocode that each of the threads run:
* rank 0 threads are "senders":
for(iter=0; iter<5; ++iter) { // i is the thread number MPI_Win_start(group_containing_rank_1, 0, wins[i]); MPI_Put(buf_, count_, MPI_INT, partner_rank_, 0, count_, MPI_INT, MPI_Win_complete(wins[i]); }
* rank 1 threads are "receivers":
for(iter=0; iter<5; ++iter) { // i is the thread number MPI_Win_post(group_containing_rank_0, 0 , wins[i]); MPI_Win_wait(wins[i]); // verify correct value in the received buffer, from the proper sender, etc. }
where group_containing_rank_0 and group_containing_rank_0 are single rank groups.
Note that the loops iterate 5 times; however, I almost always get a deadlock before it finishes.
Specifically, it deadlocks when a sender thread gets to i=1, trying to issue the MPI_Win_start (but blocking) and the corresponding receiver thread is still stuck on the completion of iteration 0, blocking on the MPI_Win_wait. Some of the time the program runs correctly (and I am having the receiver of the PUT verify that the "message" is from the proper sender by inspecting the payload).
One guess is that the sender thread received a completion ack from some other thread on rank 1, and that it's not able to differentiate those. The "completion ack" seems to be done via an MPI_Isend to all members in the specified group (in this example, that is just one MPI rank, rank 0) with an MPID_Isend(&i, 0, MPI_INT, dst, SYNC_POST_TAG, win_comm_ptr, MPIR_CONTEXT_INTRA_PT2PT, &req_ptr) call in ch3u_rma_sync.c:759 (MPID_Win_post). While this call will use the same tag (SYNC_POST_TAG) for all posts, they should all be in different communicators given the point above about the internal communicator duplicate (win_comm_ptr).
I have seen other non-threaded MPI code that uses multiple different windows, each with different parameters and names, so I'm pretty sure two MPI processes can have multiple windows between them. However, it's possible that works by ensuring a consistent ordering between the uses of those windows. I was hoping that the internal communicator that's created would be sufficient for disambiguation between multiple windows on a pair of MPI ranks, though.
Some questions:
1. can you please help me understand what's going on in my program and clarify any misunderstandings I have about MPI's guarantees about windows?
2. Does the MPI standard enable my goal of having multiple independent windows between the same two MPI ranks such that they won't conflict? Is there any way to enforce that the ith created window on rank 0 will only communicate with the ith created window on rank 1?
3. Even if I can get this approach to work, I worry about scaling this to larger numbers of ranks; my understanding is that there's a limit of around 2000 MPI_Comms in the application. So, if you have an idea on how I can get the above to work, would it scale to a larger number of threads? (I'm sure there's a better approach than what I'm doing here.)
4. I'm also considering moving to passive synchronization with MPI_LOCK and MPI_UNLOCK. Would that approach happen to help here?
Thanks for any light you can shed on this. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Mark Davis
